Wont work on my usb port , but its compatible
I just bought 4 gb ativa high speed usb 2.0 flash drive, i inserted it in the usb port of my pc but its not working
    Problem Solver:
  • 19 Answers
Is you universal serial bus driver installed on your computer properly have you try the usb flash drive in more than one usb hub try that vote for me thanx
Posted on Apr 19, 2009
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
Divice not reconiged
plug it again and if it doesn't work at all try other USB port. A USB flash drive nowadays supports only 2.0 and above USB ports. It all about signal speed a USB 2.0 and above were backward compatible with USB 1.1 .
May 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I bought new hp usb flash drive 4 gb when i go to
you can try getting a flash for your bios to see bigger drives it is probably a size limitation in bios what operating system are using and how old is the computer
May 09, 2010 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
G'Day! I have a Transcend 2 GB USB stick. Whenever I connect it to my computer or any other computer, I get this error message ''THIS USB DEVICE CAN PERFORM FASTER IF YOU CONNNECT IT TO HIGH SPEED USB 2.0...
Yes. The problem is you don't have usb 2.0 ports on your motherboard. Its the second generation usb port. So if you want to upgrade you can buy additional hardware to upgrade this. But your motherboard has to be compatible with that additional peripheral too. As an example buses of your motherboard. So you have to check that also when you purchase. This is not a problem. The only thing is it will reduce the efficiency of your pen drive (Access time etc.). Other usb sticks you have may be usb 1.1 devices.
If this is helpful to you, please rate this .
Thanks.
Jun 15, 2009 | Computers & Internet
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Dear sir, I am having Transcend 2 GB pendrive but when I insert it in my computer, it gives message THIS DEVICE CAN PERFORM FASTER IF U CONNNECT IT TO HIGH SPEED USB 2.0 PORT and its speed is also ver
If you have a USB port on the back of computer plug it in there. Or use USB extension if it is uneasy for you to plug your pen drive from time to time. From there you can hook up your pen drive much easy.
Apr 13, 2009 | Computers & Internet
Flash drive ports on teh fron wont work on pc
If your system is USB 1 rather than USB 2 then some flash drives will not work. Not all usb 2 flashdrives are backwards compatible. My kids flasdrives will only work on my usb2 ports & will not work at all on my wife's computer which has the older usb 1 ports.
Dec 19, 2008 | E-Machines etower 500is PC Desktop
Ativa 1GB flash drive not recognized by Windows
the flash drive has a fat 32 file system you must change it to a NTFS file system.
Right click on my computer. find the drive in device manager. double click it. go to policies. select optimize for performance. click ok. then go disk management.to format the drive and select ntfs in file system. I hope that helps.
Nov 19, 2008 | Computers & Internet
I purchased a western digital 160G external storage device. My computers tell me that it will be slow without a high speed USB port. However, I get a prompt to install software or to insert a disk into...
use windows xp service pack 2 professional
all the ports are then usb 2 .
if this doe not solve the problem change the circuitry of the ext drive on which you mount the hdd
Jul 09, 2008 | Western Digital Passport WDXML800UE...
How to use usb flash drive
connect it on usb hub then scan it with anti virus, sometimes your flash disk will just pop out on your computer then it will play automatically. or or or if u want to save on your usb, just choose the file you want then save it to mycomputer-then E/your flash drive.
hope you understand. :)
Mar 27, 2008 | Computers & Internet
Computers & Internet Logo
232 people viewed this question
David Payne
David Payne
