Question about Magellan Roadmate 760 GPS Receiver
Magellan 760 Unit stopped turning on, but hit a bump and it would turn back on. Got worse, to where it would not turn back on. Took the unit apart, and just seperating the case, got the unit to turn back on. Put the screws back in, and it is good for a day, maybe a week, then won;t power up. Take the back off, move the board, and it will work again for a while. Gotta be something loose, just don't know where to look.
  • 38 Answers
Sounds like your power dock is the culprit, not the internals, you can purchase one from circuit city or tigerdirect.
Posted on Oct 25, 2007
No signal in two units, did reset with magellan tech service, still gets stuck in the same location and no signal
Plug it in, turn it on and let it sit out in the open. If the unit is working at all, it will eventually find and lock onto the satellites. The 760 I'm using now came from California and it took over 2 hours to lock on. When I start a trip now, I let it sit before starting to drive and it locks on in just a few minutes.
Oct 27, 2009 | Magellan Roadmate 760 GPS Receiver
Downloaded map update to Magellan 760 - now the unit will not even power on. What can I do? Carolyn
charge it up for a few hours then press and hold the power button till it powers up
Jul 08, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 map update problem
Just push the antenna firmly back into the base; it pivots on a coax connector.
This is typical when you drop it.
The antenna is removable.
May 24, 2008 | Magellan Roadmate 760 GPS Receiver
Problem with softwear
Warm the unit up. It has an internal hard drive. Very low temps can cause problems.
Jan 27, 2008 | Magellan Roadmate 760 GPS Receiver
Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Dec 29, 2007 | Magellan Roadmate 760 GPS Receiver
Unit will not power up after map update.........
I installed today too. Totally dead, nothing but a backlight blue screen. This is their first update in 2.5 years and it bricked my GPS. You'd think they did it on purpose.
Dec 08, 2007 | Magellan Roadmate 760 GPS Receiver
this is a known issue with the power dock on the back. It needs to be replaced.
Aug 14, 2007 | Magellan Roadmate 760 GPS Receiver
Screen prompt kvt 617p/na
your hideaway unit might be fried, thats what happend to my unit. its the same unit and i had the same message. hope i was able to help. goodluck.
Aug 11, 2007 | Kenwood KVT-617DVD Car DVD Player
Won't Power On Anymore
Works great when it works. They are also know to freeze up. People have reported that it only works up to 6 months then it won't turn on. Even worse, tech support is few and far between and it seems nobody knows how to work on them. You can send it back to the manufacture to have it repaired under warranty, but don't look for it anytime soon. They will hold on to it for months. For me, I use a road map, It never stops working, and its always in the glovebox.
Jun 25, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 won't stay on
U6 is what I think it's called. those cases weren't exactly built around the insides.. (the circuit board).. there's a small IC chip on the backside of that same card with the cradle connect. . more then likely your case has shoved off a tiny little black IC chip. if you open the case and you see a little black peice.. save it. you might have to take apart your unit though. . careful when your opening it as the RF cable will be a hazard as soon as you crack the case.. so open the case just a little bit.. then find that cable I'm talking about.. and just pull it off.. then you can open it without any further restrictions.. If: this small IC chip is the problem, then you either need to solder it back on yourself.. or have someone else do it. So.. if you open the case u pand this isn't the problem let me know.. don't put the unit back together yet. and let me know. _+Daniel
Apr 15, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
143 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
