Question about Creative Labs SBS 370 Computer Speakers
Creative Speaker Of Model SBS-370 The Volume Control is not working, How to directly Connect those two Wires connected to Volume control,bypassing the Volume Control Switch
1. connect:Both Ground (copper wires) with Green wire
2. Connect Red with Blue and
3. Connect White with Yellow
This will give Stereo Output.
Posted on Feb 06, 2012
  • 3 more comments
  • SURENDER KUMAR Feb 06, 2012
  • karanraj98
    karanraj98 Oct 07, 2012
    i have done this not working sir can you plz tell other...
  • Justin
    Justin Dec 24, 2013
    Even I am facing the same problem now.. :( Any solutions found by now...???
  • Vipul JAIN
    Vipul JAIN Nov 14, 2015
    yes, it worked for me, thank u very much sir.
  • Edward Agnel
    Edward Agnel Aug 09, 2016
    Awesome! thanks for the trick :)
    Edward
Hey i have connected the wires like this
But getting some humming noise, can u please help me with this..
Thanks in advance :)
Posted on Dec 25, 2012
Generally this is due to ground problem, signal gnd and power gnd need to be separate (i faced the same problem even i dint do anything from hardware side .. don ask me hw it happned).. open the volume controller u will find a small PCB (printed circuit board) with volume control ,LED and a connector. see at the back side of the voume control u will see five pins starting from right side short 1st and fourth pin. provided you connect ground of both cables which goes inside the volume controller.. it works for me.. you may experiment as i did...
Posted on Jun 06, 2009
  • 4 more comments
  • thomaspmathe Jul 12, 2011
    hey dont worry yaar , im also looked for a week for the solution . at last i removed the volume controller myself and joined the RED+GREEN as one and then Joined BLUE+YELLOW+WHITE and connect the ground togather(copper wire) . Then it worked .. No problem Trust me
  • Rahul Karkhanis Jul 25, 2011
    That was helpful, shorting 2 and 3 from the right helped and is giving consistent results when I short and unshort them manually with a piece of small wire or any connecting piece of metal. ust used a short piece of cut wire to size (few millimeters) and a cello tape to keep it in place. you may use solder for a more permanent solution.
    BTW, I did not want to get that messy an involved but Bharathij's idea worked and made me do the above. Thomaspmathe's idea may work because he is eventually shorting the wires of which the connections may be shorted on board but beware, each shorting or opening of th connections causes effect to the voice, treble and bass. So preferably perform Thomaspmathe's idea as a last resort because you are also removing the volume control completely from the system then, but again is an option to get your system working.
  • Austin John
    Austin John Oct 27, 2011
    1.connect 1st and 4th from the right
    2. short 2 and 3 counted from right
    (this will give you stereo output at max volume)
  • adityaaserkar Dec 06, 2011
    i m having the same problem thinking of trying what u all have suggested. but as @austin john suggested, can u tell me exactly which colour wires should be joined GREEN WHITE RED BLUE YELLOW BLACK.................
    This will give Stereo Output. Trust me and Go ahead !
1.connect 1st and 4th terminals of the pot counted from the right to left2. short 2 and 3 counted from right(this will give you stereo output at max volume)
Posted on Oct 27, 2011
Please sir creative sbs 2.1 370 made in china working and power in 11.5v 1.6a adapter is damage and new Ac Adapter input Ac 100-240-1.4-0.7A50/60Hz Output Dc 12v , 2A speaker in on one min ok and speaker slow sound no bass sound please help me
Posted on Mar 12, 2011
  • steevoxavier
    steevoxavier Oct 05, 2012
    dude i think for creative sbs we have to use ac transformer .. as it requires only ac current there is no need for adapter with the rectifing circuit . so u can use a tranformer rated 12v and .5 or 1 amp I am not sure abot the amp rating just check the cae you are having .
Here is the solution that really worked for me.
