Question about Xerox 5100 Copier
Xerox WorkCentre M15i, 1" streak/smudge on left edge.
This copier worked perfectly until I changed the toner. Now I have this problem. Did I expose the drum to light too long when changing the toner? Or is there some cleaning I can do to fix? Thank you.
  • webor99 Apr 22, 2009
    Does this mean I have to replace the drum unit? Is there some cleaning that I could do myself? I was thinking I dirtied the unit somewhat as I shaked the old toner and try it several times before replacing it with a genuine new Xerox toner. Thanks again for any help posted.
    Sniper:
  • 67 Answers
It's probably coincidence, the problem is probably your drum unit, and it probably had nothing to do with being exposed to the light unless you had it out in direct sunlight, regular indoor lighting will not hurt the drum.
Posted on Apr 21, 2009
  • hinderschied Apr 22, 2009
    You can pull out the toner and pull out the drum, then look into the empty cavity and see if there is any build up of spilt toner, if so wipe it up with a dry cloth. I always use a vacuum and a brush, but the toner is such a fine powder it will go right thru most vacuum filters. The tranfer roller can cause that type of problem if any foreign substance came in contact with it. that is the black foam roller in the side door, you can roll it and clean it with a lint free rag , like an old sheet. I also believe in your maintenance menu you have a command to replace or clean the drum. You can try that also, but as the copies are being made the cleaning blade in the drum unit is always cleaning the drum. If none of this works the yes replace the drum unit.
    Good luck
    Bob
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
MAYBE YOU HAVENT SHOOK THE TONER PROPERLY.OR A FAULTY TONER
Posted on Nov 30, 2009
My M15i Xerox Workcentre is printing with a vertical line down the page
Solutions for : Vertical Black Lines on Copies When the Automatic Document Feeder and Document Glass are Used Solution : Clean the Drum
  1. Make sure there is paper loaded in the paper tray.
  2. Press the [Menu / Exit] button on the Control Panel.
  3. Press the [Up] or [Down] arrow button until 'Maintenance' is displayed on the Display Screen.
  4. Press the [Enter] button. 'Clean Drum' will be displayed.
  5. Press the [Enter] button. 'Cleaning Drum Please Wait' will be displayed and a sheet of paper will be printed. Toner (Dry Ink) particles on the Drum will be affixed to the paper.
  6. Repeat steps 1 - 5 until the page prints without any Toner particles.
Aug 13, 2011 | Xerox WorkCentre M15i Laser Printer
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
We have a workcentre M15i connected to a vista computer. We want to print from a xp computer to the workcentre. The xp only sees the workcentre if the vista computer is turned on. How do we get the xp...
We put a usb cable from the xp computer to the workcentre. We left the Vista computer connected to the workcentre via parallel cable. Not the solution we were hoping for but it does enable us to print from both computers
Apr 14, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox scan to network
What is the model number? That is not a fault on an M15 which this question is listed under. Have you checked your LDAP settings to see if something there has changed?
Mar 13, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox WorkCentre M15i squeals when printing and copying.
Do not only lubricate metal shafts, but promptly lubricate the "pulleys" on the right and left side.  the will look very similar to a wheek and pulley mechanism.  The squeal happens when one "bar" connects two "wheels" and one side moves faster than the other.
Jan 23, 2009 | Xerox WorkCentre M15i Laser Printer
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Ink toner problem?
No, that is not the ink, That is a fuser problem.
The fuser needs to be replaced.
It is a very easy repacement. Cost is between 170-200 dollars if you don't have a service agreement.
One of the two rollers in the fuser has a problem and is not making good enough contact to fuse the image.
Jan 10, 2008 | Xerox WorkCentre M15i Laser Printer
Xerox 5100 Copier Logo
381 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
