Question about HP Computers & Internet
How to get to recovery partition when booting up HP Pavillion MX
My friend has a HP Pavillion MX 70. They have a virus or something of the sort that will not allow you to do anything in windows xp. It won't even boot in safe mode nor can I get to the dos prompt. I assume there is a recovery partition since they have all the cds but no recovery disk. How do I get to the recovery partition when booting up the computer?
The same problem happened to me today on my hp Pavillion a1600n.
Try pressing the F10 key as the computer is powering on. This may allow the computer to access the recovery partition on the hard disk. If you get that far, then you can restore the user partition from the recovery partition. If it is like the a1600n, then you can do a restore of all the content and either leave your own data files intact, or, have it reformat the user partition and then you WILL have to restore all the data files. In either case, you will likely need to reinstall any applications that were added AFTER you got the PC. (Or, in my case, some apps were still kinda working...).
If F10 does not work, you may be able to create a PC Recovery Tools CD from a different hp XP machine, and boot that CD. During part of that boot up process you may get the opportunity to run the Recovery program.
Hope that helps!
Posted on Apr 19, 2009
Resting hp pavillion dv6000
If your laptop has a recovery partition then -
HP recoverypartition - press F11
For details on HP Backup andrecovery Managergo to this WEB site -
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809678&lc=en&cc=us&dlc=en&product=18703
Jul 13, 2012 | HP Pavilion Computers & Internet
Need to run HP PC System Recovery on Pavillion a775c. Files corrupted - fixing this older computer for a friend. No virus protection. Only one user account (the administrator). Cannot start any program...
One way but its drastic, you could replace the Hard Drive. It makes me think that it might be the hard drive because windows cannot boot from the drive. Its pretty easy to replace a hard drive, then run the system recovery disc.
Jun 07, 2011 | HP Pavilion a775c (A775CB) PC Desktop
Trying to install windows 7 retail 64 bit on Scorpio (was installed once already started getting wonky so decided to format reinstall) boot with usb dvd rom drive get to unpacking of windows files and...
According to Microsoft, Windows 7 must be installed on a primary partition. This error code means the installer hasn't found a primary partition on the target drive. The primary partition must be on the first hard drive in the boot order, and if you have more than one user partition (not counting the small drive table partition), you must install to the first user partition. Unfortunately MS doesn't seem to have a clear, comprehensive answer to the issue. I've gleaned the following from various forum responses.
For some reason the installer is date sensitive, so make sure the time and date are correct in the BIOS. Time your next install attempt so it will NOT go past midnight during the installation.
Check your BIOS settings to make sure the drive is listed as a "primary" drive (drive 0, not drive 1) rather than a secondary.
Some people have had problems with the Windows 7 installer on drives that have the Master Boot Record from previous installations. Try a FORMAT /MBR using the Windows 7 install CD. If this doesn't work,
  1. Use the partition command to remove the target partition from the drive to wipe this out
  2. Partition the now unused space and reformat (again!), and
  3. If the partition command or installer has an option to set a partition as primary (or something else), choose primary (disk 0) for the partition you want to use for Windows 7.
If all else fails, use your HP Software Recovery CD to do a complete repartition and reformat. You could use the Windows 7 partition command to do the same thing, but then you would lose the HP System Recovery partition. However, if HP is marking the System Recovery partition as partition 0, it could be causing the problem. In that case, see if HP has an updated version of the CD that includes a fix for this, or do without it and turn it all over to Windows 7.
Dec 26, 2010 | Western Digital WD Scorpio Black...
Due to a virus and boot up loop, I have completed a PC Recovery on a Compaq Presario with Windows XP SP 2. The hard drive now has a partition with C maintaining my old files and PR (D) the recovery...
I would back up my data then delete both partitons and format as one drive.. Thats what I would do.. But dont do this unless you have a copy Vista or XP on CD.. The install files for your system are on your hard drive..
Dec 13, 2009 | HP Compaq Presario SR2020NX PC Desktop
Hp pavillion zv6000 no disks need full restore...
Yes, the recovery partition is 100% true, and I've actually used it to repair a lot of systems, simply because it saves you time, stress and energy.
It is always on a smaller partition on your hard disk, and it is also hidden, so you wont see it.
To use the recovery partiton, you have first of all take note that you must backup ALL your documents first, because the use of the recovery partition will Actually format your harddrives and restore your system back to the factory settings, i.e the way you bought it.
Now, provided your own recovery partition is still intact and not yet corrupt, this is how to use it.
When you power up your system, Keep tapping the F11 key, i.e the F11 function key.
This will invoke the command that boots up your recovery parttion and lets your system boot from it.
Thereafter, you can just follow the on-screen instructions to complete the recovery, and again PLEASE remember to backup ALL your necessary documents first.
Hope this helps you out.
Goodluck
Jul 10, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I have a HP Pavillion 533w..a friend of mine was using the computer and decide to go to Local D drive and clicked on format...well i have no recovery disk and of course the system recovery will not work i...
You can take the drive out of the computer and connect it to another computer to see if there is any data on it. If there isn't, you MAY be able to have the drive unformatted professionally, but buying a new computer would be cheaper. If there is data on the drive you have other options, depending on what that data is. It could be as simple as making another partition bootable.
Apr 30, 2009 | HP Computers & Internet
F11 problem
Means you don't have Restore patrician on the Hard Drive.
Did you replace or reformat hard drive after you purchased it?
Mar 27, 2009 | HP Pavilion dv9000z Notebook
Dont like vista so I let my nephew take vista off of my Pavilion notebook...not good idea..want to put vista back on but it seems I was suppose to create recovery discs. Can recovery discs be downloaded...
check to see if there is a recovery partition first, to do this press F8 on boot up, if you have no boot partition then you have to go out and buy a OEM copy of vista
regards
Nov 16, 2008 | HP Computers & Internet
My computer has alot of viruses and i need to reformat.(i would guess) but i do not have my master disc or drivers .. please help
HP PC's usually have a recovery partition on them that will allow you to restore the PC to the initial setup.
Make sure you have backed up all your data before you start.
Reboot the PC. As it starts you will be offered the option to boot from the recovery partition. If it does not then select the option that allows you to choose the boot device. Then you will be offered the recovery partition.
You will be guided through the process of restoring the PC.
BEWARE!!! IT MAY DELETE ALL YOUR DATA!!! BACK IT UP BEFORE YOU START!!!
Oct 05, 2008 | HP Computers & Internet
Computers & Internet Logo
1,177 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
