Question about ASUS Intel 815E Chipset CUSL2-C Motherboard
Bios boot failure.
My mobo cannot be booted into bios. In this case, how can I figure out which part is wrong? Please tell me.
  • 3 Answers
Start removing cards and add-ons one by one starting with graphics card... leave the ram and cpu for last... process of elimination
Posted on Sep 19, 2007
SOURCE:
Beeping & no display
beeping at boot means different things. google beep codes if you have another pc?. could be ram failure, processor, mobo failure , etc. Or..it could be a flat battery-which can stuff up the bios and wont boot. So check the mobo batt isnt flat first and reset the mobo bios- jumper pin. Hope that helps.
Oct 14, 2013 | IBM IntelliStation M Pro 6218 PC Desktop
Tip
Reflash Via EPIA-M 1000g BIOS when board is dead
I'm writing this in the hope that others like me can resolv their problem with the dead EPIA-M mainboard.The symptoms where.. on power-up .. it would make 2 high pich beeps followed by 2 low pich beeps..turned out that is the error code for dead BIOS.
OK so u have a dead bios and a mobo that won't boot for various reasons.. from flashing a wrong or corrupted bios or else.
Apart from the other ways to go around the problem like buying a new chip already flashed or flash the chip with a dedicated flasher u can follow on this simple guide.
You should at least have some experience in DIY in computers .
1. Find a mobo of an old  pc that uses the same socket for the bios chip.if it uses award bios even better.I used a biostar p4m800-m7a mobo to do this.
No need for it to have a hdd or something special attached to it.. power source and cd or dvd/rom will do.
2. Try to see if it boots, if all ok..
3. Get you hands on the Hiren's boot cd..burn it and boot from cd..it has in the Dos program list... in the next page BIOS/CMOS UTILITIES. Select uniflash 1.4.. i did it with the 1.4 on the hiren's boot cd 10.1 maybe if they update it it will work also.It will tell you the name of the bios chip and some details..make a backup of original chip just in case.
4.On other pc download the 109.BIN file .. the bios file known to be stable for the EPIA-M board. You can find it on some forum.. i can't remember now..I thank them by the way.Same the file on a fat32 usb key.
5.On the surogate board with uniflash started.. comes the tricky part: u have to get hold of some good tools and pull the bios chip out while it's running... don't worry, nothing will happen.
6. Pull out the dead bios chip of EPIA-M and put it in the surogate board.These steps must be done with absolute care.If you think you can't do it, wait or call a friend with more experience or get hold of the right tools
7. Now with the dead bios chip in place.. select in uniflash, rediscover bios chip.. or something like that,..can't remember well.. but you get it when you see the screen... the sst bios of the EPIA-M NOW SHOWS UP...
8. select flash bios and select the file on the root of the usb key by typing C:\109.bin.. if no hdd attached.. the key is seen as C, otherwise use letter accordingly.It flashes the bios in less that 10 seconds.. and says ok.. power off surogate mobo.. replace bios chip with original.. and enjoy now your EPIA-M mainboard again.
If you'd like to thank me or ask details..mail me at [email protected]
on Jan 19, 2012 | VIA Epia M10000 Motherboard
My MOBO is ASUS P4VP-MX. My bios fails to start. I reset my pins for bios the computer will run but when I restart again it will gave message that that BIO checksum failed. Is this a battery failure. I...
This error is not the same as a cmos Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
Diagnosis: The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 02, 2011 | Intel ASUS X Series Motherboard P4VP-MX...
I cannot get the s5000vsa to boot from usb.
It's a server mobo.. it might not be configured out of the box to support that. Check the BIOS.. after that check for any BIOS updated for that board. It might be an issue they resolved. You also might have to TELL it to boot from an external source (some MoBo's make you press the TAB button at POST to open that menu.. others the F10 key)
Mar 19, 2011 | Intel S5000VSA Motherboard
My HP XW4600 does not power up to boot though the fans are blowing at full power. HP certified techs replaced the board twice. What else could it be?
First, be sure the monitor is connected, and powered. Sounds stupid, but I have had the problem.
Next, When you start it, do you hear one beep while the boot process is going on?. If no, the problem sounds like the motherboard. Are you comfortable taking the side off? We will be looking for any lit leds.
This being my first time, I am not sure of the protocol, But, give me
a little slack. I wil look in my service files for information on that
model.
Nothing to do with your problem, but you need to increase the memory to at at least 2Gb if you are running XP.
Let know what more info you can give me. Any thing abnormal helps.
Larry Howard
[email protected]
Dec 03, 2010 | HP xw4600 Workstation - 1 x Intel Core 2...
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Bios failure, or what?
Hi there.
Try clearing the cmos
d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted. If there is no jumper remove the battery for an hour and make sure the power cord is removed from the back before you clear the cmos
Good luck and thanks for using Fixya!!
Feb 19, 2009 | DFI AK74-SC Motherboard
P5RD2-VM mobo will not post at boot
Three beeps for that bios is a memory error.Are you sure it's not a memory issue? Did you clear the CMOS and try to boot up again?
Dec 10, 2008 | ASUS P5RD2-VM Motherboard
Gateway 7405gx boot failure
Hi Dan -
On this particular Gateway series of laptops, there is actually a bios "chip" you can replace entirely. It's sitting in a cradle right next to where the keyboard connects to the mobo (square black chip, one angled corner). It's very easy to pop out and replace, and is definitely something I would try.
You can do a search on eBay for "gateway bios chip" and you should have some luck.
I hope all goes well.
Nov 22, 2007 | Gateway 7405GX Notebook
Motherboard pc chips m810 lmr v7,1
The beep codes are not universal, but there are a few popular BIOS's and you can figure out what 2 beeps means if you can find your BIOS listed here:
http://www.computerhope.com/beep.htm
The name of your BIOS should appear on the monitor as you're booting.
Nov 20, 2007 | Asrock M810LMR Motherboard
ASUS Intel 815E Chipset CUSL2-C Motherboard Logo
393 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
