Question about Hitachi 50UX26B/27K 50" Rear Projection Television
TV Will Not Turn On
I am experiencing the exact same problem as 'david-d' had with the tv not turning on and the light on the front not coming on either. Same click sound "on" and "off". The red light inside does come on but flickers. This problem started by the tv just shutting off for no reason from time to time, but could be turned back on. Now it won't come on at all. I guess the response from 'LOFATT' solved the problem for 'david-d', but I'm not that educated in this field. I didn't quite understand his solution. If anyone, or 'LOFATT', could please break it down for me so I could understand it better, I sure would appreciate it. Thanks,
  • cevera_29 May 11, 2010
    I am experiencing the exact same problem as 'david-d' had with the tv not turning on and the light on the front not coming on either. Their is no click sound "on" and "off". The red light inside does come on.
  • 927 Answers
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Posted on Sep 06, 2008
SOURCE:
DLP tv will turn on (picture looks fine) then after a minute TV will turn off. Sounds like its trying to come back on for a couple of seconds, then I start to hear a buzzing sound for a minute, then it...
Hi Karen,
It sounds like the color wheel of your unit gone to malfunction and trigger that kind of symptoms. It needs to check by a qualified TV Technician because this kind of symptoms is not a DIY unless you have an experienced in electronics. If the buzzing sound came in front of the lamp assembly, then high chance that the color wheel is already faulty. Lamp, ballast board, fans are also a suspect here.
Have a nice day!
Jdvillanueva
Nov 16, 2011 | Samsung HL-T6156WX 61 in. TV
No picture or sound, flashing standby light, will not turn on
sounds like powwersupply issue. repair is usually reasonable from reputable repair shop. id say around 150 - 250
Jun 02, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Hpc lcd flat panel not coming on
sounds like a flyback problem part cost is around $70.00
Dec 06, 2008 | Samsung PS42P2S 42 in. Plasma Television
Lg 32lcd2d (tv won't turn on)
It is most likely the power supply. If you see domed caps change them using a higher voltage cap. If it's 1000uf at 15vdc put in a 1000uf at 25 or 35 vdc. If this helps let me know.
Sep 27, 2008 | LG 32LX1D 32 in. LCD Television
LG 32lcd2d
Sounds like your cable is off or your not on chan 3 . Can you go to setup and find cable , air ect ? And see if that does anything ? Check all your coaz and hdmi and make sure they are tight as well
Jun 25, 2017 | LG 32LX1D 32 in. LCD Television
TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Sep 18, 2008 | Toshiba 42H81 42" Rear Projection...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
I bought a Toshiba 42'' plasma TV exactly 1 year ago. The model, as per the hand book, is 42PD6600 A. About 8 weeks ago I began experiencing some problems to turn on the TV, i.e. the red light (stand...
maybe your ac cable has a lost contact thats why when you wiggle it it will turn on. just replace your power cable first before you are going to troubleshoot the other problem.
regards,
janex
Apr 22, 2008 | Televison & Video
TV wont power on, clicking noise and flashing standby led
Sounds pretty bad to me, I had a computer monitor that did a similar thing when plugged in after blowing, it's not a good thing. I didn't even bother to mess with it. You may have to replace the whole power board or at least have a whole handful of pieces to re-solder. It most likely isn't worth it unless your other tv's are under 30" and you don't have a lot of money ;)
- Dave
Dec 28, 2007 | JVC AV-32D305 32" TV
Open Questions:
Televison & Video Logo
47 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
