Question about Magellan RoadMate 3000T GPS Receiver
Reparation I can't charg it and the batery is low.
  • crunce Nov 23, 2007
    pin broken out of the dc socket on the unit
    can this be by passed and if so how
Can't get the screws to turn to open up the unit. Where can I take it to fix? I hear the power pin rattling inside the unit.
Posted on Jan 04, 2008
    Novelist:
    Scholar:
  • 86 Answers
Power pin probably came loose. If you can open up the unit and re-solder the power connector to the board. If you need more assistance re-post and I'll tell you in further detail. Also, make sure the end of your power cable is getting juice.. flow.. is hot? live? has power to it.
Posted on Sep 28, 2007
SOURCE:
The batery of my toyota highlander hybrid is too low; how can I conect other batery for to solve the problem?
You don't. If your battey is running low than run your car. A 2009 should not have a battery that is running low on charge. If the battery is not being charged by the charging system than bring the car back to the dealer from which you purchased it.
Dec 24, 2010 | 2009 Toyota Highlander Hybrid
I got a new battery, its been in it for a month or so. Now its dead and when I jump it off it starts then I turn the headlights and it dies and the battery is dead again.
In computer controled cars the computer needs at least 10 volts to operate . If your car is not charging or not carging enough The voltage is low to start with when you boost it. Then you turn on the lights it drops the voltage more to where the computer can't opperate. The batery should be charged before you start it anyway because it is really hard on the altinater to recharge a dead batery. An altinater is only meant to keep a batery topped up , its not a cahrger.
Oct 21, 2010 | 1997 Toyota Camry
I have an m5310 and i have troubles with the battery charge i bought a new battery but is still the same , i plug the notebook to the ac power and batery start to load (the front green light is on ) after...
Try to perform power drain on the motherboard.
heres the steps:
take out the battery
unplug the power adapter
press and hold power button for 30secs
put the battery back in
plug in the power adapter
power on the computer
if same issue will happen then you need a battery replacement.
May 21, 2010 | E-Machines M5310 PC Notebook
I have a 93 accord with the d4 blinking. i checked the solenoids and that wasnt the problem. i have to shift the gears my self and its an automatic. my batery was really low and thats when i noticed...
I am seeing this problem a lot on this board. I had same problem. Change the TCU unit under the passenger side floor board (pull up carpet and you will see it, easy to change). Got a used one from a junk yard--lot cheaper.
Mar 13, 2017 | 1993 Honda Accord
Internet will not connect when the laptop is being charged
only when is charged ? or when batery is going Low ?
try to change for best performance not foe saving batery life option... should help
Nov 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Handset is fully charged but phone goes blank after a few seconds
Try to replace you batery. It is not meant that a batery is still good when you gonna perform a charge.Because even it has the ability to accept power on it,it it will fast draining the stored power when a batery is weak due to the what we call low amperes .,the amperes of a batery is too small than the given specification when it is still new thats why it is so fast to drain its power.
Nov 05, 2009 | Computers & Internet
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
When trying to start my 05 fatboy,clicking noise starts
your batery is low or it needs replaced. the clicking noise is the starter relay but the silinod is not pulling in becase it needs more amps. try charging the batery or i wold just replace it.
Dec 15, 2008 | Harley Davidson Harley-Davidson Motorcycle...
I.Mate -JAQ charging problem
my i mate jaq charging jak iss broken i need charging jak jumoers
Aug 27, 2008 | i-mate JAQ Pocket PC
Magellan RoadMate 3000T GPS Receiver Logo
56 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
