Question about Lexmark X1270 All-In-One InkJet Printer
MY PRINTER WILL NOT PRINT BECAUSE THE SPOOL ISN'T RUNNING
    Scholar:
  • 68 Answers
First check all your connection I am asuming its usb. Remove and insert the connections from the computer and also from the printer.Try it again. If this does not work then pull the power on your printer for a few minutes then plug back in.If you are still not getting any results then unhook your USB port for your printer and use add remove programs to remove the firmware drivers for your printer. Reboot your computer. Then install the firmware according to what the manufacture recomends. Usually is insert cd rom let load then hook up USB but they are all diffrent so pay attention to how they recomend to install your printer. These steps should get your printer going agian for you.
Posted on Sep 19, 2007
Printer write as javascipt
I presume you are using the Lexmark X1270 inkjet printer since you're posting under this model.
It could be that the printer driver on your computer is not properly installed. Try to uninstall your existing printer driver then reinstall using the X1270 driver on the Lexmark website. To uninstall, from your computer, go to Start menu > Programs > Lexmark X1200 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.
When the computer turns on, please visit the Lexmark website to download and install the Lexmark X1270 XP Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Try to print your document again to verify that the problem is fixed now.
Nov 22, 2011 | Lexmark X1270 All-In-One InkJet Printer
CONFIG: Lexmark x1270 on Windows 7 (upgraded from Vista) PROBLEM: Every time after printing one job, the printer refuses to print any other job. Checking the printer roperties reveals that the first...
This could be a printer driver issue. Uninstall the existing Lexmark X1270 printer driver on your computer. Please follow steps below:
  1. Go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 1200 Series folder.
  4. Go to Tools.
  5. Click Uninstall.
  6. After the uninstall process, reboot pc when prompted.
When your pc turns on, check if it's running on 32-bit or 64-bit operating system. Go to Start menu > right-click on Computer > click Properties. Take note of the System Type.
Use the links below to download the printer driver: - Lexmark X1270 Driver for Microsoft Windows 7 32-bit - Lexmark X1270 Driver for Microsoft Windows 7 64-bit
Aug 11, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270, installed on new Dell, will scan/print once but print queue won't clear after printing, and further jobs just back up in queue. Once, after trying reboot, printed next doc but that was...
Try to follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Aug 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
Spooler is not connected
i gues you getting a massage that print spool services not started ....... if its right go to start then run type services.msc press enter then go to print spool double click on that and start the service .......and try to print
Dec 16, 2009 | Lexmark X1270 All-In-One InkJet Printer
Vista Printer problems - Printer not printing Test page or docs
You may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 1200 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
May 14, 2009 | Lexmark X1270 All-In-One InkJet Printer
Printing document from computer
Regardless of the application, open the document, click File, then click Print and select the printer. If the printer is not listed it needs to be installed on the computer.
Dec 07, 2008 | Lexmark X1270 All-In-One InkJet Printer
Local print spooler
I dont have a driver x1270 to my windows vista please helpmy
Oct 05, 2007 | Lexmark X1270 All-In-One InkJet Printer
Printer
click start and click on run.. Then type services.msc. Then click OK. search for Print spooler, double click on it and set it to automatic under startup type and click on start. Click apply and Ok if got the message saysing "started"... Then try printing. If u got any error message or if are not able to start. Then try clicking on Start and click on run.. delete the services.msc and type sc config spooler depend= rpcss and click ok. Then try starting the spooler again. Do as mentioned in the first paragraph.
Sep 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
