I loaded HP Deskjet 6300 All-in-One on my computer and it disabled my DVD and CD drives. I previously loaded the same program on another computer and the same thing happen. I had to unistall it to get it to work again. I don't wish to take this off my current computer. There has to be a fix. Thanks. JOHN
  • jfilipo May 07, 2009
    I tried the solution, but the driuvers came back after booting and had the "!" mark in front of them.
    I still am unable to use either drives.Help please.
    JOHN
  • 385 Answers
Go to control panel, system, device manager, go to dvd/cd rom drives, double click it,
when your dvd/cd drive appears under it, right click this drive, click uninstall,
now reboot the system, system should scan for hardware changes, if not
Back to device manager, on the menu at the top is "Action" click it,
Scan for hardware changes is there, click this to scan, hopefully should be good now.
If not we need to remove upper and lower filters.
Let me know how you get on thanks
Regards
Richard.
Posted on May 05, 2009
  • Richard Finney
    Richard Finney May 07, 2009
    What operating system are you running please ? ie: Xp, Vista, Apple Mac ?
    Thanks
    Richard.
    Novelist:
  • 133 Answers
Hello John,
I would like to know the model number of your computer.. is it HP too?
Regards,
Srinivas
Posted on Apr 19, 2009
I want to install HP deskjet 3940 in my computer
Do the below steps.
1.Connect Printer cable(usb cable)to Computer&Swicth ON the printer.Printer driver cd also put in your cd/vd drive.
2.Start-device&Printers-Add Printer-Add a Local Printer-Select Port as USB001-Next-Have disk-Select yor Cd/dvd drive(Put Printer driver cd in your Cd/dvd drive)-next-next-Finish.
Jun 11, 2011 | HP DeskJet 3940 InkJet Photo Printer
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
D drive will not load some disc programs in to the computer
If you are saying D drive is your CD/VDVD drive? If you are installing from CD/DVD drive then suddenly stop the installation/setup/loading you must check your disc drive. To check your cd/dvd drive insert a cd or dvd cleaner and start cleaning most of the cleaner has a movie inside of the disc and run for about 10 minutes. Then try again installing/setup/loading the program to your computer. If its still the same, replace your CD/DVD drive with a new cd/dvd drive because your cd/dvd drive is need to be replace. Have a nice day
Jan 26, 2011 | Computers & Internet
How do i reset my hp computer back to the way i bought it?
factory settings could mean performing a system restore to a previous state of the OS. I'll try to explain how you can perform each one of these methods in the article below.
Restore Factory Settings - System Restore System Restore is the in-built tool of Windows XP and Windows Vista that allows you to roll back the registry to a previous state. Note that it only "restores" previous settings for the registry and Windows system files.
You can use system restore to get rid of spyware, but if system restore does not fix your problem, you'll have to resort to either a clean install of the OS or using your recovery CD/DVDs.
You can read my previous post on how to restore your computer using the System Restore feature. If system restore is disabled, you can read my post on how to enable system restore again.
Restore Factory Settings - Recovery CD/DVDs Most computers come with either a recovery CD/DVD or a recovery partition that is hidden on the computer. This is true for most HP and Dell machines now these days.
If you have one of these, you can access the recovery from within Windows or during startup.
For HP, you can go to Start, All Programs, HP Tools, and then choose HP PC System Recovery.
You can also press the F10 key multiple times during bootup to get access to the recovery console in case Windows is not loading properly.
On Dells, you can access the recovery partition by pressing Ctrl + F11 immediately after the machine is turned on.
Note that all of your data will be lost on the hard drive. Using a recovery CD is not the same as repairing XP. When you repair Windows XP, all of the system files are replaced with the original ones, but your data and applications remain intact.
Restore Factory Settings - Clean Install XP Your last and final option for restoring XP to factory settings is to perform a clean install. This requires having the CD/DVD for the OS. If you only have a hidden recovery partition, you will not be able to perform a clean install.
A clean install basically consists of booting from the original XP CD, deleting all partitions, recreating new partitions, and then installing Windows XP from CD.
It's a fairly straight-forward process and you can read this excellent tutorial for step by step instructions. Again, it's important to note that you will lose all your data in this process.
Oct 05, 2010 | Computers & Internet
The disc medio tray will not open and will not run on hp g60
Hi I'm Rain ,
Ok follow these instructions to reboot your CD Rom drive.
  1. click start then My Computer .
  2. In My Computer right click the DVD/CD rom drive icon .
  3. In the list , Click eject to see if the drive is being reconized .
  4. If nothing happens repeat steps 1-2
Now when you get to sep 3 you will click properties .
5. In properties click Hardware .
6. In Hardware click the DVD/CD device to highlight it .
7. Click properties .
Now look to the bottom of that window to see device status .
If it says , this device is working properly .Properties .
Next click Driver . In driver you will see a list of option tabs that allows you to , Roll Back driver Update driver and Disable driver .
The other option is Driver Details.
Click Roll Back driver to restore the driver back to the state before you added the latest program . Click ok and follow the screen instructions.
If this fails , you can follow these steps to get back to Driver and chose
Disable Driver . Click ok if another window pops up.
Now what you are doing is rebooting the DVD/CD rom drive.
This will restart all the drivers that are associated with the DVD/CD rom
device .
Now follow all the steps again to get back to Driver .
Now in Driver you will need to click Enable to restart the DVD/CD rom
device . Reboot your system and try the DVD/ CD tray to see if it responds . If it still fails to respond you most likely will need to replace or service the DVD/CD Rom Hardware { the Tray } .
Jan 08, 2010 | HP G60-230US Notebook
I have another computer, and cannot load my printer driver because I cannot locate my CD Rom. It is HP Deskjet D1520 It worked fine previously, but now does not communicate with my HP Pavillion computer....
Run system restore and restore windows to a previous state, if this does not work, then try to reload the driver, you can actually find the driver on the hp website
Oct 03, 2009 | Office Equipment & Supplies
Printer not recognized
make sure you installed the software properly..sometimes some software requires you connect the printer first then install software...other times you install software first then install printer....make sure the settings are set up the same on the printer and computer....make sure all connections are secure..check owners manual...
Apr 16, 2009 | HP DeskJet 1280 InkJet Printer
Hp deskjet 5150 - unrecognize
I have had similar problem with HP Deskjet 5150, after several emails and fone calls HP had the audacity to suggest my Windows XP program was not compatible with their printer, What a load of crap. No more HP goods for me !!
Oct 25, 2005 | HP DeskJet 5150 InkJet Printer
Computers & Internet Logo
David Payne
David Payne
