Question about Linksys Wireless-G Broadband Router
Linksys Wireless-G not connecting to internet
Ok, here is the problem. Two computers in our house are connected to the internet through a Linksys Wireless-G router this router is connected to a Rogers issued SMC router off of the SMC are another two computers, the two computers connected to the SMC are receiving internet fine, the two receiving through the Linksys were recieving internet fine with no problems as well until a couple of days ago.
Now both computers connected to the linksys router get a warning no to low connectivity of the internet, needless to say they no longer have access to the internet but when i disconnect the linksys router from the SMC router and run the computer off this router using the same cable that was connectinf the linksys to the SMC, the internet works fine.
So whats wrong with my linksys wireless-g router? and how can i go about fixing it.
  • 2 more comments
  • macecomics Apr 19, 2009
    The router i'm told is 4-5 years old
  • Steve Rand
    Steve Rand May 11, 2010
    Can you http to the linksys and see what is going on?
  • S. Marusic May 11, 2010
    How old is the Linksys unit? I sounds like you may have to replace the wireless-G unit. Intermittent signal strength is one indication that a router may be on its last legs.
    OpenSource13
  • Anonymous Mar 14, 2014
    mts 3g dongle sopport smc router?
    Problem Solver:
  • 9 Answers
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Posted on May 01, 2009
I am having problems with my Linksys wireless router WRT54G connecting with the internet. When I connect the router to the internet I lose internet connections. Normally it works with the internet, but in...
1. RESET both the modem and router by unplugging them from the wall outlet for 30 seconds.
2. Power them ON again, and after 2 minutes check the connection.
3. If not OK, connect a computer directly to the modem, reset the modem and check the connection after 2 minutes.
4. If not OK, check your cables and if these are OK, call your ISP for your status and line quality.
5. IF OK, check the Powersupply of the router.
Sep 04, 2011 | Linksys Wireless-G WRT54G Router
Trying to run setup wizard on my WRT54G-TM,so i can block other people from borrowing my internet.I have one desk top hooked up and two laptops, works great ,but when i run the wizard disk it tells me...
To test your Internet connection, connect a LAN cable from your computer to the DSL or cable modem and if you can browser the Internet then your Internet connection is OK, then the problem is the LAN cnnection to the Linksys or the Linksys may not configured correctly.
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 21, 2011 | Linksys WRT54G-TM Wireless Router
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
During my linksys install, the software validates my connection and fails everytime. I do not have an adapter on the computer I am installing the software on. This PC has direct cable connection to...
You need to have the router connected directly to the computer to do this setup. If you are directly connected to the internet you cannot communicate with the router and most everything will fail. Remember to set wireless security on the router, give a ssytem name and consider setting channels to 11 or so to not compete with wireless home phones.
Oct 03, 2010 | Linksys Computers & Internet
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect wirelessly
You need to setup cisco page, with your ISP. Your setup name and password must be same for all computers. All computers for this installation must connected by wire at the beginning. And make sure you enable the wireless options on Linksys page. READ HELP form Linksys main page.
Aug 12, 2009 | Linksys Wireless-G WRT54G Router
Wi Fi Connection
Have you tried this: go to bottom task bar and right click on the PC icon. Select "View Available Wireless Networks". Find and select the wireless system you have, i.e., linksys, etc., and click on "connect".
If that doesn't work, use the same method to open the connection options, and click on "repair".
Lastly, if neither of the above works, try rebooting your linksys or whatever wireless system you have, and start over.
Jan 01, 2009 | Dell Latitude D600 Notebook
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
475 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
