Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Whirlpool Dishwasher acting as if there is no power to it
The dishwasher stopped running during a cycle and acts as if there is no power. I already checked the CB and the power cables in the circut box of the dishwasher and there is power to it. I have also shorted out each on of the switched on the handle and they both seem to be operating correctly. Any Ideas
  • 7 more comments
  • Anonymous Nov 28, 2007
    I have a whirlpool DU1055XTPS3 and will not start the start button once in a while would give trouble to start now is stop lighting and not working at allplease hepl anyone. Thanks Yvette
  • drbp Dec 23, 2007
    My whirlpool Gold is doing the same thing. It's as if a fuze has blown in the dishwasher and there isn't power to anything. I can't figure this out. I've looked for loose connections, joy
  • Anonymous Mar 07, 2008
    my whirlpool dishwasher seems to have no power, it stopped in the middle of a cycle, between wash and rinse, i still have water in it, breaker is not thrown, is there a reset botton hidden some where, du912pfggo is the model #
  • Anonymous Mar 22, 2008
    No power on dishwasher
  • Anonymous May 05, 2008
    Whirlpool dishwasher was going through cycle then stopped with no power. Still has water in it. Have checked circuit breaker. Is there a reset button or solution?
  • mikepiac Aug 31, 2008
    Whirlpool dishwasher DU1055XTPS3 acts as if no power. Still has water in it from last cycle. Circuit breaker is fine and I’ve verified power is getting to the dishwasher’s junction box; and no short within. Door appears to close and latch fine. Is there a fuse, or reset button? Anyone able to offer a diagnosis and/or solution? Also, good way to drain water other than shop-vac???
  • Anonymous Aug 31, 2008
    no power
  • Irritated26 Nov 22, 2008
    Did anyone have a solution for this?
  • egmidior Jan 25, 2009
    i have a whirlpool gold quiet partner IV and it doesnt turn on. it was working fine a few days ago and it simply wont run. ive checked the electrical socket to which the dishwasher is plugged to and it has power. i checked the outdoor fuse box and the breaker is fine. i've read on a few boards to check the fuse in the junction box. but where is it? please help!
I had this problem just two days ago. For me it was the thermal fuse. On my dishwasher it is located on the main control board, at the top. It is white and has two wires going into to separate terminals. It says "Microtemp" on it. I used a small wire to short it and see if that was the case. Be careful though. There is also another fuse on the bottom of the dishwasher that looks like a little black cylinder with a silver cap, and two terminals coming out of it for wires. In our case that fuse was fine.
Posted on Jul 07, 2010
  • 734 Answers
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
Posted on Dec 02, 2008
I have smeg built in dishwasher. Acts like running cycle but i don't think it's getting enough water. the soap tables are not dissoved. before if opened door during cycle lots of water but now none
Check water inlet filter, check for blockage at the stop valve .
The rubber washer does come loose and blocks/limits the flow into the dishwasher. The fill cycle is on a timer and any restrictions in the water connection will under-fill the unit.
Hope this helps?
Jun 24, 2017 | Smeg Dishwashers
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner 2 stopped running
my whirlpool has power to it but no lights and will not start, replaced micr computer still will not start Water in bottom as if it quit during a cycle
Oct 17, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
Sep 22, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
Is the right cycle selected? Refer to the “Cycle Selection
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Cycles won't run
dc, sounds more like a shorted interface, a shorted keypad will act like this. There should be a tech sheet behind the toe panel on the bottom. It should have instructions on how to test the keypad and put the unit into the test cycle. back.
Nov 14, 2006 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
5,128 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
