Question about Mitsubishi WD-Y57 57" Projection HDTV
My Mitsubishi WDY57 dlp projection television will not power on.
In advance i appreciate any input that can be given. Recently my Mitsubishi dlp television (Model # WDY57) has started to randomly turn off. At first i thought it might be the air flow defect coming up again. But a year ago i had a technician from Mitsubishi come out and replace the sensor in the television and it has not been an issue ever since. Originally i thought heat might have been an issue since i have so many devices running underneath the television set. But i have a fan pointed at the back of the TV at all times running on high. I've cleaned the television of all dust and looked at the power panel and motherboard in the television and it appears to be normal (no burn marks or show of damage). As of today i can not get my television to turn on at all. If i unplug it for a while and plug it back in the timer light will light up and blink for about 30 seconds then back to nothing. It is hooked up to a power surge protector and all other devices in that area have not had any complications. I also ended up replacing the original lamp about six months ago and have not had any complications until recently. Time frame that it took for it to just not turn on anymore was about 2 to 3 weeks with it turning off randomly once every 4 to 5 days. Any help would greatly appreciated!
  • booniesman88
    booniesman88 Nov 27, 2010
    on the front of the unit after you turn it on and it shuts off, press and hold the menu and device buttons for a few seconds. you should get a series of flashes from the green LED. 1 pause 2, is an "all ok" code. the code pattern will repeat about 5 times. please let us know what you get.
SD Tech
  • 14553 Answers
SOURCE: We recently experienced a power outage, but once
The blinking green light is the DM unit in the set booting up like a computer.
Several things can happen here--Research by model number with GOOGLE, model number and problems.
It is often called the blinking green light of death.
The most common problem is 4 filter caps in power supply (they run 7/24 and supply voltage to DM unit fail--also some fuses there.
If you look on the net you will find places that sell kit for this repair.
This is also one of a group of several Mitsubishi sets with this kind of problem--It is not the Lamp!
Some of these models develop so many problems Mitsubishi now sells a chassis replacement--includes power and several boards that develop bad caps.
Understand: Mitsubishi has a long history of caps failing in their sets, it goes back almost 30 years. I have seen older ones where over 20 filter caps were bad.
You can talk to Mitsubishi to see if chassis replacement is available for your set--this came about as a result of the threat of hundreds of people entering a class action lawsuit (several).
If this told you something you did not know rate this solution as very helpful as I do this here for free.
If you have questions make a "comment" here and I will assist you.
SD TECH
Posted on Aug 24, 2010
Testimonial: "This is somewhat helpful. I'll contact Mitsubishi. Thanks!"
  • 1153 Answers
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Posted on Dec 17, 2007
  • 301 Answers
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Posted on Feb 20, 2008
Slinteriors
  • 8617 Answers
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
http://servicemanuals.vstore.ca/
Posted on May 08, 2008
milmar
  • 50 Answers
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Posted on Aug 11, 2008
I have Mitsubishi WDY57. When I turn on the tv it says "TV will shut down in a few seconds. Please check if the air flow is blocked" TV then shuts off. Any suggestions?
Susie, try removing the lamp assembly, and blowing out the ventilated area on the lamp assembly housing. i had this issue on my wd-y57 recently and that solved it.(mine was really packed with dust...) i made sure to hold in the system reset button after doing this (located in the controls panel on the front of the tv) but not sure if that is necessary.
Jun 23, 2011 | Mitsubishi WD-Y57 57" Projection HDTV
I was recently given my sister's 55in mitsubishi rear projection tv. It was working great when we unplugged it but when I plugged it in at home it did not turn on at all. The only thing that is showing...
We have a 55in mitsubishi rear projection tv.
It was working great when the electricity went out (it was plug'd into a power strip) when the electricity came back on it did not turn on at all. The only thing that is showing that there is even any power going to it is a flashing green light by the reset button that does not turn off unless unplugged. I have followed the troubleshooting instructions for resetting etc but no help. Any suggestions would be appreciated. M Deisley
Nov 28, 2010 | Mitsubishi WS-55819 55" Rear Projection...
My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
May 01, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Where can I buy two capacitors for my Mitsubishi WD-52525 52 in?
Thats the best place to order them from, as they have the correct replacement cpacitors which are the high temp orgional capacitors. They should have which ever ones you need.
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi Projection TV Power Supply Board assistance - Model # WD 62525
Mr.Marxxx you need to let one of your friends fix it for a small fee.Just like everyone else does.
Jul 28, 2008 | Televison & Video
Mitsubishi WS-55313 no video
Resolder the vertical output IC that should take care of your problem.
Jun 16, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WD-Y57 57" Projection HDTV Logo
546 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
