Question about Proscan PS36500 36" TV
Weight of TV
We have a ProScan 36" 36500 model TV and would like to know the approx. weight of it for purposes of buying a TV stand
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Near about 75 kg.
Posted on Sep 19, 2007
SOURCE:
Measurements of hisence 50 inch 4K tv
From Best Buy's site I found this 50" 4k HiSense TV
http://www.bestbuy.com/site/hisense-50-class-49-5-diag--led-2160p-smart-4k-ultra-hd-tv-with-high-dynamic-range-black/4982500.p?skuId=4982500
With the following dimensions listed:
  • Product Height With Stand 27.7 inches
  • Product Depth With Stand 9.7 inches
  • Product Height Without Stand 25.6 inches
  • Product Depth Without Stand 3.3 inches
  • Product Weight With Stand 28.2 pounds
  • Product Weight Without Stand 27.6 pounds
  • Width 44.1 inches
Apr 03, 2017 | Televison & Video
How do I find out the weight of my 42LC2DB television for a wall bracket
If its not on the paperwork get your bath scale have some one hold tv and stand on scale. note weight put down tv back on scale note weight and subtract,
I am assuming it's not a 60 inch, if so maybe 2 people and 2 scales
mike
Feb 19, 2016 | Televison & Video
I am shipping my tv to my new location, need to know the weight
Which model TV do you have?
The TVs in the LD-325 line are 14.55 pounds with the stand, but is 13.45 lbs without. If you have the original shipping container and all the accessories, the LD-3255VX weighed 21.83 lbs. The LD-3255AR is 23.2 lbs in the box.
The EW32S3PW with the stand is 15 pounds and 1.5 pounds lighter without the stand.
The older model SK-32H640G is 23.9 pounds with the stand. Removing the stand takes 1.4 lbs off the TV weight. When in the original box with accessories, the TV weighed 27.0 pounds.
There are a number of other models, so please add a comment with the model number and if the stand and accessories are going to be in the same box. I hope this gives you some help.
Nov 10, 2012 | Westinghouse 32" Flat Panel LCD HDTV
How much does this model weigh? I want to buy a tv stand weight limit states it holds a 100 lb tv tops?
A 46 inch Sony LCD FlatScreen tv weighs around 90 pounds.
If you look in your own tv's user manual it will tell you its weight in the DIMENSIONS section.
Feb 06, 2011 | Televison & Video
I AM BUYING A NEW TV STAND AND I NEED TO FIND OUT THE WEIGHT OF MY SAMSUNG TV?. MODEL LE40A456C2DXXU
The most basic details of the new Samsung LE40R74BD LCD TV include its weight and dimensions and both make this new model of phone very much attractive. This device has a weight of 22.8 Kg, a height of 71.3 cm, a width of 99.1 cm and a depth of 32.6 cm making it very compact and manageable. The black colour of this model of LCD TV has made its looks very much attractive as well as impressive.
Hope this solution is helpful?
Sep 26, 2010 | Televison & Video
Trying to find a tv stand for this tv. what is the weight of the tv
  • Dimensions: 29" H, 30 1/8" W, 22 1/2" D
  • Approx. Shipping Weight: 120 Lbs. I would get a stand that gives you some extra capacity for safety. Measure the base of the TV so you know the dimensions of the sets "footprint" to know the dimensions you need for the stands shelf to accomodate the set. Good luck
  • Nov 25, 2009 | RCA F32648 32" TV
    How much does a 39 inch flat screen olevia tv typically weigh?
    I couldn't find a 39" Olevia TV, but I did find 37" ones and they weight a little over 50 pounds. You can find the weight for your specific model at www.olevia.com. Select the series and then click "View Full Specifications" on your model. Then click the Specifications tab and go down to Other. Gross weight should be the weight when packaged, and Net weight should be the weight of the TV by itself.
    Mar 21, 2009 | Televison & Video
    TV weight
    The trick to lifting Large TVs' is that they are very 'front' heavy, that is, most of the weight is in the picture tube...recall the "problem" of unstable TVs' from years ago (Children pulling down TVs')
    If the TV is on the floor you can put a large pillow at the front (Picture tube face) on the floor & carefully tip the set forward onto the pillow. You can then measure the bottom of the set to see if it will fit on your stand. If you are concerned about the weight simply attempt to sit your body (180 lbs?) on your suspect stand..if it holds your weight your good...wiggle around to see how stable it is.
    _________________________________________________Rick......
    May 24, 2008 | Televison & Video
    Weight
    I have one of these TVs and still love it.  The manual says that the weight is listed at 250lbs (approx.).  Most of the TV stands in retail stores only hold up to 240lbs., so that is something to consider.
    Sep 23, 2007 | Mitsubishi CS-40503 TV
    Proscan PS36500 36" TV Logo
    202 people viewed this question
    Top Proscan Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Jaime Hernandez
    Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
