Question about Whirlpool GU2400XTP Built-in Dishwasher
I have white crusties with black spots in all along the seal on inside of door, and along filter on top left side of door (inside). and also i use jet dry and my glasses and dishes are coming out cloudy looking. also i have to fill the rinse agent every wash instead of monthly. Is there any special cleaning that needs to be done to this?
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Problem is your water. that is from the calcium in the water. go to www.dishwasherfilter.com and get the filter system . it will make your dishes sparkle and help clean out your dishwasher.
Posted on Feb 28, 2010
White spots on exterior of microwave door glass
Exterior or interior? If they are on the exterior then something unassociated with the oven has caused them. If they are between sheets of glass then could be silacone fume residue or if it has a clear plastic filter on the inside of the glass, could be that. If they happen to use laminated glass, it could be the plastic middle but I doubt they would. Radiation leaking from microwave ovens is really a bit of a myth. Yes, if you have a damaged seal and there is a big enough gap, microwave radiation can leak out but unless you are hugging your oven, it's no real drama, according to current medical experts.
May 05, 2017 | Kenmore Kitchen Ranges
Water seals
doors or windows doors the seals go under trim that must be removed most just snap in place some use screws remove and replace weather strip . door seals they seat around the top in a grove on either side and inserts along the sides and bottom. door window seals out side remove door panel remove mirror pull up remove moulding inside just pull up strip and replace.
Jul 29, 2012 | 1996 Chevrolet Suburban
How to seal a small hole inside the door of dishwasher from the metal end of the top rack hitting along the inside of the door.
Remove the epoxy, and clean the area with alcohol.
When dry, add a small amount of GOOP adhesive to the area. The door must be left open for at least 12 hours for the adhesive to set enough to prevent sagging. unit should not be used for a total of 24 hours for complete hardening.
The GOOP adhesive is available in the glue/adhesive sections of hardware and big box home center stores.
As an appliance tech I have used this product for many years on tubs of all types to save my clients from expensive repairs. It holds very well, yet can be removed if need be. As time goes on, you may need to add a little more to cover any additional wear that may occur.
Let me know if it worked out for you.
Apr 13, 2017 | Frigidaire Dishwashers
How do I change cabin air filter in 2006 m35? video or pics?
First, you need to remove the glove box: Open the glove box. There are three hinge points at the bottom of the box (left, center and right). There are "tabs" on the box that slide into these "holders". Gently pull up and out on the left side of the glove box. The tab should pop out. Repeat for the center point. This should allow the left side stop pin to clear the dash slot. Repeat for the right side. You should now be able to turn the box, pull it from the dash and let it hang from the retaining cord on the right side. Note the hinge slots and tabs for reference for re-installation later. Second, remove the black access door behind the glove box: This is an "L" shaped cover with three hinge points at the bottom and three tabs at the top. Gently push back on the tabs at the top to un-lock, rotate down on the hinge points and pull out. Behind this you will see a white plastic door which covers and holds the filter in place. Third, remove white access door as follows or you will break the retaining tabs off! On the right side is a locking tab, gently press in and pull the right side of the tab toward you to unlock the tab BUT STOP AS SOON AS THE TAB UNLOCKS THE DOOR AND OPENS ABOUT ½ " or the tabs on the left side will break off, they are not hinged! Next, slide the door to the right to clear the tabs on the left side and remove. Note the position and orientation of the filter inside. Remove the old filter. Fourth, install the new filter: Make sure the orientation and air flow direction are as marked and match previous filter. Mine was pointing "up", with the rigid side plate facing out. The new filter will be sitting on top of the fan, when the white door is re-installed, it has "fingers" that lift the filter into the proper location, but you may find it easier to lift the filter up with one hand and slide the door back into position with the other hand. That said, lift the filter, slide the tabs on the left side of the door back into there slots. Push the door back into original position and latch the right side locking tab. Make sure the door is sealed and back to original position and latch tab on the right is locked. Now, reverse the previous steps to complete the task. Re-install the black access door cover. Lift up the glove box and turn to install right side stop pin into dash slot position, rotate left side into position and center box in dash opening. You will have to move the box up/down, in/out a bit to "feel" the hinge tabs properly engage the hinge slots. Once the tabs are in the slots you can push down on each side and it will pop back in place. (If you have difficulty, you may want to remove the under dash cover below the glove box. There are three tabs in the front that slide into three slots and one tab and slot in the rear. This can be removed by pulling down on the front of the panel at each side and the middle, then slide it forward out of the rear slot. Disconnect the light if required by pushing the latch on the plug and pulling it off. Feel around the hinge locations to guide the parts together).
