Im running a dell inspiron 530S, only had it for 18 months. The cdrom doesnt recognise blank dvds, only blank cds. Ive never tried blank dvds before so i dont know if it was working and then stopped.
Error message says 'please insert writable disk, there is no disk in drive'. Data discs are fine, only problem is with blank dvds.
I have done every suggestion I can, from rebooting to uninstalling device manager, etc. Nothing has helped.
Please help!!
Comments:
Apr 19, 2009
- Hi
Thanks all for the posts.
Im not terribly pc literate as you can probably guess. I hunted around and found it is a DVD-rom, so I feel like a bit of an idiot!
This is probably going to sound like a stupid question but; Is there anything I can do to make it burn DVDs? have downloaded some freeware called CDburnerXP does this make any difference?
Thanks for any replys
You said in your post "The cdrom doesnt recognise blank dvds". If the drive is truly a cdrom drive, then it will only recognize a blank cd, not a dvd. It could also be a combo drive that READS dvds but does not write them. You may need to upgrade your drive. If your drive is supposed to write dvds, it should say "dvd-rw" or "rw" or "rewriteable" somewhere on it. If it says "dvd-rom" it will only read, not write.
Its only cd writer burner and can only that it can read dvd disc also. That is why its called combo. But burning blank dvd it can't. But if you want buy some dvdburner too.
Comments:
Apr 19, 2009
- None, its not capable of dvd burning.Only cd burning.
You must buy a dvd writer burner must be capable of dual layer burning many of it are also capable of lightscribe burning just choose this specification.
My drive door on my dell inspiron 530 is stuck, i need to add a new monitor, the one i have has lost...
(More)
My drive door on my dell inspiron 530 is stuck, i need to add a new monitor, the one i have has lost its color/no red/ i tried resetting to manufacturers specs...but the drive door is stuck, will not open; can you help, please?
can't turn off the closed caption and smart lock is locked and I don't know passcode, is there a...
(More)
can't turn off the closed caption and smart lock is locked and I don't know passcode, is there a main reset passcode?
I have lost the remote control to my cd/dvd and I can't figure out how to get to the next episode...
(More)
I have lost the remote control to my cd/dvd and I can't figure out how to get to the next episode without the remote.
I have a memorex dvd multi recorder and all DVDs I use are showing as full ,even though I know thery...
(More)
I have a memorex dvd multi recorder and all DVDs I use are showing as full ,even though I know thery are empty. I have attempted to use DVD+RW
I put a lock on some of the channels and I KNOW the pin number I entered was correct.....it will not...
(More)
I put a lock on some of the channels and I KNOW the pin number I entered was correct.....it will not let me unlock it. What can I do??? Thank you so much in advance.....I appreciate your help. I believe the product below is the correct model....I cannot find a model number on the unit but it says on the front panel DVD/VCD/CD-RW/Photo-CD Does this help??
