Question about Sharp AR-5316 Advanced Digital Imager Copier
How to put developer(black) into copier - Sharp AR-5316 Advanced Digital Imager Copier
    New Friend:
  • 91 Answers
1. Open the front panel
2. Pull out the toner cartridge
3. Unscrew the blue screw that fixed the developing unit to machine base
4. Pull out the developing unit
5. Unscrew two screws above the developing unit and one in the bottom middle.
6. Take out the toner cartridge housing
7. Pour the developer
8. Reverse these steps to re assembly the developing unit.
9. Turn on the machine
10. Execute developer calibration, follow these steps :
[#] [INTERUPT] [C] [INTERUPT] [25] [START] [2] [START]
11. Wait until the calibration finished and
12 Press [CA]
Posted on Apr 20, 2009
K M c654e black imaging unit. Was taken out and put back in. Either says wrong unit replace with right one. Or when it accepts it as right one it prints only about a third of paper. Blank on rest.
While putting Imaging Unit inside the machine, make sure the contact/chip area is actuating/hitting properly to the contact assy on the body of machine.
Here Black IU has two part- Black Drum and Black Developing Unit. I think only contact of pins causing problem.
At Frond side of drum unit below is Chip.
and same corresponding to developing unit u can find 3 pins assy.
while closing contact should be proper.
Dec 08, 2016 | Konica Minolta bizhub Office Equipment &...
My dell printer 5100cn , print quality very light, replaced inks drum and still having problem with black
laser printers have a high freq high voltage wire that puts ions on the paper as it passes ,
have you cleaned this wire . it attracts dirt an inks like the paper it treats.
there is a wire cleaning tool in the machine usually.
Jan 04, 2015 | Dell 5100cn Laser Printer
Bizhub c6500 c2454
Black developing unit fault, has the black developer been replaced? Was it replaced correctly, with required counters cleared and proper test run after install? Was who ever installed new developer using a vacuum cleaner? If so might have destroyed the sensor located below the developer unit. (NEVER EVER USE A VACUUM CLEANER TO REMOVE DEVELOPER STATIC ELECTRICTY can destroy the ATDC (Automatic Toner Density Control) sensor. Toner mixes with the developer, on any Developer unit. So could have a bad sensor or control board. As for the counters if the developer was replaced but counters not properly cleared then copier thinks the developer is old and will adjust voltage as required when in fact new developer is installed and messing with image issues. KONICAMINOLTA PRODUCTION PRINT MACHINES USE THOSE COUNTERS!!!!!!!!!
Oct 07, 2013 | Minolta C250 Color Copier
Where we can buy toshiba studio 230 developer?
677864645f7a396c54674d71464b78424b4677-100x100-0-0.jpg Toshiba E-STUDIO 163 202l Developer Black
New Genuine Original D2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $88.21ExtraMileToner
at
GenuineBrandSupplies.com
New Genuine Original D-2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $65.33
Oct 21, 2011 | Toshiba e-Studio163 Copier
Ricoh afficio 1045 & ricoh 450 toner is mixed in ricoh fw 780 now background and negative image is coming what can i do plz give some idea
firstly you need to remove the developer and vacume the developer unit and magnetic developer roller.
Put in new developer and correct toner in toner unit.
Call service...
After replacement there is a sequence wich needs to be done, for developer initialization.
Aug 16, 2011 | Ricoh FW 780 Black and White Copier
I have white horizontal lines through the text when printing A4 portrait. What can I do to solve this?
Look at your black development unit, if you see a white band on the development roller, remove the development unit, shake it and turn the gear of the development roller ...
Jun 01, 2011 | Ricoh Aficio 1224C Black and White Copier
I' ve a problem with copier ar 5516. i need information about using of developer. where i must to put the developer? the toner AR-021FT IS COMPATIBLE WITH THIS COPIER?
yes ar021FT toner compatible for your 5516. when replacing the developer:1) pull out the toner cartridge,2) pull out developing unit with 1 screw (blue),3) in developing unit remove 2 screws (blue) to open its top cover,4) drain d unit and replesnish with new developer. do procedure 4 to 1 to return. Good luck.
May 22, 2011 | Sharp AR-5320 Black and White Copier
Canon 7130 black and white copier. It looks like it is scanning but blank pages come out. I changed the toner and nothing. There are no alarms. also can this machine still be bought?
**** open the copier to see if the developer has fallen away from the drum unit or is the tab below where the toner is put in out of place. Sometimes, if out of place, when the copier closed shut the arm is moved to the right side of the post ( located on the lower half of the copier ) and move the developer away from the drum unit and produces light copiers or even blank copies.
May 17, 2011 | Canon NP 7130 Black and White Copier
How to put developer(black) into copier how to enter thes functions please... i must enter in expert mode before entering codes...
Hello sir; This model copier, the developer come with toner cartridge, you don't have developer replacement problem.
May 26, 2009 | Sharp AR-5316 Advanced Digital Imager...
Blank Copies
The Unit where you've put the toner cartridge could be to far from the drum. Make sure your developer unit (unit where you've put the cartridge in) is locked in place.
Mar 14, 2008 | Canon NP 7130 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
482 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