Read more: http://wiki.answers.com/Q/How_do_you_change_the_cabin_air_filter_on_a_2006_Infiniti_M35#ixzz1NKCLa6qC
May 25, 2011 | 2006 Infiniti M35
I was told my cabin air filter is dirty. Where is it and how do I replace it?
The Cabin Air Filter is located outside the car, underneath the Left side, plastic cowling cover at the base of the Windshield. To access the old Filter cartridge:
1. Turn on and Stop the Windshield wipers in the UP position, and turn off the engine, remove the Key.
2. Standing in front of the car, raise the Hood and observe the black plastic cover panel which covers an area, along the base of the windshield, from the Passenger side Hood Hinge, and extends toward the center wiper, (approx 2.5 feet long by 6 inches). The Filter is beneath this Plastic Panel. Yep, it looks and is flimsy, so be careful.
3. Before you can remove this panel, you will need to gently peel back the Soft Rubber Engine Compartment Edge Seal, (approx 1 inch around and 5 feet long), that extends from Left to Right along the base of the Cowling, from Hinge to Hinge. Only Peel back about half of the Seal. When I did mine, I removed the entire Seal, inspected the Seal for damage, washed it and treated it with Armor All. I was also able to squeeze the rubber seal along it's base, tightening the grip pattern, to prepare it for re-installation. Also, by removing this seal, you have the opportunity to clean the entire cowling space, removing all sticks, leaves, and debris.
4. To remove black plastic access panel, CAREFULLY remove the two plastic retaining plugs, by prying up the center studs about one half inch, and then pull out the plugs, (each plug has two parts, take care to avoid loosing the center part). You will also find a 1.25 inch diameter black plastic clip that unscrews with a screwdriver. If you find a plug missing, or you damage the plug, NAPA has replacements. Don't be a cheapskate, if they are broken or missing, replace it, otherwise you could have rain flowing into your vent system.
5. When you pull up the panel, you will find it may stick to the surfaces. There are some foam tape seals that line the panel beneath. Take care to avoid knocking these off. Gentley clean and prepare, and Armor All the Top/exterior surface of the plastic panel. If the foam tape falls off, clean with plain water and soap, and treat/clean with Denatured Alcohol, and use replacement foam tape also available at the Dealer, NAPA, and Home Depot. This stuff is thin, so don't get anything that is too thick or it won't go back in.
6. You will find the Cabin Filter under the panel. You will also find another Body Seal, (similar to the Engine Compartment Edge Seal), which should be cleaned, inspected and treated. When I opened my space, the Seal had previously fallen off the Sheet Metal. Consequently, the rain water was splashing around the Filter space. Care must be taken to assure that this inside, secondary seal is in good condition and capable of being reattached. If the seal is a bit sloppy, you can pinch the base of the seal, which improves the grip strength for re-installation. The idea is to shunt the rain water that may leak underneath the black panel, over to the drain on the Left.
7. Before removing the Filter, take a good Shop Vac, and clean out all the debris, so that it does not accidently fall into the the cavity below, when you remove the filter. You will find, that when you remove the Filter, the White Plastic Squirrel-Cage Blower is visable. If you aren't careful, the rubbish falls in.
