Control panel icons and properties tab are not working
When i right click the mouse and try to open properties, i am getting an error. Also the icons in control panel are not working
    Scholar:
  • 40 Answers
The first step is to scan for spyware. These nasties can alter system files. Download MS Antispyware and Ad Aware and scan or spyware.
Also run a system file checker command to update any missing files Go to Start>Run>type "sfc /scannow" without quotes.
Note: it is advised to keep the original windows CD handy while prforming SFC \scannow as it tries to update the missing/ corrupt files.
Regards,
Arpit
Posted on May 01, 2009
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
I have no sound. maybe my computer has been muted
Check that sound drivers are ok as follows
  • Open your start menu (right-click on the "Start" button and choose "Explore"), and find the "My Computer" icon. Right-click on it and choose "Properties" from the submenu. Click on the "Hardware" tab and then the "Device Manager" button.
  • Expand the "Sounds, video, and game controllers" heading to find your sound card. The name will depend on what sound card is installed on your PC. It will most likely have a name containing "audio." It should look something similar to the example above. You'll know immediately if there is a major driver error because an exclamation point (!) will show over the card's icon.
  • Double-click on the name of the sound card to open a new window. In the new properties window click on the "Drivers" tab. If there is no "Drivers" tab then you chose the wrong sound device. Go back and try again. On the "Drivers" tab, click the "Driver Update" button. Follow the Wizard's onscreen instructions to update your driver. You can also contact the manufacturer of your PC for the most recent audio drivers. They can usually be found online.
if the drivers were OK, proceed as follows
You can check the system volume and adjust it as follows
No. Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Sounds and Audio Devices.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Move to Sounds and Audio Devices by pressing the arrow keys.
  • Press ENTER.
3 In the Sounds and Audio Devices Properties dialog box, on the Volume tab:
  • Adjust the sound volume by moving the Device volume slider.
  • Select OK.
  • Adjust the Device volume by pressing the RIGHT ARROW key for higher volume (louder), and the LEFT ARROW key for lower volume.
  • Select OK.
4 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
Apr 25, 2011 | Computers & Internet
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All...
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Mar 23, 2011 | Toshiba Satellite A40-S161 Notebook
Help. I want to disable the touch pad on my Gateway M6866 laptop. Whenever I am typing and get near the pad, the typing goes all over the screen. Any help will be appreciated.
Follow these steps to turn on or turn off the touchpad and optional pointing device.
  1. From the Start menu, click Control Panel.Note: If your Control Panel is in Category View, click Printers and Other Hardware.
  2. In Control Panel, click or double-click the Mouse icon.
  3. In the Mouse Properties dialog box, click the Device Settings tab.
  4. Click to select the device you want to turn on or turn off, and then click Enable or Disable.
Mar 13, 2011 | Gateway M-6866 Notebook
How do I disable touch pad from Dell Latitude E5400
You may disable the touch-pad by following the steps mentioned below:
  1. Click Start and then Control Panel
  2. In Control Panel, click on the Mouse icon. Note: If the Control Panel is in Category View, under View by, click either Large icons or Small icons.
  3. In the Mouse Properties window, click on the Device Settings tab.
  4. In the Device Settings tab, click on the Settings button.
  5. Check or uncheck the checkbox next to Enable Tapping then click OK.
  6. On the Mouse Properties window, click Apply then OK.
Hope this helps..
Feb 20, 2011 | Dell Latitude E5400 Laptop
I am trying to connect my webcam with out the disc
Instructional steps
  1. Click the "Start" button, then click the "Control Panel" icon on the Start menu. This opens the Control Panel window.
  2. Click the "Switch to Classic View" link in the left-side navigation pane of the Control Panel window if the Control Panel is not already set to classic view. When the Control Panel is set to classic view, you will see the "System" icon in the right-side pane.
  3. Double-click the "System" icon in the Control Panel window. This opens the System Properties window. Click the "Hardware" tab; then click the "Device Manager" icon to open the Device Manager window.
  4. Click to expand "Sound, video and game controllers" in the list of device categories in the Device Manager window. Double-click the "Microsoft LifeCam" icon. This opens the Microsoft LifeCam Properties window.
  5. Click the "Driver" tab in the Microsoft LifeCam Properties window; then click the "Update Driver" button. This opens the Hardware Update Wizard. Follow the wizard prompts to install the Microsoft LifeCam VX 1000 driver and complete the process.
Oct 24, 2010 | Microsoft LifeCam VX-1000 Webcam
Getting error message the current port is not supported for the printer status
Hi there
Go to start and then go to your settings control panel and then click with your mouse on printer and open printer then click on the printer icon you using with left side mose to properties then you will see the tab says port just try a dierent port till you get it right
All the best Pineworks
Mar 17, 2010 | Nikon COOLPRINT Thermal Printer
I have been having a problem with the cursor jumping. I would like to turn off the touchpad but cannot find that application. HELP!
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Oct 11, 2009 | Dell Inspiron 1420 Notebook
My touchpad on my HP Pavillion6000 doesn't work.
If you are using a windows OS, right click on the desktop, click on properties,click on the"appearance tab", on the bottom right click on "effects", once you get here, see if the large icons radio box has a check in it and un-check it, Then hit apply, you should see the icon reduce themselves to a normal size
Sep 20, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
