Question about Acer TravelMate 8006LMi Notebook
Acer aspire t180 pc has parallel and usb ports printer does not work help
Cant hook up lexmark 1200 series printer to my acer aspire t 180 new printer and pc it says download successful but all items to print are qued wont print anything have had other people try to and they were not successful we tried two different printers. my pc has a parallel port on back plus usb my printer is usb please help
    Sergeant:
  • 457 Answers
Did you update the lexmark printers drivers from their site I think if you do this you should have no prolems.
Posted on Sep 19, 2007
SOURCE:
I have an older HP DeskJet 722C printer and an Acer Aspire 5050 3242 laptop. Is it possible to hook up this printer?
I would say, it quite possible. If, the printer is a USB connection then it is only the matter of assuring the drivers for the printer will work properly with the operating system. You may obtain the latest drivers here HP DeskJet 722C printer
If the Printer happens to use the outdated parallel port, I would suggest to use an adapter, you can review the ones currently available online here Parallel to USB printer cable
It is always possible to use old peripherals on newer machines, it is only the matter of researching the internet to rather any available adapters are on the market to maintain older printers.
I hope this is helpful!
Jul 13, 2011 | Acer Aspire One Netbook 8.9" Notebook
I recently purchased a new pc hp2009m and the cord on my lexmark e250dn does not fit my pc how can i adapt please advise. Colin
This printer has three standard ports: bi-directional parallel, USB, and ethernet (RJ-45). Most likely your previous computer had a parallel port. The simplest solution is to get a USB cable (Male type A to Male type B - 6' or less in length is recommended.) Install the software on the computer then connect the cable to the port on the back of the printer and to the computer (the square end goes to the printer and the rectangle fits the computer). The USB port is in the same area on the left side of the back of the printer as the parallel port.
Alternatively you could get a network switch and connect the printer as a networked printer. The ethernet port is near the middle of the back of the printer.
http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_E250D&segment=DOWNLOAD&userlocale=EN_US#1 has the software and drivers for support OS versions.
I hope this helps.
(Getting a bidirectional parallel to USB adapter is cludgy when you have a USB port available.)
Jul 01, 2010 | Lexmark E250dn Laser Printer
IM LOOKING TO CONNECT MY ACER ASPIRE 6920 SERIES TO A PRINTER. WHAT ARE MY CHOICES? AND COULD I USE MY OLD LEXMARK X5470 TO CONNECT?
The laptop will be compatible with almost every printer so long as you have the installation disk. If its an old printer and does not have a way to plug in a usb port there is a special adapter that goes from the printer port to usb port that way it is compatible.
Sep 01, 2009 | Acer Aspire 6920 Notebook PC
Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
I have a TP link wireless adaptor for an acer aspire T180 pc. I can't work out where to fit it on the motherboard
Providing the wireless adaptor is a PCI card this fits the white slot on motherboard.
Should it be USB, then plugs in the USB port.
Feb 22, 2009 | Acer Aspire™ T180 PC Desktop
T 180 desktop acer
Click on following link for audio driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-Audio-Driver-Download-37473.html
Click on following link for Ethernet driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-LAN-Driver-Download-37475.html
Regards,
Sandeep
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
My Fax on my lexmark 3400 series does not work.. How do i reserve message throw my fax.. And how should it be hooked up..
need to "hook up" acer 8spire T180, desktop with Windows Vista to a Lexmark 2500 series combo unit fax and printer. Do I need a Modem, for this???
Oct 13, 2008 | Acer Aspire™ T180 PC Desktop
No video/sm controller drivers for xp
hello,
YOu can download driver from the acer wbsite. or copy and paste to the address bar the link provided by geek63640, and then in "product line" select "Desktop" then in product select "aspire T 180" and in the download column select what driver you want to download.
But recommended to download all the drivers and then install all. pls install in series.
melnavz
Jun 20, 2008 | Acer Aspire™ T180 PC Desktop
Installing Lexmark 1200 series
Have you downloaded a "driver" for the printer. If not, search for "Lexmark 1200" free driver downloads. Or go to "control panel" and click on "add new hardware" and follow the onscreen instructions. Try this first and if not work, then do the search.
keever
Mar 04, 2008 | Lexmark X1270 All-In-One InkJet Printer
No Sound Now on Computer
Might be trivial, but try the volume controls, that little speaker icon on the Windows task bar.
Dec 28, 2007 | Acer Aspire™ T180 PC Desktop
Acer TravelMate 8006LMi Notebook Logo
392 people viewed this question
Ekse
Alun Cox
