Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
Power on, but no video
Hello. I have a 60 inch Sony kp-65sw510 that has been given to me. The problem is that it powers on, but no picture is coming through. So how do i fix it?
  • 87 Answers
SOURCE: 60 inch sony wega lcd projection
Possible themal sensor. Easy to bypass too!!! Check with authorized Sony repair facility.
Posted on Dec 23, 2007
  • 51 Answers
SOURCE: Sony KP-57WS500 57 in. Rear Projection Television
Hi Guys
Your problem here has to do with the amount of aging that happens to the three colour tubes - red, green and blue.
Blue actually ages slower than red and green. What actually happens is the green tube deteriorates and due to green being the predominant colour for brightness causes the blue tube`s flyback lines to appear - especially when switching between inputs or when the video is blanked.
No replacing the blue tube will not solve your problem as the tube is actually the best one of the three.
As someone mentioned there is a way to adjust this by removing the speaker grill assembly in front of the set. Doing the service mode adjustment with the remote is not the right way to solve the problem - you would be adjusting the colour gain and off-set values and would seriously be compromising the white balance of the set.
On the left hand side behind the speaker cover you will see a black square block with six adjustment points. Look for the one marked SCR BLUE, Switch the set to a unused input so the blue lines become visible. Now adjust the BLUE point counter clockwise until the lines disappear. A small adjustment should do it, Switch back to a picture and make sure the whites are still white.
This should sort your problem. I would however suggest asking a Sony service centre to do this for you. This is a dangerous thing to do as you will be working close to the 35Kv supply the the anodes of the three tubes.
I hope this answers your question.
Goo luck.
Posted on Mar 08, 2008
SOURCE: Sony kp-61s70
I used to work at an arcade and we constantly had the problem of hues on the screen, there is a product you can buy that will fix this problem, though I'm not sure how much it costs since we just had one at the arcade. It is a magnatized wand that you plug in to a power source and wave around in front of the screen for a few moments. It did the job everytime.
Posted on Jul 18, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony kP-57ws500 picture is distorted not right
It calls convergence problem due to failure of convergence output ICs.
If you want to repair it at your own, let me know if you have basic electronics knowledge and little experience to guide you more.
Posted on Nov 08, 2008
  • 4234 Answers
SOURCE: My Sony KP-57WS500 57 inch
If the colors are separated, this is a convergence problem that can be as simple as poor connections on the convergence ICs or defective ICs. Please provide a more detailed description if you can. If you can solder, you may be able to fix this yourself. Let me know if you wish to attempt the repair.
Thanks,
Dan
Posted on May 05, 2009
My kp-57ws520 standby light blinks 9 times tv does not come on any more it did for a short period of time
I had a similar problem with a sony 60" lcd hdtv. The normal power on light was green. When I had an issue the led would flash about 8 or 9 times. Can't remember exactly. It turned out to be a troubleshooting code. When I researched it, turned out to be the high powered lamp that lights the lcd screen was shot. When this happens you get no picture or sound. It's not a terribly difficult job to replace it yourself. I found a replacement bulb on line by my model number along with instructions on how to replace. You probably get about 4 or 5 years out of a bulb depending on usage. Hope this helps.
Jun 26, 2014 | Sony KP-51WS520 51" Rear Projection...
Tv blinks 5 times...picture wont come on...sony model kp-51ws520
internal power supply problem. needs to be checked by service tech shop. also try a different power outlet to see if the set does the same thing? if it does then follow the above.
Aug 22, 2011 | Sony KP-51WS520 51" Rear Projection...
Where is the fuse located on a KP53S25 Sony TV?
hello there should be a glass fuse in the power supply also beware in a lot of sony sets there are soldered in fuses aswell. and circuit protectors i hope it helps
regards
shaun
Feb 05, 2010 | Sony KP-53S25 53" Rear Projection...
I have a sony 60 inc rear projection lcd. the tv turns on ok, however, the picture and sound goes off and then comes on again. this happens every 15 minutes or so.
hello do these checks first Adjust the Picture setting in the Video menu (see page 49).
❏ Adjust the Brightness setting in the Video menu (see page 49).
❏ Check antenna/cable connections.
❏ Adjust the convergence again using FLASH FOCUS (see “Adjusting the
Convergence Automatically – FLASH FOCUS™ –” on page 33). if this don't work get back to me and we'll try somethink else thanks
shaun
Oct 13, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
Dec 05, 2008 | Sony KP-57WS520 57" Rear Projection...
Sony KP-61HS10 blinking codes
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
You can get the service manual and free support at the following site to help yu with the repair of your sony the manual is 10.99 support is free here is the link. They will email the manual to you.
http://servicemanuals.vstore.ca/
Feb 14, 2008 | Sony KP-61HS10 61" Rear Projection...
Long time to power up video
My Sony KP-53XBR200 will not display any video (even from the tuner) except the internal display until it sees a video input on one of the video jacks on the back after a power hit.
I solved this by putting a video cable from Monitor out to Video 4 in (unused for other video). Voilla! Instant video on. This may not be your issue, but it fixed my set!
Oct 20, 2007 | Sony KP-53XBR200 53" Rear Projection...
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
