MSI -K8MM-V VIA K8M800+ VT8237R CHIPSET.
Hi, I have recently purchased a Seagate 250GB SATA Hard disk. I was able to successfully install the hard disk,I USED to use 80GB IDE Hard disk which i upgraded with 250 GB SATA HDDbut not able to detect the new one if i use as slave or Master HDD also,pls suggest me how to resolve this issue on this mother board -----
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
Regards,
Graemevm
First thing, Sata hard drives dont use the Master/Slave setup.
That's only used on IDE drives through jumper settings on the drive itself. For Sata to work correctly all it needs is to be detected or enabled by the bios and set to be the first bootable HDD in the Bios boot menu. While installing Windows XP you will see a prompy very early on in the install process to Push F2 for recovery or push F6 for any additional disk or raid drivers. Push F6 while its shown on the bottom, its only there for 1-2 seconds so make sure you get it quick.
You will need a floppy with the drivers written on it, usually you can get those from a disk that came with the motherboard or from the PC or motherboard manufactuers website (look for SATA drivers and unzip or install them to your floppy.)
Insert the floppy when prompted and it will detect your disk during the Setup part of the windows instalation. If installing Vista or Windows 7 beta you will not need SATA drivers.
MSI -K8MM-V VIA K8M800+ VT8237R CHIPSET.\r\n
Any help here would be greatly appreciated...
Please post here or e-mail me at [email protected]/[email protected]
The suggestion is right the trouble shootih i have done is
* as u said checked with the bios SATA is enabled
* i have one more 4 GB OS installed HDD if i make it as master then i am able to detect it but if i want to make it as master i m able to find the HDD in boot up menue but if i ry to install XP it is giving as no hdd found
* after making the jumper settings i.e making it to work in 1.5GS operation i m able to detec as slave r else i m not able to find aslo. will my mother boad support only that kind slow operaion??????????????
* i have one more 4 GB OS installed HDD if i make it as master then i am able to detect new one i.e SATA HDD it but if i want to make SATA HDD as master i m not able to find the HDD in boot up menu aslo if i try to install XP it is giving as no hdd found
* after making the jumper settings i.e making it to work in 1.5GS operation i m able to detect as slave will my mother boad support only that kind slow operaion??????????????
*over all request is i want to install OS in the new SATA HDD and make that as master
*------------------------i want to know how to reply to ur comment after i get the reply there is no other option in the page so that i can reply to ur comments directly so that i m reporting as " i have the same problem" pls assist me---------------------
AS in the screen shot i can detect as slave but not as master
pls assist me regarding
Thanks in Adv
Naresh
sata hdd is not detecting
It's not being detected while trying to install windows or in windows in my computer?
