Question about Kodak EasyShare C613 Digital Camera
Using timer
Using timer
    Scholar:
  • 62 Answers
Changing picture-taking settings
You can change settings to get the best results from your camera.
1Press the Menu button.
2Press to highlight a setting, then press OK.
3Choose an option, then press OK.
■Press the Menu button to exit the menu.
NOTE: To better understand each menu option, use camera Help. Highlight a menu choice, then press the button. Some settings remain until you change them; others, until you change modes or turn off the camera. Some modes offer limited settings.Press Menu, , and OK to access settings
Options
Self-timer
10 seconds (default)—
so you have time to get into the scene.
2 seconds—
for a steady, auto-shutter release on a tripod.
2-shot—
one picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
Exposure Compensation
Increase or decrease brightness before taking a picture. (Also see page 27.)
0.0, -0.5, -1.0, -1.5, -2.0, +0.5, +1.0, +1.5, +2.0
From: http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00711/C613_UG_GLB_en.pdf
If this helps, please post a rating for me. Thanks!
OpenSource13
Posted on Apr 19, 2009
My woods digital timer is acting weird. I take the timer off the outlet and set the timer like normal. The display is doing everything I want it too at this point. But then, as soon as I plug it into...
Copy following link to identify timer and see Woods (Coleman) warranty support link
http://waterheatertimer.org/Woods-timers-and-manuals.html
Buy another timer.
Reset timer using reset button.
Check if timer has batteries. Older timers had batteries. Newer timers have internal rechargeable batteries.
Try on different outlet.
Check outlet polarity using circuit analyzer.
Timers are made to last 1-3 years, some more some less.
Jun 18, 2013 | Hardware & Accessories
How to ground a Tork EW103B time switch wired for 240Volt since there is no ground lug in the plastic housing or on the body of the timer itself
Many plastic timer enclosures do not have ground screw.
Simply join the ground wires inside wiring space using wire nut.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#ew
Since the timer mechanism is plastic, it is non-conductive.
It's like using all-plastic electric drill. The drill does not have ground wire because the electrical components are housed completely in non-conductive plastic.
You can buy the Tork 9000A metal Nema3R enclosure if grounding is preferred. Or buy Intermatic 2T511GA metal Nema3R enclosure plus buy Tork IAP adapter to fit Intermatic enclosures.
Choose the metal enclosures when conduit needs to be supported and timer could be hit by some object.
The non-grounded box and non-grounded timer is also true of GE digital timers 15132 and 15136. Which coincidentally have same wiring as EW103 when using 240Volt.
http://waterheatertimer.org/How-to-wire-GE-15132-timer.html
However the Tork DTU40 timer has ground screw >>> but the timer is not grounded, so ground screw is merely for joining wires together.
http://waterheatertimer.org/images/IMG_2232-Tork-DTU-timer-600.jpg
Jul 31, 2012 | TORK Hardware & Accessories
Timer has been programmed but will not go on or off automaticvally. Has a new battery and the red light is on. I have to use the breaker to turn the pump on and off????
You posted under Intermatic PB300 series timer module.
http://waterheatertimer.org/pdf/Catelog-146-PB300.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM
Failure after battery replacement is common complaint about timers.
Chance to restore functionality is to reset timer.
Reset PB300 timer using round reset button on far right side.
If functionality is not restored, then timer has gone bad.
Order new timer module using information on back of timer, and take photo of wiring so new timer can be wired easily.
Jul 18, 2011 | Intermatic Panel Mount 24-hour Electronic...
I need to know how to reset the timer
If you reset ST01C timer using reset button, then all programs are lost, plus current time of day.
Generally this timer needs to be reset if error message appears and as last resort for troubleshooting problem. Timer does not need to be reset after battery goes bad, all you do is set current time of day, and then program remain inside timer indefinitely (or until timer is reset of goes bad)
If setting current time of day does not work, you use reset button.
For ez programming steps with illustrations:
http://waterheatertimer.org/ST01C-program.html
How to reset ST01C using reset button:
Push and hold ON-OFF button and then push reset button using toothpick or paperclip.
Release reset button but keep holding ON-OFF button until INIT displays.
Then release ON-OFF and 12:00 should be flashing.
If timer functionality does not restore, then try replacing timer battery.
If functionality will not restore, then timer is bad.
This timer does not need electric current for setting timer, so timer display is not dependent on circuit breaker.
If you have a different timer, then add a comment with in-focus photo of timer for possible identification. Most other timers do not require 2-button reset procedure.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 23, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have A Time All Model TB 211 and need to learn how to set the time with the pins. Have no manual. Using for my Xmas lites, on and off. Outdoor use.
There are two 2 basic types for mechanical timers: Pins and segments
geno_3245_149.jpgTimer pins flip in and out using fingernail.
geno_3245_150.jpg Timer segments lift up using small tool or fingernail
geno_3245_151.jpg Sometimes segments pull outward away from center
To check timer functions after setting pins or segments, manually rotate dial to and watch lights turn on and off.
Dec 07, 2010 | RTO Intermatic #HB51RC Photo On/Off Out...
I have sony DSC-S500 digital camera i want to know how to take a photograph using self timer thank you Regards Sailaja
For capturing the images using Self Timer, press the Down Arrow control button continuously to select the desired mode. You can set the timer for 10 seconds and 2 seconds by pressing the continuously, If we press the button again the Self Timer will be turned off.
Press the Shutter button, the self-timer lamp flashes and a beep sounds until the shutter operates. To cancel the self-timer, press the down arrow button again. You can redice the risk of blur by using the 2-second delay self-timer.
Good Luck!
KenSolutions
Oct 30, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
How to use the timer on a sony cyber shot 7.2mp digital camera
On your Cyber-shot DSC-W55 locate the control button:
32864f9.jpg Using the self-timer
Press cd9ebdc.jpg on the control button repeatedly until the desired mode is selected.
Conditions of the self-timer lamp:
(No indicator): Not using the self-timer
fc274e6.jpg: Setting the 10-second delay self-timer (picture is taken after 10 seconds)
996d00d.jpg: Setting the 2-second delay self-timer (picture is taken after 2 seconds)
Press the shutter button, the self-timer lamp flashes, and a beep sounds until the shutter operates.
Hope this helps.
Thank you.
Oct 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Do I turn the faucet on fully?
Yes, when using an inline water timer, it does not control the pressure of the water, only the "on/off" of the pressure. So make sure to keep the faucet at the pressure you want the drip system set at as if you weren't even using a timer.
Jul 19, 2009 | Garden
Using timer on Columbia watch
Try using your mode button to get to the "ST" screen. To start the timer, hit your st/stp button. To stop your timer, use the same button. To reset the timer, hit "reset". Hope this helps.
Mar 13, 2009 | Columbia All Sport Digital watch
Kenmore dryer timer will not turn.
Bad timer motor if you are using timed dry.
If using auto dry probably a bad sensor.
Verify by using any time dry or air fluff cycle and see if the timer moves.
Mar 03, 2009 | Kenmore 64902 Electric Dryer
Kodak EasyShare C613 Digital Camera Logo
96 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
