Question about Onkyo Audio Players & Recorders
I am having a problem with ONKYO HT-s6100. It keeps shutting off and going into standby mode when ever I turn it on
    Brigadier General:
  • 8,619 Answers
Hi
Please try and check the power cable if its plugged into the power socket firmly. Also try connecting it with a diffrent wall socket. Sometimes receivers go into 'protect' mode and shut themselves off if the speaker terminals are shorted. It only takes 1 small strand of copper bridging between the black and red posts to cause this to happen.You have to check all the speaker connections behind the receiver and behind each speaker wires at the amp 6-8 ohm is ok for 8 ohm speakers.
If the speakers are also fine then check whether it is overheating, as heat can cause the reciever to turn off. If it is overheating then the amp protection circuit has been activated.Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and set the volume to maximum. If the AV receiver stays on, set the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord and get it repaired as the power supply circuit is overheating due to faulty components.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 19, 2009
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
I have an Onkyo HT-S6100 home theater not sending picture to TV.
I just fixed mine with the same problem. Apparently, the HT-R667 and 606 receiver that comes with 6100 has a problem with the HDMI board. Onkyo wanted $500 dollars to fix it, costed me $16. Here's how to fix it. http://www.highdefforum.com/high-definition-receivers-recorders-players-tivos/121956-repairing-onkyo-htr667-aka-606-a.html
and the youtube vid: http://www.youtube.com/watch?v=gj0x5S9ez5U
Good Luck!
Apr 04, 2010 | Onkyo TX-SR605 Receiver
I have just installed a HT-S6100 at home and works perfectly with a Blue Ray Samsung player (via HDMI). I also have a Sony DVD player with component cables I want to connect to my HT-S6100. I followed the...
There seems to be a lot of this type of lack of signal (video, audio or both) with this system. I have the same system and the same problem. Mine is working now. I'm using all HDMI connections. I think the other important thing to do is "delete" all Input Assignments that are not being used. By "delete" I mean set the Input Assignments to "----". Let me know if this helps.
Dec 14, 2009 | Onkyo HT-S5100 Theater System
My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Dec 04, 2009 | Onkyo TX-SR501 Receiver
Onkyo HT-S6100. Receiver says NO SIGNAL and so
I have the same exact unit and same exact problem. Any luck yet?
Oct 16, 2009 | Onkyo Audio Players & Recorders
Receiver keeps turning on and off also the standby mode blinks
The receiver is going into "protect" mode. This means that a problem has been detected and the unit shut down to prevent further damage. Without seeing the unit and taking some internal measurements, it is difficult to provide a complete solution. Typically, the output transistors fail which can cause this. There are other possibilities too. I would suggest that you get a detailed repair estimate from a local shop. With that information, we may be able to walk you through the actual repair.
Dan
Oct 15, 2009 | Onkyo TX-SR604 Receiver
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
HT-R510 home theater system
If bought new return immediately for replacement. The amp section is no good and cannot be reset - needs repair. but you are under WARRANTY - use it.
Sep 06, 2017 | Onkyo HT-S490 System
101 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
