I bought an acer aspire 5610z and when i turned it on the screen stays black. can you tell me whats going on or what i can do to solve this problem i have a acer 6930 and the light when i close my laptop wont turn off unless its turned ff or on sleep mode? how do i turn that off
You could have a defective screen - follow this to determine the fault.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
im sorry its not the back light.
but when i close it there is a little lite when i close it
it lights up the acer and that will not turn off unless its turned off or on sleep mode
