Question about Panasonic Lumix DMC-LZ2 Digital Camera
No image on the display, no image captured when photo taken.
The camera worked perfectly until last week, when the camera would not show an image on the screen. When I took a 'photo', no image was captured. The photos that had already been captured in the camera could be brought up, it is just the taking of new photos.I had changed the battery with no change. I tried to troubleshoot but had no success. I reviewed the settings, but found no problem there. Any ideas?
  • Mr Question Nov 27, 2007
    Camera (Lumix dmc-lz2) worked fine. Went to use it the next day and then no image on the display. The menu works fine though. Found that when the camera is squeezed together the images do appear. I opened it, wiggled wires, put it back together and still can only see images when squeezed. Any solutions? This camera is only two years old. Feel ripped off.
  • deepakgarg Nov 30, 2007
    i can see all images taken on screen..but no new image is been taken by it..its all blank..
"Comment by TerryB, posted on Oct 13, 2007 - Thanks!"
After calling the Service Center and explaining this problem, they said it sounded like an internal shutter problem and would have to be sent to them and approx $160.00, I was thinking it might be better to buy a new one.
Then I tried TerryB solution and it WORKED!
Thankyou so much, we'll be able to get photo's of the kids opening Christmas gifts this year.
PS very disappointed in the Service Center phone number - seems like they were going to try to rip me off!
Posted on Dec 11, 2007
I had the same problem and I just fixed it myself!
I: (1) removed the six screws from the camera; (2) opened it up; (3) simply jiggled the orange ribbon cable; (4) made sure the internal plug-in was in tight; and (5) closed the camera and put the screws back in.  As soon as I turned it on, IT WORKED!!!
Good luck!!
P.S.  I found this solution somewhere on this Fixya.com site, but I can't relocate it.  THANK YOU to whomever posted it!!
BTW, I originally took the camera to the camera store and they told me they would have to send it away for repair, and that I was looking at anywhere between $100-150 to fix.
~CameraGirl!
Posted on Oct 13, 2007
  • TerryB Oct 13, 2007
    Good luck!!
    ~CameraGirl!
I took it into a repair shop for an evaluation. They stated that it wasn't a setting problem, but a hardware problem. It would cost a minimum of $135 & about 2 months to repair. I chose to toss it & buy a new camera for about $226.
Posted on Oct 09, 2007
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
Camera won't show the image on the screen when taking the pictures. I have to use the small view finder to take photos. No image on the display until the photo is taken. How do you sqitch it back to the...
You don't. The D40 works as SLRs have worked for half a century. Only more recent dSLRs (Nikon started with the D3 and D300) have the LiveView capability that lets you handle your dSLR as a point&shoot.
Jun 11, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Black Screen on Canon PowerShot SD750
Probably bad CCD. !!! Check if there is possibility of free of charge repair !!! Many models are repaired free with CCD broken, even warranty time is passed.
Sep 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Cant capture photos as the screen does not display image.
May be issue is with Display LED..Please contact nearest service center...Check for the Warranty for free service
Thanks
May 31, 2009 | Olympus FE-20 Digital Camera
Camera had beer spilled over it. Not much but enough to stop it working. I took it to a camera repair shop in Vitnam, The guy said he could fix it and went to work on it, when i got it back it worked...
which model camera have you got? you listed in Fuji F470 but your last piece in you description says F47fd. I can offer help either way but please clarify.
Thanks
Mar 08, 2009 | Fuji FinePix F470 Digital Camera
Black screen, not capturing photos
have the same problem...
it happened about a month ago and i pressed the display button and it worked, but now that doesn't work either!
Jul 22, 2008 | Canon PowerShot SD1000 Digital Camera
Problems with sony cyber-shot dsc-t20
Kindly initialize your camera from menu and camera will starts with factory default settings.
May 27, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Problem with display being white...but!
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 13, 2008 | Canon PowerShot A60 Digital Camera
Canon eos digital canon rebel xti - LCD won't work when shooting
Most DSLR cameras (like your Canon) don't have a live view - in other words, you can't "see" the image before you capture it. You must use the viewfinder.
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
LCD not showing view of image to be taken
Nikon Techical Support the quickly this is a CCD or associated component failure
Jul 22, 2007 | Nikon CoolPix S2 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
77 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
