Question about IBM (25P3294) Motherboard
X3500 could not start (power on)
IBM x3500 server, when i put power cable in the power supply unit, the light path shows error (service porcessor bus) sometimes no error, the green light blinkin, but when i push the white button to start server ; the cooling fan spins one time and the sas hdd light blinks for a sec after that no responce, the server could not start.
1. change the power supply hole unit
2. change mother board
  • Anonymous May 24, 2009
    hi me facinmg the same problem ..
  • IBM Master
  • 5,660 Answers
Suggest you change the power supply unit. 'Sounds' like a faulty power supply.
Suggest Electrolytic Capacitors have gone bad, in the power supply unit.
Check the link below, to see what Electrolytic Capacitors look like, and what they look like when they have failed. These capacitors don't Always show the visual signs when they fail, but most of the time they do.
I do not suggest you open the power supply unit chassis to observe closer though, as the capacitors can hold a charge for a L-O-N-G time. Sometimes weeks, or months. (Sometimes up to a year)
These capacitors are designed to slowly build a charge, then release it all at once. Should your fingers contact the terminals, of any of the larger capacitors, they could discharge their charge to You!
These could result in a bad shock or worse. (Even if your fingers contact a circuit that the capacitors are in, if your fingers complete the circuit, you'll be the recipient of the released charge)
Power supply unit unplugged from power, you can take a flashlight, and look through the ventilation holes, or slots. See if you do observe any bulging, or leaking capacitors. When they leak, there is a yellowish, or brownish ooze that comes out. It may come out of the top, or bottom of the capacitor.
At the top of the capacitor is an X, or this -> lK. It this is split open, you have a bad capacitor.
Link: http://www.capacitorlab.com/visible-failures/index.htm
Posted on Apr 19, 2009
Windows xp installation
Insert xp cd, follow the setup procedure and that is it ... finish with installing needed drivers.
Apr 23, 2014 | IBM System x3500 M2 (783932U) Server
INSTALL WINDOWS XP ON IBM X3500
Support for Windows Xp has ended 4-12-14
Terry
Apr 10, 2014 | IBM System x3500 M2 (783932U) Server
Ibm system x3500 BIOS update failure
Have you waited to see if anything shows for awhile (by awhile I mean 30mins to an hour.) Like you said it still could be updating.
Jan 24, 2014 | IBM System x3500 7977 - Quad-Core Xeon...
Controller monitor failed,controller not started appeared on my screen when i opened our server systemx3500
This is a raid controller failure. Server is not able to initialize device.
Workaround:
1: Turn off server
2: Take out Raid Controller from server > blow air on raid controller slot to remove dust.
3: Put it back
Now turn on server and see of it gets initialized.
If you still gets error then its time to replace controller
Thanks
Dec 06, 2012 | IBM System x3500 7977 - Quad-Core Xeon...
IBM xseries eserver x236 Bios problem: a yellow light( !) like this is on and IBM server can not start
Try this:
Light path diagnostics
Many errors are first indicated by the illumination of the system-error light in the operator information panel on the front of the server. One or more lights inside the server might also be lit that can direct you to the source of the error. The system information LED lights to alert you that there might be important information recorded in the system-error log. 2. Removing the left-side cover and look at the light panel. These LEDs indicate the type of error that has occurred.3. Once you know the general type of error and the general location of the component involved, the next step is to check the system service label on the outside of the server. This label gives an overview of internal components that correspond to many of the LEDs on the light path diagnostics panel and can help to view lit LEDs inside the server. Note: Some of the LEDs on the light path diagnostics panel will not have a corresponding LED lit on the system board.
Good Luck
C2Solutions
Dec 31, 2010 | IBM eServer xSeries 236
Hi, my server doesn't turn on with the power button, what can i do? The power led indicator is blinking but when I push the power button nothing happens. Is there any other way to turn on that server?
Hi
first thing i would check would be that you are using a good grounded outlet. Checking with a ground fault checker will tell you if you have a grounded outlet. If the ground check fails, try plugging into an outlet that does check good.
If you dont have one handy, then the easiest way to determine what is causing your server not to boot, is to check the light path diagnostics.
here is a link to the IBM options install guide that also has the diagnostic codes and instructions for accessing the light path diagnostic panel, inside the server.
To access the light path diagnostics panel, slide the latch to the left on the front of the light path diagnostics drawer.
This section starts on page 12 in the manual, or page page 24 in your PDF reader.
ftp://ftp.software.ibm.com/systems/support/system_x_pdf/25r3454.pdf
This could be any number of issues from a faulty VRM, or failed power supply, or bad processor. The light path diagnostics will tell you where the problem is, or at least where to start.
Hope this helps
Jan 04, 2010 | IBM xSeries 346 Server
IBM fan error
I have updated all the firmware of the server using latest updates
and after restar it work properlly . waw my problem solved.
Dec 30, 2009 | IBM x3400 Server
No start netfinity 5600 server
Now you know that the processor and ram are good, use these on all the boards, and check the boards that dont startup are the bad ones.
Oct 22, 2007 | IBM Netfinity 5600 8664 Server
IBM (25P3294) Motherboard Logo
1,991 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
