have you looked in the owner's manual ? Support LED TV UN40H5203AF Samsung TVs
don't know if this the right one for your set, I think the 40" series all have the same manual. I couldn't download it myself. Also on that webpage you can 'chat' to a Samsung rep. who should be able to give you better directions to the correct instructions
To know more about this, you have to download the repair manual to this set. Its disassemble section will have all details.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
I tried to pull the base stand out - no luck. I tried to wedge a screw driver in - no luck and it looked like the screwdriver could damage the plastic if pushed harder. I finally used a wide metal paint scrapper. It went in where the screwdriver would not go and moved to base enough to allow it to pulled out the rest of the way.
