Question about Singer Sewing Machines
Material won't feed just stays in one place, the drop feed control doesn't move the teeth.
  • 374 Answers
Hi! there,
feed dogs are mechanically connected to shuttle race link.everytime shuttle race rotatate and needle goes up and down the move relative to its timing order.there is control knob on feed dogs to release or goes down permanently not to move,on the right side of machine.if you push down feed dogs go down.try to find this one,if you can't try to see uder the machine if there a loosen parts behind shuttle race holding feed dogs.tighen this up.hopefully this could help you,have a nice day,just rate me thank's
Posted on Apr 19, 2009
My sewing machine wont RUN. The needle goes up and down but the material wont move along.
under the foot around the needle, there should be two rows of what look like teeth, these pull the material through and there will be an adjustment mechanism on the machine. Try leaving the foot up while you run the machine, you should see the teeth going up and down; if they are it is most likely just a case of setting up the amount of pull. I think it is adjusted with the wheel that sets the length of stitch.
Apr 07, 2016 | Sewing Machines
I started to sew and the needle does not move and just stitches in place.
does the plate under the presser foot move back and forth that is what moves the material some drop down when in certain modes . like darning or freehand quilting as I see no make I can not look your up anywhere .
Jul 21, 2015 | Sewing Machines
How do I stop my needle from breaking and how to I see to it that the machine is self feeding the material forward instead of me having to pull it towards me to get the stitches into the material?
The needle may be bent, but surely the material should feed away from you not towards? Is the bobbin in correctly? If you have inadvertently left the feed dogs down the material will not be gripped and stay in the same place instead of moving. Check.
Mar 27, 2015 | Sewing Machines
Needle is moving up and down but it doesn't move forward
if you have a manual, check and see where the feed dog lever is and make sure it's in the up position. when the feed dog is in the down position it's in the darn mode staying in one place,, but when it's in the up position the machine will sew.
here is a link for a manual, if you don't have a manual
http://www.sewingpartsonline.com/instruction-manual-elna-2110.aspx
Jun 12, 2013 | Sewing Machines
The feeder on my 6690 won't pull material through
Look in your owner's manual. I'm sure your machine has a reverse feed button but don't know if you can manually disable the feed teeth. If it is so equipped, it doesn't drop the teeth. Rather, it simply causes them to go straight up and down. If the teeth truly stay below the needle plate level, they are likely out of adjustment and need to bereadjusted and raised.
Jan 08, 2013 | Husqvarna Viking 1
Material won't feed through on kenmore 17600 sewing machine
Take out the material, take off the foot and needle. Stick your finger on the feed dogs and hand turn the hand wheel like sewing. Does the feed dog come slightly above the surface of the needle plate? If it does.... tighten the presser foot tension.
If it doesn't locate the switch that drops the feed dog. Make sure it's in up position.
If neither of those solutions work. Remove the needle plate and see if the feed dog or mechanism that runs it is broken
Good luck
Nov 10, 2012 | Sewing Machines
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
How do I get the teeth to grab and advance the material on my very old Bernina 830?
Well there's a number of reasons why it may not be advancing the material. First, ensure that the teeth are completely cleaned-out - get an old toothbrush, or similar with firm filaments and, with the stitch-plate removed and the bobbin door open, give the teeth a really firm clean across the teeth to remove anything in between ... this is especially important if you've been sewing with metallised fabric or thread. If the teeth are nice and clean, check if they are still pyramidal with a reasonably 'sharp' point facing backwards - if the machine is very old and very well used, the teeth might be rather rounded and it may be time that you have a new feed dog fitted ... some of the old machines are difficult to obtain spares, but they're mostly still out there. Most commonly, check how far the teeth of the feed dogs protrude above the stitch plate ... this is a bit difficult to do and should really be done with a proper gauge, but generally they should protrude 1mm above the stitch plate - less than that and you wont get the material to move properly, especially if its fine material. Lastly, it could be the foot pressure that's the problem ... if there's inadequate foot pressure, the material will not be pushed adequately onto the dogs. Again, unfortunately, you really need a proper gauge to set the foot pressure, but if the dogs are clean, in reasonable condition and have 1mm of clearance above the stitch plate, you can try increasing the foot pressure a bit. This is done by opening the top cover and you will see a large-ish flat-blade screw in a threaded tube just behind where the needle bar goes up and down and to the left of the takeup arm. If the screw is rather near the top of the threaded tube, you can try screwing it down (clockwise) maybe 2-3 turns to see if it makes a difference ... of not, dont be tempted to just keep screwing up the pressure ... there's something else wrong. Oh .... and by the way .... before you've done any of the above, I assume you've checked that the feed-dogs are not dropped ! You can drop the feed-dogs to do embroidery etc on the 830 - there's a small round knob below the stitch length control - make sure its turned to the position that shows a tooth pattern and not the cross-hathced pattern and make sure the feed dogs do actually come above the stitch plate when turning the handwheel - if they dont, or moving the feed-dog drop control doesn't make any difference, then the link mechanism is almost certainly jammed (really, really common on old machines that haven't been regularly maintained!). To free that off, you need to remove the free-arm cover and look to the front right side of the mechanics - you'll see a linkage that should turn when you rotate the feed-dog drop control - if this doesn't separate or is permanently separated, whatever you do with the control, you need to give it a drop or two of Bernina sewing oil and gently help it move - once free, that should solve the problem. I cant think of any other reasons !!
Hope that helps !
Nov 16, 2011 | Bernina Sewing Machines
Husqvarna 950E, the feed teeth will not lower. I move the dial and they stay raised. Even when the embroidery attachment is on. Can I manually lower the feed teeth?
If the machine has been taken apart it may have been reassembled improperly so that the dial on front of freearm is interfering.
Also, try removing the needle plate. If the teeth touch the side of the plate they may not drop properly.
Aug 29, 2009 | Husqvarna Designer I
Feed dogs not feeding the material
Is this a second hand machine ?
Is the stitch length selector set to > 1
Remove the needleplate and clean between teeth of feeddogs if it has been a while since this has been done, old lint will impede feeding.
Presser foot tension for general work needs to be set at 3, or the chromed button pushed down to the grooved line, depending on machine.
If new, call the dealer where you bought it and speak to them.
Nov 24, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
427 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