8. Once cleaned out, and the Old Filter Removed, gently wipe the interior space with a good bacteriacide, or other sanitizer, with lint free cloth. Spray the cloth, not the surface. Inspect the Blower, with bright light, and assure that no debris fell into the motor. (Remember the Key is off and out right?). The blower will/should freely spin, be gentle, baby fingernail only please.
9. I took this opportunity to use an aftermarket spray cleaner/disinfectant, for the ventilation system, permitting you to spray it directly into the blower. Follow the product instructions, which includes preping the system, (before you start this job), by running the blower on high heat, with and with out AirConditioner (on max high heat). Follow the directions.
10. I used Replacement Filter, by Fram, "FreshBreeze", Part No. CF8392A, about $10.
11. I also took the time to gently wax the entire painted surface all around and inside the cowling, and hinge surface, before closing up the panel. There is a large water drain to the far left, behind the Hood Hinge, and it is good time to get the rubbish out of the hole and clean and wax the space.
12 Return the Black Panel, taking care to assure that the left rubber/vinyl left tip, lays flat, behind the hinge, and along the fender. The panel will line up with the two plug holes and the screw on cap
13. Reinstall the Engine Compartment Seal, along the base of the cowling, and enjoy the fresh air.
14. So long as you are this far along, check to be sure your Wipers are in good shape.
Aug 23, 2010 | 2001 Buick Century
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
How to change cabin air filter in toyota avalon 2002?
1) Turn off the ignition switch while leaving the wipers in the up position. 2) Open the hood and properly secure it in the open position. 3) Gently pull the rubber cowl seal away from the cowl vent screen. Place your hand underneath the right half of the cowl vent screen and lift straight up, thereby releasing the four spring clips and removing the right half of the screen 4) Remove the water shield. Carefully disengage the two water shield locking tabs and slide the water shield toward the front of the vehicle, lifting the water shield up and away from the vehicle 5) Remove the Passenger Compartment Air Filter, being careful not to allow debris or loose components to fall into the filter housing. Replace the Passenger Compartment Air Filter with a fresh filter and reverse the above procedures to reassemble the vehicle components. �
I am not sure what time in the year your 2001 Avalon was built but her is the procedure that I just followed: 1. Open glove box and remove contents 2. Remove the three philips head screws along the top inside frame of the glove box. 3. Remove the hex head bolt in the lower right and Philips screw in the lower left side of the glove box frame. 4. Unlatch the black cover plate from the roof of the glove box. This holds an electrical connection and will need pushed up through the hole when the entire box is removed. 5. Pull on the top left side of the glove box to release the pop tab. Repeat on the right side. 6. Carefully lower the glove box assembly. 7. Disconnect the electrical connection to the trunk disable button 8. The entire glove box can now be removed from the area. The door gear assembly does not come off of the box and is easily damaged if attempted to do so. 9. The Cabin Air Filter assembly has a white cover. Pop the tabs on the right and left side and slide the assembly out. 10. Replace the filter in the assembly. Make sure the airflow indicator points down. 11. Re-Install Air Filter assembly. 12. Re-Install the electrical connections remembering to slide the one through the hole in the top of the glove box. 13. Push glove box assembly on pop tabs. 14. Re-Install screws and bolts. 15. Reconnect the black cover plate to the top of the glove box.
rate it
Jan 08, 2010 | 2002 Toyota Avalon
Ford 1988 f250 will not start up.
Pass side inside on the fire wall inside by the heater core just below it. There's a black box with white botton on top. Push the white button downword to reset the fuel pump.
For the fuel filter, you'll find it along the inside fram rail in the driver's side. Just follow the fuel lines.
Good luck oh and not sure if the 1988 F250 are the same as the 86, but if they are what i typed out should help. Happy Easter
Apr 12, 2009 | 1988 Ford F 250
Rain water leak
The most common source of this kind of leak is the windshield, have a glass shop check the sealing around the glass
Sep 04, 2008 | 1992 Mercury Grand Marquis
Whirlpool GU2400XTP Built-in Dishwasher Logo
167 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
