Question about ASUS Eee PC 900 Notebook
More momery i have a Asus computer which, has limited memory avaliable, is it possible to download virtual memory, would it make the computer have more momery and move faster?
    Sergeant:
  • 326 Answers
U can expand u r ram memory
Posted on Apr 19, 2009
Memory is used up by excel
I don't think you can. It's a real resource hog especially if youre using 2010/13. See below.
Excel 2003 is officially limited to 1 Gigabyte (GB) of memory.
This limit appears to be a limit on the working set memory used by the Excel process, which is the memory reported by Windows Task Manager.
Although Excel 2003 has a substantially increased memory capacity, many of the individual specific memory limits listed below have not changed in Excel 2003.
Excel 2007 is limited to 2 Gigabytes of memory for the Excel process under Windows XP/Vista (Windows memory limit).
This 2 Gigabyte limit is a limit on the Virtual Memory address space. Virtual memory used by a process is larger than the working set memory reported by Windows Task Manager, so the amount of useable memory under Excel 2007 is considerably less than twice that of Excel 2003.
Because Excel 2007 (Excel12) also requires more memory to store the indexes to the increased number of rows and columns you may not be able to load larger workbooks under Excel 2007 than was possible under Excel 2003. Memory Fragmentation may also mean that it is difficult to make use of all of the available 2 GB of virtual memory.
Many of the individual memory limits listed below have been removed in Excel 2007.
Excel 2010 is available in 2 versions: 32-bit (2 Gigabytes of virtual memory) and 64-bit (8-Terabytes (which is 8000 Gigabytes of virtual memory)).
The 32-bit version has the same memory limits as Excel 2007, but the 64-bit version, when used with a 64-bit Windows operating system, will have extremely large memory limits.
Note that the different versions of Windows Vista 64-bit and Windows 7 64-bit support differing amounts of RAM.
Aug 17, 2014 | Microsoft Excel for PC
Tip
How to run a guest operating system inside a host operating system without dual...
Install virtual box from : Download VirtualBox
VirtualBox is a cross-platform virtualization application. What does that mean? For one thing, it installs on your existing Intel or AMD-based computers, whether they are running Windows, Mac, Linux or Solaris operating systems. Secondly, it extends the capabilities of your existing computer so that it can run multiple operating systems (inside multiple virtual machines) at the same time. So, for example, you can run Windows and Linux on your Mac, run Windows Server 2008 on your Linux server, run Linux on your Windows PC, and so on, all alongside your existing applications. You can install and run as many virtual machines as you like -- the only practical limits are disk space and memory.
Follow the instructions on
Chapter1 First steps
on May 27, 2015 | Computers & Internet
Tip
Virtual Memory too low Warning Trouble in win xp and vista
When there is less physical memory than needed, then some virtual memory (virtual RAM) is created on the disk. When there is a limit set to the size of virtual memory usage and there is not enough of it present there is a warning that frequently comes "Virtual Memory too low". Solution 1 : This problem occurs when physical RAM + Virtual RAM (usually created on hard disk) together are not sufficient to take care of the currently needed RAM size, or this situation is about to arise. This usually happens when some fixed upper limit for Virtual Memory has been set. To solve this problem, you can either upgrade you physical RAM on your computer (recommended), or you can set the Virtual Memory to system managed size or you can do both. Setting Virtual Memory to system managed size means windows will set it to higher size whenever needed automatically,for this, <br /> Right click on My computer --&gt; goto properties, goto advanced tab, click on performance settings, now click on advanced, now click on advanced, now click on change button for Virtual memory. <br /> On this screen select the System managed size, press OK. After this re-start your computer. This will solve the virtual memory too low problem. Solution 2: Recommended solution is to upgrade your physical memory (RAM) according to requirements of the kind of applications that you run on your computer. If you upgrade RAM or not, the following procedure will help prevent this warning by increasing the virtual memory limit. <br /> Right click on My computer icon and click properties. <br /> This will show system properties window. Click on a advanced tab and click on the settings button under heading performance. This will open performance options window. Click on advanced tab and click on change button under heading virtual memory. Check if the space available is set to some custom value or double the RAM size ? If it is not double the RAM memory size , then select the size option set the virtual memory size double the RAM Size and press set button and press OK button. Restart the computer
on Apr 04, 2011 | Computers & Internet
I can't download messenger in my computer tell me why?
its a result of low virtual memory of your computer.because it take longer time to download it.what you have to do is to increase your virtual memory or delete some file,if you know that you have enough virtual memory.
Jul 09, 2010 | Yahoo Messenger
System says low on virtual memory even after I zero & format the hard drive with new operating installed?
this is virus instaled on computer bios or defective memory boards.
1st replace memory, and check-it.
2nd find a original bios on IBM website, and flash-it.
Nov 22, 2009 | IBM NetVista PC Desktop
I have a PC900 ASUS with 4gig C: drive and 16 gig D: drive running xp pro on C: I keep getting low memory errors. What can I do? Thank you Earl
Stop running so many applications.
You have less hard drive space on C: than I have memory on my computer. I am currently running 2.85G memory utilisation - if that was your laptp, that means nearly all of your disk is used up by virtual memory.
You can change your swap space to your 16G drive - go to desktop. right mouse on My computer> Properties > Advanced > Performance > Advanced > Virtual Memory
Change the location and size of your swap file.
You can also add more real memory - that is the most efficient and effective way to increase your performance as well.
Jun 29, 2009 | ASUS Eee 4G Notebook
Limited video shared memory 64mb
Hi icr
You better try to increase the virtual memory of your system as seems you would nt be able to increase the pre allocated video memory to your video device.
The virtual thing you can do by going to the my computer's properties and then in advanced tab you find performance options .Here you can tweak your virtual memory accg to your systtem memory
Waiting for your appreciation
Feb 15, 2008 | HP Pavilion dv1000 Notebook
Noki6230 delete fhome momery
there is no possible way to format 6230 phone memory. you can manually erase phone memory contents.
Dec 22, 2007 | Nokia 6230
Shareing virtul memory
there should be no virtual memory limitation on a motherboard. That limit is a windows only setting that is controlled through the control panel and limited physically by the hard drive. Perhaps you mean to say video memory? ...or conventional memory?...or which other?
Jun 09, 2007 | Asrock P4I45GV R5 Motherboard
ASUS Eee PC 900 Notebook Logo
109 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
