Question about Toshiba Satellite M45-S359 Notebook
Wireless adapter fails to negotiate with a secure modem
I was told that this may be caused by the wireless adapter being out of position and needs to be removed and then reseated.
Where can I find the adapter and how do I accomplish the R&R of the adapter.
Thanks,
Don
  • 1 more comment
  • Don  Farrell
    Don Farrell Apr 19, 2009
    Good morning (?) Rcampsr. With respect to your questions:
    1) Yes, it has worked for 4+ years. Problem started when Verizon
    accidentally deleted my network connection. It took them
    a full week to find and correct the failure.
    It is Verizon that is maintaining that this failure is the laptop, not
    their modem.
    2) Home wireless connection.
    3) No, I'm retired. I'd really like to find a job, I need the rest.
    4) The Verizon Modem is about 20 feet behind me. It is a Westell
    327 Modem.
    5) Yes, WEP is enabled. I cannot connect to my secure network
    even though the broadcast is seen by my laptop. If I disable
    WEP, I can connect to the network via the modem.
    6) Yes, all internal test indicate the the wireless adapter are
    functioning properly.
    FYI the OS is Win XP SP3. Is there anywhere online where I can get a copy of the component placement map with the locations of the CRUs and FRUs?
    FYI - I use a grounding strap to the frame on anything electrical I work on.
  • Don  Farrell
    Yes it is DSL service.
    I direct connected to the modem/router and removed the WEP security so that I can at least get a decent signal level.
    I also did a rather simple test, I disabled the wireless and updated the modem. First I set the WEP to equal OFF. Access was perfect while I was attached via hard-wire.
    Access was also fine via the wireless without the Wep. (I disconnected the hard-wire) Then I re-enabled the WEP on the laptop and verified the WEP password. One log-on was successful.
    I move the laptop to the adjacent room and tried to log on to no avail. I went back to the hard-wire an changed the wireless to no WEP, went back to the same room and logged on just fine, without the WEP.
    So the failure does seem to be isolated to the WEP negotiation whenever a password is sent back and forth.
    I'd really like to take a hammer to the modem and fine tune it until it is dust, but that would solve nothing.
    Are you sure that the problem is my laptop and not the modem?
    I will pull the memory SIMMS and look for the wireless adapter under them.
    I do thank you for your help.
    Don
  • Richard Camp
    Richard Camp May 11, 2010
    Hi Don, there can be many reasons for a wireless adaptor to not negotiate a connection. The first question is, did it work before? Are you using a home wireless connection or one that is at a remote location? Are you trying to get wireless access at work? Where is the access point located in relation to the notebook? Are you using wireless security? Does the OS say the adapter is operating correctly? a little more information would be helpful.
    For your information the wireless adapter is located in the bottom of the laptop behind one of the removable doors towards the back of the laptop. The only problem is you may have to remove some other hardware to access the wireless adapter, i.e.: video, modem, lan, memory, etc. and risk the problem of static discharge, adapter not reengaging correctly when replaced, etc.. Each laptop manufacturer uses different locations for their hardware. Good Luck, RAC
    Novelist:
  • 90 Answers
Ok, It looks like you have a DSL connection for your internet service. The problem you are having is that you are missing the WEP key inorder to connect to the modem with a secure link. The Modem has to be set to use WEP security and then there are a number of security keys that can added for security. Your modem is not configured for WEP, otherwise you would not be able to connect to it with no security.
You will have to read the information and access the modems setup features to enter the keys. You may have to go to the manufacturers web site and download the manual from it. If Verizon does not give you access to the modem for adjustment then you may need to have them setup the wep and email you the keys so you may copy and paste them into your connection configuration. Depending on the security level of the modem the longer the key the more secure. Some modems use a transmit key and a receive key in order to make the connection more secure. I would also check the modem and see if it has any options for WPA security, which are much better than the WEP. On any computer that connects to the network you have to create the connection with the WEP key or keys. If the modem uses these different keys then you have to match them. Say the modem WEP key is X to transmit and Y to receive, then the computers WEP would be set to Y to transmit and X to receive. The keys are also case sensitive numbers and letters, and the longer the better for network security. The manual will tell you the allowable maximum length you can use for the key. You can use the same key for transmit and receive if you wish to make it easier on you, but it all boils down to the type of security you programmed into the modem.
