Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
40 inch sony 5 years old that turns itself on.
I have older parents with a set that turns itself on when it is not in use. it has once turned itself off while in use. all batteries of all remotes are new. it happens even if remotes are removed from room. parents had tv repair guys come who could find nothing wrong to fix. one site on the web talked about a 1 ohm resistor in the microprocessor whose values may have changed. any suggestions?
  • jlsmith Sep 19, 2007
    are you referring to the power cord plug and/or the wall outlet/socket?
O LED PISCA MUINTAS VEZES E NAO ARRANCA A FONTE
Posted on Jun 18, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
There might be loose contact or sparking in plug or socket.
Posted on Sep 19, 2007
SOURCE:
Hi my parents have a 10 year old Electrolux oven eob63100k it works for about 50 mins then turns itself off and after approx 15 mins comes back on again all by itself any ideas?
Thermostat issue when it reaches heat its set to it should turn off and then come back on when it drops below that temp
check if thermostat is clean
Sep 26, 2017 | Electrolux Ovens
How to stop sony demo mode
  • Turn on your Sony Braviaicon1.png.
  • Press and hold the Up Arrow button on the remote control
  • Press the Powerlb_icon1.png button on the TV while still holding down the Up Arrow button. The TV will turn off and then turn itself back on.
  • Release the Up Arrow button. Once the TV turns itself back on, it will restore your Sony Bravia to its factory settings.
  • http://www.ehow.com/how_5855646_reset-sony-bravia-tv.html
    May 17, 2013 | Sony KDL 40CX520 40 CX520 Series Full HD...
    Hi We bought a Sony Bravia 40" 2 1/2 years ago. Model # KDL40EX400. After about 14 months we started to experience something very bizarre. The TV would turn itself off. No lights on the screen. Af
    At some point you have to cut your losses, this is the reason I suggest getting an extended warranty with coverage (including the maker) of 3 years, 80 of the 140 sets in our shop are less than 3 years old, if this set had that they would have to fix or replace the set----One reason I choose to answer your question (I do this here for free) is this set ought to have a error buffer, when set fails it will count the event and that also indicates where the issue is.
    Most of the Sony sets for the last decade with set off and using the Sony remote: Display, 5, vol down, and POWER will if set comes on bring up a display with a number of shortened items listed----they should all if the set has this be a zero. Any with a number indicates a issue and the number indicates the number of times this event has happened.
    Dec 04, 2012 | Sony KDL40EX400 40 in. HD-Ready TV
    I just got a Sony Bravia 40 inch lcd 1080p high def tv. I am able to pick up a dvd picture on it, but I am having trouble finding my cable channels. I do have a cable box, and it is hooked in there...
    When I installed my dads Samsung 40 lcd 120 hz. I had to turn it all off and after 5 mins I turned on the cable and then 5 minutes later I turned o the tv.
    Or have you tried "searching" the tv for cable channel's?
    Jun 17, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
    KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
    sony 52 inch tv in stand by mode comes on and off on its own
    Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
    SONY TV KEEPS TURNING ITSELF OFF!!
    Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
    May 23, 2007 | Sony KV-28FX60 28" TV
    Sony Trinitron TV will not turn on
    First thing that comes to mind is that the horizontal driver transformer has bad solder connections on the primary and the secondary windings. Also a set this old could also have a defective regulator IC if you dont know wht m saying , b=est thing to do is find out how much an estimate is then go back to best buy and see what a new set cost cause man you got your moneys worth outa this one for sure!!!!! Good Luck
    May 02, 2006 | Sony FD Trinitron WEGA KV-36FV300 36" TV
    Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
    279 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
