Internet will not connect through dial up
Bought new dell inspirion 530 and can't log on to the internet through dialup connection.
  • Richard Camp
    Richard Camp May 11, 2010
    Have you configured the modem connection and the network setting correctly? Have you been given a phone number to call by your ISP to dial with the modem? You have the proper login and password for the connection? What OS are you using? Does it say the modem is working correctly under, control panel, system, hardware settings? Good luck, RAC
  • 53 Answers
Check the basics...RJ11 connected to pc, username and password reentered, restore IE settings in internet options. Check dialup number is correct and that dialup modem has no issues in the pcs device manager. Not much more can go wrong with dial up as it's such a simple service.
Posted on Jul 28, 2009
CAN'T GET TO CHANGE DIALUP SETTING
To make sure settings are not set up to dial go to internet options and click on connections and make sure nothing is in that box. If there is something delete it. Once you check this go to network connections in control panel and make sure there are no dial up connections. If any just delete it. Hope this helps.
May 06, 2010 | Dell Dimension 3000 PC Desktop
Pl give step wise procedure to connect 6030 to internet via Dial
1. You need a means of connection from your cell phone to your computer or laptop (inferred,bluetooth or data cable), a dialup connection, your proxey settings
steps to connect internet with mobile phone to PC.
Step 1:Take your gprs enabled cell phone and connect it to your computer or laptop using either buletooth,infered or a usb cable.
Step 2:Create a dial up connection.Go into yor control panel,then into internet options.Then go to connections and add.Create a dial up connection and when it asks for a phone number type in *99#
Step 3:On your new dialup connection add the same proxy address you have on your gprs in your cell phone.
Step 4:Now on your cpanel there should be something called modem options here you must change the APN to whatever your APN is on yor gprs in your phone.
Step 5:Go to start menu and connect,then connect to your dial up (make sure your cell phone is connected to your computer or laptop)
Step 6:Start your browser (internet exploxer,opera etc) and start surfing the net.
Mar 09, 2010 | Nokia 6030 Cellular Phone
Broken network card??..
What model Dell do you have example..(Inspirion 530) post it back here and I will help locate the correct driver for it
Oct 11, 2009 | Dell Ethernet Card Network Adapter
Wireless issues with my Dell XPS/Dimension One desktop
Even if it's a new Dell, you may need to update either the drivers for the wireless card or the BIOS.
Also, verify which protocol your Dell is set to use (i.e. 802.11g, 802.11b, auto-select, etc.). Dell may have fixed to to a slower protocol for compatibility.
May 02, 2009 | Dell XPS One Desktop
How d o I dial the Username and Password From this router.
If you have a dialup internet connection the router can not directly help you, because the device that you are using for dialup (your PC) needs to first dial up your ISP using the telephone and then once connected it will use PPP to setup the IP Connection, at that point your within the PPP stack it will send your Password and Username. When that is all done you have connectivity. The router assumes that your connection by nature is either DHCP or PPPoE, not PPP or SLIP as with a dial up connection
What you need is a device that has dialup capibilities, and an internal PPP stack to allow for connectivity to the ISP while allowing for a connition to the router. This can be done by connecting one of your PCs (with Internet sharing enabled) to the internet via dialup and using a second ethernet connection to your router, then from the router you can connect your other PCs.
This method involves setting up two different subnets so here is a suggestion:
1) On the PC set the ethernet LAN facing connection to an IP Address of 192.168.10.100, netmask to 255.255.255.0, Gateway to 192.168.10.1 no DNS
2) On the router set the WAN IP Address to 192.168.10.1 and the DNS to the DNS provided by the ISP.
3) On the router facing the LAN (your network) set the IP Address to 192.168.1.1 and thell the router to act like a DHCP server.
This way you will be able to connect your PCs to the router and have it serve as a permanent connection to the PC which will still have to dial out but you can send a periodic ping sequence to keep the Internet connection up. and connfiguer auto-dial if the connection goes down.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 16, 2009 | NetGear WGR614 Wireless Router
Cannot connect to the internet
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router on this pc or if you briefly used it.
Aug 18, 2008 | Dell Wireless 2350 Router
Use a wired router for dial-up (NETZERO) connection..
You want to use a LAN with a router that uses a dial-up as a backbone internet connection for your LAN.
This is absolutely possible.
If you just want to share the connection that one computer has, and dont want to buy a router that has a built-in modem, try this
If you are running windows, There is a feature called Internet Connection Sharing (ICS.) It will share the dialup across the network.
Just 1 hookup the router and all the pcs to it. 2 Dialup the machine with the modem. 3 Enable ICS on that machine. 4 Youre LAN is online.
In XP, goto the network connections, and while you have 2 active connections in there (the dialup and the LAN port connected to the router), right click the dialup, goto properties. goto advanced tab, and click on enable ICS.
The other computers should be served IP's automatically and NAT'd out to the internet by the computer running ICS.
(The other computers should be automatically setup to the internet like they should be and connected to the dialup riunning on the ICS (host) computer)
May 16, 2008 | Linksys (R) RT41P2-AT 4-Port Wired Router...
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
