Question about Sony HT-DDW790 System
Sony HT-DDW795 low volume problems
My surround sound system plays cd's just fine and loud but when you play a dvd the maximum volume is much much lower any suggestions? Also the FM tuner is plenty loud.
  • 3 more comments
  • CobraMustang Nov 18, 2007
    Ive got the same problem. Just set it up today and it plays cd's and dvd's just fine, but when i wanna listen to tv, its way too quiet even at maximum volume
  • Tbone68 Nov 29, 2007
    My volume is way low, I can not hear a thing until the volume is in the mid 40 range and then Max is just about OK. IS this normal for this model or is something wrong?
  • Anonymous Jun 03, 2008
    HI, AM THINKING OF BUYING ONE, THINKING OF THE CONS/PROS OF TH IS ITEM.
  • Anonymous Jul 16, 2008
    I have this problem as well. It didn't used to be a problem when I used a multiplexer, but just using the remote to switch to DVD and eliminating the multiplexer is so much easier. But when I want to listen to music, I set the volume to Max yet I can barely hear it in any room other than the room the stereo is in.
  • Anonymous Apr 27, 2009
    Same issue here hope sony has an answer
SOURCE:
welcomejee
  • 10594 Answers
SOURCE: Sony DVD Home theatre system
lets perform special reset function in your home theater.
1= set to stand-by mode
2= press three buttons of "Stand-by, Function & Volume- " all togather.
3= you will see "Cold Reset" message on front display of set.
4= power up and enjoy ;)
Posted on May 28, 2008
quang123
  • 107 Answers
SOURCE: Tuner Hum on Sony HT-DDW740
Check electrolytic capacitor C899 100uF 35V in STBY PCB
Cheers
Posted on Dec 02, 2008
  • 3 Answers
SOURCE: Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Posted on Jan 03, 2009
SOURCE: How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
Posted on Jan 07, 2009
SOURCE: Cannot turn TV off when playing CD's with samsung HT-X810R/LG50PG
Problem traced to Samsung's Anynet+ System interacting with LG's Simplink. They seem to be
compatible. Cured by Menu/Option/Simplink/OFF. Hope this helps with anyone else having this problem. trev6.
Posted on Jan 10, 2009
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
Some of my speakers arn't playing sound on my HT-E555OW
If you are trying to play a cd, you must manually tell the unit to play it in surround sound. Cd audio defaults to stereo only. Does it do the same thing if you are playing a dvd? If it happens on dvd's as well, then something in the speaker setup menu is wrong.
Dec 25, 2012 | Shure Samsung Ht-E5550 3D Home Cinema...
Volume issues
The connections are inappropriate.re check the cable connections.
Jul 05, 2009 | Sony HT-DDW790 System
Volume is Always Low when playing DVDs
i may try to change other DVD player software..........see if any change
Dec 25, 2008 | HP Pavilion dv2000t Notebook
How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Mar 04, 2008 | Panasonic SC-HT680 System
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Oct 16, 2007 | Sony DAV-FC8 System
Low volume
Hi federmagico If you have not clean the lens do so now if that does not work call a tech the problem could be the lens.good luck.
Apr 25, 2007 | Sony HT-DDW670 System
Crackling from surrond sound
I have a SONY home theater4.gif system, HT-C800DP, there is a crackling sound when playing DVDs - it is almost as if the unit overheats. Is there any solution to this? Sometimes I cannot even finish a DVD as the noise gets very loud.
Thanks,
Cindy
Aug 14, 2006 | Sony HTD-C800DP System
Sony HT-DDW790 System Logo
276 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
