Question about LG 32LG30 32 in. LCD HDTV
Optimum settings for 32LG3000
Factory settings are not optimum!!!!
I cannot give much of a solution based on the amount of detail you have given, but I will try.
Generally speaking most TV factory settings are set too high through the brightness and contrast controls, and this is probably the problem you're describing. I advise adjusting the brightness lower, and the contrast slightly higher.
Try watching a DVD and pausing a particular scene which has lots of dark gray's and white's and then try to figure out the optimum setting.
Posted on Apr 21, 2009
How do you adjust the water level on an LG front loader washer?
You cant, water levels are factory set for optimum water efficiency, new machines use a lot less water than older machines, poor wash results are usually caused by over loading
Oct 17, 2013 | LG WM-2277HW Front Load Washer
LCD 32lg3000 frozen
Make a hard reset to this set, and try again. To make it a hard reset, unplug the power cord from wall socket, and re-plug it into after 10 minutes or so. This must make it a hard reset. In most cases, this must help.
Jul 18, 2012 | LG Televison & Video
Can anybody help with obtaining a user manual for an LG Model 32LG3000 LCD TV. The LG website says it is unavailable.
Hi Roger,
You may view and save the copy of LG 32LG3000 user manual at this LINK. It is a Pdf file format.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Oct 12, 2011 | Televison & Video
Need to know then factory settings for the carburetor on a 78 it 250 e...how many turns out for the idle and how many turns out for the air/fuel mix?
I have the H model and set mine at one and a half turns out from stop. It waivers a little from summer to winter but only by a fraction.
As for the idle speed, when bike is warmed it will idle a little different to when cold and using choke.
Personal preference really, without a tacho fitted, I set it so she idles easy when cold. Once she's warm, idling is generally not used!!
To balance the two, warm engine and hold throttle at your optimum idle speed. Screw in idle adjuster until it engages base edge of carby slide. Release throttle and screw in/out fractionally to test if revs rise/fall. Set at optimum and then turn air mixture screw in/out till revs are highest (without using throttle). Then reset Idle screw back out to bring revs down to optimum level.
Tip, use a little thread seal on the idle screw as they have a nasty habit of unscrewing and leaving a hole in the side of your carby...sure fire way to lean right out and burn a hole in your piston when riding.
Cheers.
May 21, 2010 | Motorcycles
What is the tire pressure for front and rear tire on a 2001 Honda ace 750?
The factory recommendation is 29 psig in both front and rear if you don't carry a passenger. Tire inflation must be appropriate to the load they carry, and some tire manufacturers specify higher pressures for their brand.
You probably won't go wrong with the factory setting, but for optimum performance, you might do better with more pressure.
May 14, 2010 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
What is the default lock code for lg 32lg3000
Hi tcpipuk
To answer your question;
There has been two different factory default code for forgotten passwords.
First one is: 7777
Second one :0000
Hope this help Good luck
Apr 28, 2010 | LG 32lg300c 32 in. LCD TV
32LG3000 TV LCD - usb port ''service only''
Yes it's possible to use the USB port , you only have to change settings in TV setup to change it.
With software ver 3.15 it's very easy see link below how to change setup.
http://lgusb.wikispaces.com/#support
Feb 23, 2010 | Televison & Video
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
Sky remote control code for LG tv
Can you provide me with a set up code for my Sky remote control to work my LG LCD tv model no. 32LG3000?
Many thanks
Jan 09, 2009 | Televison & Video
LG 32LG30 32 in. LCD HDTV Logo
685 people viewed this question
Computer Repairing
Computer Repairing