  1. Connect Yellow, Green & White wires
  2. Connect Red and blue wires
  3. Connect ground copper wires
Posted on Aug 23, 2013
Creative Speaker Of Model SBS-370 The Volume Contr - creative-speaker-model-sbs-370-volume-ohlhgpql0cwzj23qzxa0titc-4-0.png
Can anybody help me to make the volume controller direct as above stated for creative sbs 2.1 370 (NEPTUNE MMS110 REV A)
Posted on Dec 08, 2015
Thanks, It worked for me.
Posted on Oct 04, 2014
I get a weird sound frequently from the woofer and at that time only either of the speakers work.......solutions please...????..
Posted on Nov 22, 2013
Creative SBS 370 2.1 - left audio channel is not working
This is coz of one carbon track of dual potmeter gone bad due to prolonged use.
Jan 28, 2013 | Creative Labs SBS 370 Computer Speakers
Can i use AC Adaptor that has input: 230V-50Hz output: 9VDC to Creative SBS 2.1 370 Speaker?
The Creative SBS 370 Works on 11.5V AC (IT IS NOT DC) 1600mA (Means 1.6 Ampere) and 18.4VA. So, the Power Adaptor which you connect to the power socket behind the woofer is an AC ADAPTOR and NOT A DC ACAPTOR.
Nov 02, 2011 | Creative Labs SBS 370 Computer Speakers
Creative SBS 2.1 370 Speaker. hello how are you today, i have a question regarding the wiring in the volume on and off switch in the Creative SBS 2.1 370 Speaker setup, ive lost the little contoller some...
posted by Sandeep Sharma
hai, Here is the solution. when u cut the PCB from both sides u will find 4 cables i.e. green blue yellow and a copper wire coming from woofer and 3 cables white, red, yellow coming from audio lead. connect the green cable to copper cable and yellow to blue coming from woofer. Now take white cable coming from audio jack.connect this with yellow blue cables of woofer. Now attach Red and Yellow, connect these to green and copper cables of woofer and enjoy. if problem persist then make experiment to make interchanges with red white yellow coming from audio lead to the 2 sections of woofer side. woofer connections green/copper and yellow/blue remain same.
an.astrologer@gmail.com
Aug 30, 2011 | Creative Labs SBS 370 Computer Speakers
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
My spekaer doesnt work.......it is properly connected to the cpu .............speaker problem or OS problem?
check to make sure you are getting power to the speaker system and that the audio jack is plugged into the green jack on your sound card. also open up volume control and make sure its not muted and that it recognizes it. when u turn the volume up if you dont see any green movement on the bar then you have a sound driver issue. go to device manger in xp right click on my computer properties then device manager and see if there is a red or yellow mark on your sound card on vista and win 7 go to my computer then system prop, then device manager.
Mar 14, 2011 | Creative Labs SBS 370 Computer Speakers
Sbs 2.1 370 speaker problem is only when we coonect speker to right side. Left side not working
i have this problem too,sbs 2.1 370 speaker problem is only when we coonect speker to right side. Left side not working
Nov 21, 2010 | Creative Labs SBS 370 Computer Speakers
Creative SBS 2.1 370 Speaker - Volume Remote Controller not worki
Hi Arun!
Try to plug your speakers to an iPod or any MP3 Player to check if there's sound. If there is sound, then try plugging it to the green port at the back of your speakers.
If it doesn't have sounds then you need to buy a new speaker system.
^_^
Jun 05, 2010 | Creative Labs SBS 370 Computer Speakers
NO SOUND
Have you checked on the PC that its not muted.? There is normally an icon at the bottom of the screen which looks like a speaker if you right click on it, it will give an option to open the volume controls. Check this to see if sounds have been muted.
Mar 13, 2010 | Creative Labs SBS 370 Computer Speakers
Remote Control Repair
Open up your controller and look for 4 Wire! Green, light green, blue and yellow! Green and yellow is for power i guest! Light green and blue is for bass. 4 together max everything!
Dec 01, 2008 | Audio Players & Recorders
Creative Labs SBS 370 Computer Speakers Logo
7,021 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
