Question about Sony VAIO VGN-NR360E/T 15.4" Laptop
I was copying some files from my laptopto a Flash drive. an error mesage came. i ignored it. after competing my coping work i tried to shutdown . hoping that i will be able to get rid of the error mesage. But system was not shutting down so i forcefully sut it down . after that when i restarted it aske which mode i have to boot in as i gabve windows normal mode. but since then after booting into windiows vista when it is about display my desktop screen goes black out. I have no idea what to do. please help.
My MacBook Pro OS X 10.9.1 won't read my Lexar Professional 800x 8 GB Compact Flash UDMA 7.
You can try using a file recovery software like Bad Copy Pro 4.10.125. It works well for me.
Jan 20, 2014 | Lexar Electronics - Others
Archos AV700 I/O Error
Offhand, I would suspect that the remaining files were somehow corrupted. Is it possible for you to verify those files using the external HD and a PC?
Either that or the format of the Archos AV700 was not that "clean" and would require a redo.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 15, 2008 | Archos AV700 Digital Media Player
Laptop toshiba satellite Error says FILE INTEGRITY VOILATED,.... i AM UNABLE TO COPY FILES ITS GIVING ERROR
An error mesage makes the computer user aware of functionality possible have compromised the computer systems regular operationalities. For example, the computer expected to be manipolated as requested by the feature manual. A forceful shut down of the computer by pressing firmly on the shutdown button or pulling a plug may cause the computer to display an error message because of an abropt cut in processing requirements. Working with files for example may require to save in appropaiet area on the computer. A data saved at an alternate location that was disconnected liek a disk drive may display error whenever attempting to access an unavailable port area.
Jan 22, 2011 | Computers & Internet
Copied files to a folder on portable harddrive
1. Try creating another folder and coping the content from the original to the new folder on the USB drive.
You may have stopped the coping process inadvertently during the copy process.
Apr 07, 2010 | Toshiba 120GB USB 2.0 Portable External...
Error Copying old c: drive w/Ghost 9
Do a disk defrag on the source drive. If that doesn't work, you may have a virus on your source drive and norton ghost is catching before getting on your destination drive.
Nov 24, 2009 | Symantec Norton Ghost 9.0 for PC
Cannot copy Outlook pst file to flash drive, somethings blocking it
hello
in this case there might be a software installed on your pc that is resticting you to copy that
like point sec is a s/w that will restrict you
in this case what you can do you can uninstall the s/w or bypass the s/w by not typing just ignoring that options
May 24, 2009 | Microsoft Outlook
Some OS files not coping
your CD Rom drives could be dirty if if they are not copying files from the CD's correctly. tipically while installing an OS the CD's are moving alot of data very fast and can encounter errors if drives are dusty or dirty or even if the cd's have small scratches or smudges.
I recommend a CD/DVD drive cleaner disk, or fresh copies of your CD's.
You May also have to replace your drives, you can buy replacements fairly cheap from online retailers such as tigerdirect.com or on auction sites.
Apr 17, 2009 | Computers & Internet
When i insert quickbooks cd and click install it says error need to install flash 7 macromedia.
Depending on the version of QuickBooks you are installing, it may require the flash player for some of it's help functions. Typically, the flash player the program requires is included on the cd.
There can be instances where you already have a later version, but the program is not reognizing it. This may indicate that the Flash registry entries are not in the Windows registry properly, and the Macromedia Flash needs to be reinstalled.
If you have already installed the program once, and the Flash installed, you may get an error message about needing to install, or that it cannot install the files named ************. In this case, you may try ignoring through the message.
If worst comes to worst, explore the cd, copy the Qbooks folder to your desktop. Inside the folder, you will find the Install file and the installation should go through.
Sep 21, 2008 | Intuit QuickBooks: Pro 2005 for PC
Sansa error 0x80070052
code error x080070052 while sending document to flash usb
Feb 11, 2008 | SanDisk Sansa c200 MP3 Player
Sony VAIO VGN-NR360E/T 15.4" Laptop  Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
