Question about Gigabyte GA-K8VM800M Motherboard
After format hard disc, my pc no sound. Actually i don't have audio driver for my computer. PLS help.....
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    What is the Brand and Model of your PC?
Hi reboot in to bios and look up realtek ac'97 audio driver and enable it i had the same problem when installing windows, hope this works.
Posted on May 01, 2009
  • 326 Answers
Please visit this site and select which Version of Windows you are using in the "Please Choose OS" drop-down menu at the bottom. This will bring you to the drivers page for the motherboard that you posted your question under.
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1919#anchor_os
Posted on Apr 19, 2009
My touchmate computer audio is not work after formatting why?
after a fresh install you will nedd to set up your audio again
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if you don have the disk you will need to download the drivers
there are a few freeware driver solutions on the web
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
hope this helps you
Apr 04, 2012 | Western Digital WD1600AAJS) 160 GB SATA II...
Cant able to uninstall avg free 8.5..pls help it
I think that it had stucked on your computer.You can uninstall your avg anti virus by using its installation driver disc.First you put the disc on your cd drive and then avg install/uninstall shed will appear.now you can uninstall your avg.if you don`t have the disc then format your computer.that`s the only solution.
Sep 17, 2011 | Computers & Internet
There's no audio on my pc.i'm trying to download an audio driver.pls help
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 23, 2011 | Computers & Internet
I reformatted my pc..and wen i turned it on.. i've got no audio..pls help.. thanx..
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
don
Feb 12, 2011 | E-Machines eMachines Desktop PC
After formatting my pc i hear no sound pls help
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 24, 2010 | Computers & Internet
I can't hear the sound after formatting the computer
Hi dear,
1- You have formated the the hard disc and install OS again.
Therefore
you have to install AUDIO (sound) driver.
you can use audio driver disk or motherboard disk which was come with motherboard.
or you can install sound driver from the internet.
Thanks
Veeru
May 07, 2009 | Compaq Audio card Sound Card
Audio sound
actually the sound driver is not supporting properly just reload the sound drivers.if you dont have your sound card drivers.just insert your sound card number in the google website you will get the drivers in a minute.just download the exact card driver which you have and after downloading the driver install it in your pc. and then check out it wiull work properly.also check out that the head phone pins are connected in proper sockets of the pc.
Feb 26, 2009 | HP Compaq Presario v3000z Notebook
Looking for pi945gcm audio & video drive
PLZ GIVE ME THE DOWNLOAD OF MOTHERBOARD DRIVERS OF PI945GCM
Jan 20, 2009 | Mercury P4VM800M7 Motherboard
Sound card
After you formatted your computer
the Sound card's drivers  were also formatted what you will have to do is to reistall all the drivers for the PC
if you cannot find your driver  could you please  post the mother board type
like "intel 965" ,945  etc
and i would  be able to  tell you your sond card drivers .
Nov 09, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Sound not coming out from the center OR the rear speakers
To play soud ...it needs sound driver... which comes in mother board cd..
Sometimes it happens... No sound....then that case, RESTART u'r system... if problem persist then install audio driver once again from u'r mother board cd...
Avoid loose connection..... Power on!!!! Off... of sound system in the middle of use of u'r PC.
Dec 27, 2007 | Logitech X-530 Computer Speakers
Gigabyte GA-K8VM800M Motherboard Logo
203 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