Read the owners manual for the modem and then you will have an idea what and how to get the two wireless connections to talk securely to each other. Currently your system is wide open and anyone can log on to your system without security, even the next door neighbor. Good Luck, RAC
Posted on Apr 19, 2009
  • Richard Camp
    Richard Camp Apr 19, 2009
    I would get a program off the internet called Netstumbler. It will allow you to see what the signal strength is in the other room. The WEP should just slow down the signal slightly in data speed but should have no effect on the strength of the signal. When you turned the WEP back on in the modem, you also set the WEP key string/password to the same one as the computer was using. XP has a mind of its own when it comes to negotinating connections and it is important to insure the key is set. You need to physically make sure the keys are the same in both units and any other computers that are using the wireless connection. It has to be set exactly the same in both. Does the wireless modem have a WPA option in it? This is much better than WEP for security, or is it too old a unit for it? RAC
Netgear adaptor won't recognize 2wire 420
If you wish to unlock this Huawei E960 password.... Call +2347035041294... Skype: mickyhandsome2010
Oct 17, 2013 | NetGear WNCE4004 IEEE 802.11n 450 Mbps...
Tip
Avoid factors that cause interfrence on the wireless connection.
If you are facing wireless interference on the wireless connection and have already tried resetting and changing wireless channel on the routers and the issue still persists then please check the factors that could cause wireless interference.
The factors you need to check:
1) Make sure that the router is sitting on a wooden desk. If it is sitting on any metallic surface or on top of your Monitor or CPU, please remove it and then keep it on a wooden or glass surface.
2) Some modems may create interference with the router. So it is always advice able that you place your router at least 3 feet away from the modem.
3) Since Your router is having internal antennas, the transmission capability of your router can be increased if your router is mounted vertically rather than keeping it horizontally.
4) Similarly, Make sure that the wireless adapter in your wireless computer is positioned in such a way that it can receive wireless signals generated from the router without any disturbances. If your wireless adapter is hiding inside any enclosed surface you can position it properly.
5) Similarly if you have a cordless phone operating at 2.4 Ghz, It will definitely interfere with the wireless signals generated from the router. Make sure that you keep your cordless phone away from the router or other wireless devices or you can even switch off the phone for sometime for testing purpose.
6) Also try disabling the personal firewalls in your computer like Mcafee, Norton Internet security, Spy ware, Zone alarm etc.
Hope this information allows you to resolve the issue.
on Feb 10, 2010 | Computers & Internet
Brought a new laptop with wireless installed have a philips SNB5600 but have lost the security key how can i get the code
go to the wireless access point admin settings (not on your wireless adapter on your laptop). then check wireless security settings. if you see something there such as security key, that is the security key that you need to set up on your laptop. if security key is not visible, try to see if there is an option there which says unmask to show the security key, then copy it to your laptop. if all else fails, change the security key in the wireless access point and change all the wireless adapters that connect to it accordingly to the new security key you set it up.
Nov 07, 2009 | Computers & Internet
How to secure my d-link wireless adapter with my Arris 550a modem
To make your wireless router secure you need to use your browser and type in the router's IP configuration address.
Then you need to change the default Admin password,
change SSID and turn off SSID broadcast,
setup the encryption (use WAP or WAP2 if your wireless card supports WAP) if not use WEP 128 bit encryption
and for added protection use MAC address filtering.
Apr 15, 2009 | Arris Touchstone 450a (CM450) Modem
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Xbox 360 wireless adapter not connecting 2 pc
u need a wireless router linsky is about the best out there
Sep 20, 2008 | Microsoft Wireless Network Adapter Xbox...
Westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Aug 20, 2008 | Westell Wirespeed VersaLink...
Need Ethernet port on PC
If you have a wireless router then the ethernet cable will go between the modem and the router. Then you need a wireless LAN card to connect the PC to the router
What model router and modem do you have?
PC wireless card
Jul 03, 2008 | D-Link DFE-530TX+ Fast Ethernet PCI...
My wireless Encore adapter is a 802.11g
If you are using Windows XP, In the lower right hand side there is a blinking tray icon that looks like a computer with waves coming from it, double click it and you will see "signal strength" with green bars. If your wireless adapter is internal, you may have to move the wireless router until you get a better signal on your computer. Try putting it somewhere up high with no large metal or concrete objects between it and your computer. If your adapter is external USB, move it around until the signal improves and try to secure it in that position. Hope this helps.
Jun 26, 2008 | Encore Computers & Internet
Wireless adapter ......need something compatible with a siemens router
you probably need another router such as linksys, netgear, belkin.. etc.
Nov 10, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Toshiba Satellite M45-S359 Notebook Logo
156 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
