Question about Copystar CS-1815 Printer
I need help to install my copystar cs-1815 - Copystar CS-1815 Printer
  • 523 Answers
Its very easy let me know wat you want to do or if you want to send you the manual.
Posted on Jun 01, 2009
Copystar cs-1815 error code 3200, how can it be fixed
If it is a c-3200 code it means that you have a exposure lamp problem.Defective scanner,defective scanner PCB,lamp or inverter board,incorrect shading,poor contact of the connector terminals on lamp assembly. Look for a bad connection And look at lamp. Look for blue rings or burnt ends. Now don't look at that light while its on.
Feb 02, 2015 | Copystar Office Equipment & Supplies
My copystar cs 1815 is printing low on one side?
The feeder assembly must be out of adjustment this is most likely at the drum. 85 bucks just in parts. Labor would depend on whom you choose to have it repaired with.
Nov 26, 2014 | Copystar CS-1815 Printer
My kyocera copystar CS-1815 shows in the message screen "Waste toner near full." How do I empty the waste toner?
Hi there just open it up and inside there will be a small plass bottle that hold the waste toner you can clean out and put back.
Mar 04, 2010 | Copystar CS-1815 Printer
Copystar CS-1815 reports a paper jam at the document processor
Check for debirs in the unit that could be tripping the jam sensor if not the sensor has gone bad.
Apr 23, 2009 | Copystar CS-1815 Printer
Need the drivers to install my printer
Try your nearest copystar dealer.They generally have lots of those CDs around.The 1815 is a very common model
Mar 24, 2009 | Copystar CS-1815 Digital Copier 042DD512
Copystar CS-1815 waste toner
There are two screws on the drum unit. They are on the left hand side and one on the right hand side. Remove the screw from one side and take off plastic small side cover. Dump the waste toner. Do the same for the other side and then put it back together. Turn machine off then on and the error code should be gone......
Apr 17, 2008 | Copystar CS-1815 Printer
Service Manual for KM-1815 Kyocera Copier
all km manuals are available from New Jersey Copy
contact tony@newjerseycopy for all mita service and op mans
Nov 01, 2007 | Office Equipment & Supplies
Copystar CS-1815 Printer Logo
156 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
