Remote is not working.no cooling.makes noisy sound .requires service.
  • 653 Answers
Let's skip over the remote not working for a moment, and go to the problem with the air conditioner. In humid conditions, it is not difficult for the air conditioner coils to ice up, which would account for the noise and lack of cooling. If you are above freezing in your area, which I will assume is the case since you are trying to run your A/C and not your heat pump (if there is one)(not specified in your generic question), turn it off for several hours to give it a chance to thaw out, then switch it back on and see what happens. If the A/C works then, try the remote and see if it works. If not, change out the batteries and see if it works then. If not, then check with the manufacturer to see about a replacement. If the A/C doesn't work after thawing, your compressor may be shot
Posted on Apr 19, 2009
Noisy clutch, spinning sound, intermittent
If it's a rattle type sound it maybe dual mass fly wheel noisy too much play in it, requires replacing!
It also could be release bearing noisy too if it sounds like a wurring noise
Mar 07, 2015 | 1997 Nissan Pickup
When I turn the oven on, there is a fan that comes on that sounds very noisy. It sounds like a vibration in the cooling fan. I'm wondering if simply swapping out the blower would take care of the noise? ...
yes this will work for you, but before you change out the fan motor make certain the fan blades are unobstructed and not rubbing against anything this can make quite a horrible noise as well.
best regards Falco
Nov 04, 2013 | KitchenAid KGRS807SSS Gas Kitchen Range
My Akasa laptop cooling fan has become noisy after a good few years of use. where can i get it serviced
sounds like the bearings are bad in the motors. It would be cheaper to replace unit than fixing it. new fans/motors would cost more.
Aug 05, 2012 | Akasa AK-NBC-01B Notebook cooler Black
I'm referring to the very old beetle engines which didn't need water (older than 30-40 years) Why they were so noisy. Is it their character ? Other than the noise, they were very fuel efficient &...
I use to own a Volkswagen Beetle back in the 70's . I don't remember the engine being noisy. These engines were air cooled and because of their design had a different sound than a conventional engine. If these engines had run for an excessive number of miles they required the valves to be adjusted .Perhaps this is the noise that you are referring to.
Feb 03, 2011 | Volkswagen Beetle Cars & Trucks
GE GSL25IFRF - Noisy, makes wistling sound (Freezer) could it be Fan?
Yes it is the fan. If it is cooling and working ok then I wouldn't worry about it. It may keep working for years (it may go out tomorrow also), but if it is annoying you then replace the fan.
Jul 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
AC PROBLEMS 1996 GRAND MARQUIS
Definately needs inspection and service. Sounds undercharged with refrigerant. Low charge may also cause noisy compressor. Good luck
Jun 13, 2009 | 1996 Mercury Grand Marquis
MAKES NOISE WHEN IT COMES ON
The way you describe it sounds like noisy compressor valves. As long as it is cooling ok, I wouldn't do anything. If you begin to notice cooling problems, your compressor is probably going to give out.
Jun 02, 2009 | Refrigerators
Air Condition
it sounds like a loose compression compressor.
if the compressor is loose compression, normally it sounds noisy. then suction pressure is above normal and if you accelerate and maintains that high speed, let say 2000 rpm, the suction pressure goes down to the normal level and cools your air conditioning .
tnx 4 using fixya...
drcool
Aug 29, 2008 | 2004 Nissan XTerra
Noisy frig
it could be that your cooling fan gets noisy at times and stops for a while you could try to put oil on the shaft behind the fan this will help when it does get noisy pull the fridge kisten to the motor if noisy replace it its not to expencive about 40.00 dollaresthanks from gilles
May 12, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Noisy channel of receiver
Generally, crackling noises come from anyplace there is a mechancial connection for the sound signal. The volume control, main/remote speaker switch and possibly the headphone jack. That is where the contacts must be cleaned, but it requires dissassembly. Try operating the main/remote speaker switches, and plug/unplug a headphone several times. I am assuming there is still audio behind that crackling. Are you using both main and remote speakers simultaneously?
Apr 09, 2008 | Audio Players & Recorders
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
