Question about Panasonic TOUGHBOOK CF-18 Tablet PC
NEEDING NEW PLASTIC COVERS FOR (AC, USB, ETHERNET PORTS) ON MY CF-18
So i have to pay money to get advise..i will ask someone else...wow i thought advise was free, guess not
Posted on Apr 23, 2009
My cf-18 tough book has worn out usb ports
If the USB board is still functioning, you can get a PCIMCIA to USB adaptor (or similar) which will allow you to run usb devices from the card
Jan 14, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
Can I Install Linux via USB Flash Disk for mu Panasonic CF-18, plz help me
Yes, you can do it. I recommend you install Ubuntu Linux. To do this you need the following: 1. Download the distribution from the site www.ubuntu.com/desktop/get-ubuntu/download 2. In paragraph 2 "Burn your CD or create a USB drive" on this page, select "I would like to create a: USB stick " 3. Follow these instructions
May 30, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic toughbook cf 18
You will, at the very least, need to have the screen and screen cover replaced. If the hinges also damaged the bottom case to which they are attached, then it too will need replacing.
If you can't get it repaired locally, let me know.
Jan 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Unable to install OS on Hard drive. Error PXE-E61: Media test failure, check cable. PXE-MOF: Exiting PXE ROM. Invalid partition table
When your computer failed to boot from the disk-drive, it tried to connect to a network-accessible "boot-server" via the Ethernet adapter.
However, if there's no cable connected to the computer's Ethernet port, you will get the "check the cable" error-message.
So, your real problem is "invalid partition table", which means that the very first record on the disk-drive is either missing or corrupt.
That first record contains the "partition table", which lists the size of the hard-drive, and the size of each partition (usually only one) on the hard-drive.
So, you'll need to buy an adapter that has a USB-plug on one end, and a connector for your "SATA" or "IDE" hard-drive at the other end.
Remove the hard-drive from your computer, attach it to the connector, and plug-in the USB connector to a USB port on another computer, and then use software to delete and then reconstruct the partition table.
Or, the hard-drive is failing, and must be replaced (maybe under warranty???).
Oct 22, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Need to disassemble
to remove the keyboard on the cf-18 keyboard you must remove the 4 screwsby the ESC, F4, F10, and PAUSE key. once removed lift the 2 covers and holding the keyboard from Function key sides lift up slowly. There are 4 sticky tapes holding the keyboard, once some of the tapes are off you can slide the keyboard up towards the LCD to remove. The connector to the keyboard can be removed by removing 3 screws from the aluminum center cover found under the keyboard
Jul 17, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic cf 18b toughbook,touch screen do not work,help
goto your device manager and then find your display driver and update it. Dont search for it, manually locate the driver being in the location where you extracted the driver. Then update. and bingo!
Feb 18, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Jan 08, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Usb port not detected
Have the same problem. USB Port broken?
Apr 05, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
334 people viewed this question
Top Panasonic Tablets & eReaders Experts
Michael Galve
Michael Galve
Mike
crveno
crveno
Level 1 Expert
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
