Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Replacing actator-water on kenmore side by side .
I Need to replace actuator -water on my side by side ,and i do not know how to take off the panel. i bought the actuator from Sears and the said it was easy to replace the part.PLease advise
  • Kathy Heidel Sep 04, 2008
    My side by side is model #5432404 and i have to replace the actuator for filtered water. I removed the tray and I do not see any screws. How do you take the panel out to replace actuator?
  • 625 Answers
The water tray probably just pulls out and there's screws near the base that comes out. up underneath there should be some screws to take out. thhen the unit comes down and out the front. wires and a hose will be coming out with it.
Posted on Sep 19, 2007
Location of top actator 2000 chevy tahoe
You must remove the dash to replace the temperature control blend door and its actuator, it is combination repair.
Dec 27, 2012 | 2000 Chevrolet Tahoe
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
Water is leaking from the top of the top drawer, mainly on the right side of the top drawer. Is there an adjustment to raise the tub so that it would have an even seal to prevent the water from leaking. I...
Don't know anythings about these but if they are drawers they either slide in and out or they roll on rollers it could be that the side guides that is moves in and out on has broken or come loose from the side of the dishwasher. Is it hard to open the drawer if so it could be that. Again I don't know anything about these hope this help though.
Mar 30, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do i replace a water actuator on a kenmore refrigerator
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0501084-00007.png
its about $70 for the part,....what a jokers
Jan 07, 2010 | Kenmore Refrigerators
Need to replace the water actuator on frigidaire model FRS6B7EESB
To get help replacing the actuator you can visit mu site below and enter your model number FRS26R4A in search feature this will take you to the parts page. On left of screen click picture #15 dispenser. I shows a diagram of the parts and I or Appliance Parts can assist you in installing the actuator. Thanks Sea Breeze sea breezehvac@yahoo.com
click on link below
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Frigidaire FRS26R4A Side by Side...
Broken water actuator
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Jan 25, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore/Fridgedaire refrigerator ice actuator replacement
hi thanks for the question are you talking about the arm to stop the ice making if so you can just put back in clips on the front of ice maker and at back thanks the appliance doc
Sep 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 253.51399101
Maybe this will help .. should be diagram of dispenser http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0165000&brandID=0582&modelDesc=SIDE-BY-SIDE%20REFRIGERATOR&modelNumber=25351399101&documentID=P0104005&documentTypeID=PLDM&documentClassCode=PM&titleType=DISPENSER&titleID=00007&
Sep 24, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore side by side ,model no 253.51399101
To access the front of despenser.. most times there is a molding around it the will pop of my Gently prying around it .. screws are behind molding
Sep 20, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
192 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Bill
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
