Question about Toshiba TheaterWide 46HM94 46" Rear Projection HDTV
HDMI ports are not working
My 57inch Toshiba Model: 56HM66 TVs HDMI ports are not working for some reason. im trying to get My PS3 to work through it and its not picking it up...what do i do?
  • 41 Answers
Try using the cables that were included with your PS3, (yellow, red, white) when you see your PS3 on that input. Plug in the HDMI cable. There should be something saying that an HDMI is detected and if you want to use it. Check the HDMI input on the TV and see if you see anything. The other thing that you might want to do is do a firmware update on the PS3. sometimes there are compatibility issues with HDMI
Posted on Apr 19, 2009
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
My hdmi plug in the playstation does not work i have set the playstation to hd but it dont work ive tried to cables and to diffrent tvs
Solution
Remove SCART leads, plug in HDMI from PS3 to TV HDMI 1 port.
Now......
Turn OFF TV, turn OFF PS3
Wait 15 seconds
Turn on TV
Press and Hold PS3 On switch until it has completed one recycle.
Now wait 2 secs and you should get the handshake and connection.
Jul 15, 2010 | Sony Playstation 3 (PS3) Console
How do i change from 480i to 1080 on my Toshiba 52HM95 DLP im trying to hook up my playstation 3 with an HDMI cable but it wont switch over to 1080i
Most TVs choose the resolution based on the signal coming in. Be careful if you try and use 1080P. Not all TVs support it. 1080P is only on HDMI. set the playstation to 1080i before connection.
Some TVs and Playstation HDMI do not mix well due to software in the HDMI ports. Try RGB cables.
Apr 02, 2010 | Toshiba 52HM95 52" HDTV Projection...
PS3 hdmi only working on some displays
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
My Toshiba 57H84 has stopped picking up my PS3 through HDMI
try holding your finger on the power button(next to disc eject) for 5 secs
May 24, 2009 | Sony PlayStation® 3 (60 GB) Console
HDMI PORT STOPPED WORKING!!
the best option here is connect via a standard PS2 avi cable or componet cable until your tech guy comes out!
Apr 30, 2009 | Televison & Video
NO sound on HDMI3 port and when playing Blu-Ray DVD's the screen is pink
Go to the samsung website, and find out how to upgrade the firmware for your TV. You will probably need a portable usb memory stick to do so (if your TV is equipped with one). HDMI is an evolving technology, and firmware upgrades can resolve many of these quirky issues.
Here's a possibility from http://www.samsung.com/us/support/faqs/supportFaqList.do?group=&type=&subtype=&model_nm=LN-S4696D&dType=D&mType=UM&vType=R&prd_ia_cd=02010100&acc_ia_fl=&disp_nm=LN-S4696D
Which Samsung LCD TVs Have The HDMI 1.3 Interface? spacer.gif Of the LN-T series Samsung LCD TVs, those models whose last two digits are 61, 65, 66, 69, 71, or 81 (for example, LN-T4071F or LN-T466F) have the HDMI 1.3 interface.
Samsung LCD TVs with HDMI 1.3 interfaces also have HDMI-CEC (HDMI - Consumer Electronics Control). For information about CEC, click HERE.
For information about individual Samsung LCD TVs with HDMI 1.3 interfaces and HDMI-CEC, click HERE. When the Samsung LCD TV web page appears, select the TV model you want information about by clicking the drop down list under Product Finder on the left side of the page.
Though other series of Samsung LCD TVs (LN-R, LN-S, etc.) have HDMI connections, none have models with the HDMI 1.3 interface.
Feb 18, 2008 | Televison & Video
Toshiba TheaterWide 46HM94 46" Rear Projection HDTV Logo
679 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
