Question about Watches
I'm trying to take apart this reel in order to clean and oil it. However I'm not able to remove the handles or the spool. Ideas?
I'm trying to take apart the Daiwa Viento fishing reel to clean it out and oil it, however I'm unable to get the reel apart, unable to remove the spool inside. Ideas?
Unless you know exacly what you are doing don't bother. It is a very complicated reel and expremely easy to put back together incorrecly. Send it off to Daiwa Sports service department. It'll either cost you £5 or nothing to have it serviced.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} T: 08450 603603
E: info@daiwasports.co.uk
Posted on Feb 10, 2010
  • Simon Turner Feb 10, 2010
    Hmm, obviously thei site has problems if you copy and past form Word. Thye need to sort that out. Here are the contact deatils for Daiwa Service is plain text:
    T: 08450 603603
Reel winds forwards and backwards. Can't figure why
check you free spinnin clutch for excess drag setting
talk with a rod and reel shop as most are up to date with problems in reels
Jan 21, 2016 | Watches
Luminox Titanium Watch
you set it using the wheel pull it out , it should have two positions, one adjust time the other one date and chronograph, I see if I find full manual.
Aug 03, 2008 | Navy Seal Luminox Watch
Tip
Best Saltwater Spinning Reel for 2016-2017
Now that you know a little bit more about what you're looking for in a saltwater spinning reel, you probably want to know what some of your better options are. So here is a list of ten of the best saltwater spinning reels currently available.
Saltwater Spinning Reel Archives Top Spinning ReelS
on Nov 24, 2016 | Omega Speedmaster Day Date 3520.50.00...
Wrist watch shortening
Look at the inside of the band and there will arrows pointing what direction the to tap the pins out to remove links. Put the watch on a small roll of tape or something similar that keeps the band off the surface you are working on. Gently tap the pin out with a tool that will fit in the pin hole. Remove the pin and determine the number of links to remove. Remove the links and reverse the order in which you took it apart .
Apr 27, 2014 | Citizen Eco-Drive BL006056H Wrist Watch
Smith and wesson sd9 feed problems 16+1
Clean, clean, clean! Probably a little sludge in the extractor or extractor spring. Pull it apart, clean it as if your life may one day depend on it, light oil, re-assemble, test fire, and a final quick clean.
Apr 13, 2014 | Watches
Cannot open bracelet on Bulova 11606355 watch
Try taking your watch to a local watch shop.
If there is something wrong with it, you can only tell by handling it. Alternatively if there is a special way to do it they will probably know it.
Apr 24, 2010 | Bulova Watch
Oil all over wrist watch - can it be cleaned?
hi, if the watch is water proof witch most watches are, if it is it should tell you something on the back like wr 30m or wr 10m if it says this on the back then this is telling you that the watch is water proof up to 10metres or what ever it says if this is the case then you can put it in the sink with only slightly warm soapy water then just rub it over gently with soft cloth whilst under water.
How ever if it says water resistent then this dont mean its water proof this just means its rain proof but not made for going under water unless it says water resistent to 30m then this can be washed in the sink also if it dont say this then you cant put it in the sink you can only wipe over it with a damp cloth to remove as much oil as possible.
But if you can get it clean and its not water proof then the watch is going to have to be taken apart to clean the outer casing that is only if the oil has not got inside the watch.
Oil wont short the watch out put it can cause problems if you have any buttons on the watch so your best bet would be taking it into a watch shop and get it cleaned that way.
Let me know how you get on or if you need further assistance ok
Jan 27, 2010 | Watches
How to remove stem from scotty pocket watch
did you figuer it out because i am having the same problem, i don't want to take apart the balance just to change the and fix the face
Mar 20, 2009 | Watches
Cannot open watch-back says, ''bezel stainless steel back''
Take it to your local jewelry store, they will sell you a battery and install it for you. Watch how they do it for the next time.
May 17, 2017 | Watches
LUMINOX DEAD IN THE WATER!!!
No real way to clean it yourself, you need to take it to a professional who can diassemble it, clean it then reseal...unfortunately that takes tools and the knowledge...dont try at home, if its gotten wet, it WILL need to be taken apart and worked on.
Mar 14, 2008 | Navy Seal Luminox Watch
Watches Logo
521 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
