Question about Mach Speed TRIO Onyx MP3 Player
Cannot clear drive to load or sync audio files
    Sergeant:
  • 326 Answers
Try factore restore settings
Posted on Apr 19, 2009
How do I fix my Motorola phone shut by chances
Hello Endzinaw!
We kindly recommend you to please follow this steps to troubleshoot your device.
As a first step, please try a Clear Cache partition
This will remove any temporary files that may be causing the problem, but will not delete your files or settings. Follow this steps provided in this link: http://bit.ly/RAZR-CLEAR
If this steps are not helpful, we recommend you to try a Factory Data Reset on your device. Make sure you back up your files first, since this will be deleting all the information stored on your device. I can recommend you to use the google tools, since they can really help you to back up your pictures, contacts and files.
You can learn more about the usage of this tools by following these links:
Google + Auto Backup: http://bit.ly/GPLUS-BACKUP
Google sync: http://bit.ly/Google-sync
Google Drive: http://bit.ly/Drive-backup
Here I leave you also the steps to do a master reset on your device: http://bit.ly/RAZR-RESET
If after all these steps you still facing the same issue with your device, please do not hesitate to contact our customer service at this link: http://bit.ly/Moto-us
We will be more than glad to help you.
Best Regards,
Liz
Motorola support.
Nov 11, 2014 | Motorola Mobility RAZR XT910
Can i transfer my pictures from the gallery on my tablet to a flash drive
Yes, but it takes several steps to transfer pics from your tablet to a flash drive.
There are two ways of accessing tablet files: 1) wireless access which requires a sync app on your tablet and PC software of the same app type. One such app for sync between Android (any) to/from PC software is Cheetah Sync: http://www.jrtstudio.com/cheetah-sync-android-wireless-sync.
Alternatively, you can use ES File Explorer's Network/LAN/Cloud/FTP functions to share files between your Android phone/tablet and your PC via secure Wifi: http://www.cnet.com/how-to/share-files-between-android-and-windows-with-es-file-explorer/
or 2) wired via the USB charging cable, which I will explain in more detail:
Plug your table to your PC using the Samsung charger cable that doubles as a data transfer cable when you remove the USB plug from the wall charger cube and plug it to the USB port on your PC.
Your PC should read your tablet as an external drive: Open "My Computer" and double-click the tablet drive icon>search your subfolders for your pictures. Highlight your picture files and either copy and paste or drag and drop (different way of copy/paste) to your desktop (or desired location), copies will be transferred but not moved from the tablet unless you "cut and paste" from your table to PC to clear out your tablet and make more space. When done, unplug your tablet cable from the PC. Plug in your flash drive to the available USB port: access the flash drive icon on My Computer. Drag and drop or copy and paste picture files to your flash drive.
Sep 24, 2014 | Samsung Tab Tablets & eReaders
Audio and video get out of sync
What you are doing requires a lot of resources. A lot of RAM memory, a fast processor, plenty of space on your hard drive. If nothing else has changed you probably need to clear space from Temp files, un-necessary software and old emails! After a clear out, give it a Defrag and try again.
Mar 26, 2014 | Gateway SX2110G-UW308 Small Form Factor...
Audio out of sync
There could be a few different problems. You should first narrow down the possibilities. If you are playing the mp4 file directly from your laptop try changing the source. Put the mp4 on a usb drive or on a playstation/xbox or simply on a dvd. Try playing the file through one of these other sources. If the audio no longer lags behind the video than its likely an encoder setting that your Hisense doesn't handle well. If lagging is still present on all your sources then change the type of cable. If you are using HDMI try RCA or vice versa. You can also separate the audio from the video. Try using a VGA cable between your laptop and TV for the video and use a separate RCA to 3.5mm headphone jack for the audio, Most Flatscreen TVs have dedicated audio inputs for different video inputs. Try out these different set ups and you can determine if the problem is with the TV the Laptop or the cables in between. If it is the TV you may have a problem with the main board but this is unlikely especially if the audio video sync works fine with other file types.
Jan 27, 2014 | Hisense Televison & Video
Need to sync to play music. how to sync?
Syncing refers to software a program you have installed on your computer to use with a device.Don't expect i tunes or other programs to sync with another device.Install the program from SanDisks web site.Another way to load MP3 files is to attach the unit to your computer and open the drive on the unit,Drag and Drop to Drive or folders on drive .
Jan 04, 2011 | SanDisk Sansa m240 MP3 Player
How to load audio cd that's mp3 readt to a ipod
you can use Itunes to convert all Mp3's to an Ipod Format that's the only best and sfest way to prevent any corruption to the files and to the Ipod itself.
Once you installed Itunes on your PC, search all the Mp3's to have it sync to the Itune program conenct your Ipod Itunes will detect the Ipod and ask if you would like to sync your device "ipod" with Itunes I suggest you select no do not sync the ipod to youe Itunes any changes on the Itunes when you sync your Ipod will also change the way you have your Ipod setting. once the Audi Files are detected by Itunes you can drag all the music you like to your Ipod's Name on the Left side it should show once you connect your Ipod this is the only way you can upload Mp3 files to your Ipod if you don't use Itunes the Audio File may be installed in your Ipod but may not run, Apple has a different Format this is the reason why you need Itunes.
Jun 27, 2010 | Audio Players & Recorders
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Getting music from cd into Insignia
if you Windows Media Player 9-11 you should go under sync and load the music that way then push sync button under the list
you can add the WMV, WMA in a raw fashon or add the playlist by dragging the playlist or indavidual song to the sync list
or
go under my computer in win XP/Vista click on the device and then click internal storage and drag the music files to the audio folder and the video files to the video folder(after making the folder)
Aug 21, 2008 | Insignia NS-DV2G MP3 Player
No audio on driving directions.
You will need to perform a hot sync to restore your voice files to the unit.
Feb 25, 2008 | Garmin iQue 3600 GPS Receiver
Mach Speed TRIO Onyx MP3 Player Logo
64 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Gyula Lacz
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
