Question about Linksys WRLS BRIDGE |WMB54G MUSIC R
Lynksys router model befw11s4
I put a admin password on this thing and turned around and forgot it. Any thoughts on how this can be reset?
  • 24 Answers
You're going to have to reset the router, itself.  There's a reset button found on the back of the router.  Insert something small enough to fit in that hole, push & hold down the button for a few seconds. However, this will clear all the data from your router, including your settings...make sure you have all your settings information before resetting the router.
Posted on Oct 27, 2007
SOURCE:
How can i put a password on my linksys befw11s4?
Turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
Aug 04, 2012 | Linksys BEFW11S4 v4 broadband DSL router...
Forgot user id for router
Look on the back of your router for a url (numerical Web address) that is the format of 123.456.7.8 In your PC Internet browser put said url in address bar and connect to your router. Your user id should be on the first page. If you have forgotten your password contact your service provider to reset.
However your user ID and preset password should be on the sticker on the back of your router. If none of this works contact your service provider.
Sep 25, 2011 | Linksys Wireless-G WRT54G Router
I am not sure where I can find the four to eight digit pin for my linksys model router, as I have tried everything listed under the router itself.
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Sep 18, 2011 | Linksys BEFW11S4 802.11b Wireless...
I need a password for my lynksys
IF you didn't set a password then at the login screen :
Login ... leave blank ( some models use the word admin)
Password admin
IF you set a password and forgot it you need to restore the unit back to defaults and erconfigure the router
To restore press the reset button using a toothpick or similar item. Its located on the back next to the WAN port connection
Jul 20, 2011 | Linksys WRT54G2 Wireless Router
Forget my password
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 18, 2011 | Linksys Wireless-G WRT54G Router
I have fa linksys router model BEFW11S4. I NEED THE PIN NUMBER, WHERE CAN I FIND IT? I DON'T HAVE THE MANUAL OR CD OR BOX. PLEASE HELP
Should be on the White sticker on the bottom. If you need to login to the router to change settings You need to access the router setup page by typing 192.168.1.1 on the address bar of a computer that is working with the router , then it will be asking you for a username and password , just leave the username blank and password is admin.
If you need to connect wirelessly to the router but there is a password you don't now you need to hard reset it: unplug it and hold the button on the back that says reset for 30 secs and plug it back in then connect. you must use a cord connection first to login to turn on wireless.
Jun 14, 2011 | Linksys BEFW11S4 802.11b Wireless...
I got a linksys router model BEFW11S4 ver. 4 from a friend who doesn't recall what his user id or password are. How do I get around this problem and reset the router?
On the back is a pinhole near the power jack socket. Put a pen nib in there while it is powered on and then hold until the lights start to flash. It is now reset to: 192.168.1.1 user: admin pass: admin
Nov 06, 2010 | Linksys Computers & Internet
I HAVE A LINKSYS wireless-B broadband router 2.4 Ghz 802.11 Model BEFW11S4, and i am on guest account and i do not have a disk for instilation so is there a way to instal it without a disk?
You dont need an admin account or installation disk to install the Linksys router that you have.
Just get an Ethernet Cable plugged in to 1 of the 4 ports at the back of your router and plug it to your computer.
Then Access your router via your computer by opening Internet Explorer and type 192.168.1.1 to the address bar.
if it would ask you for Username and Password, default should be the one below.
Username:
Password: Admin
As you can see you just need leave the password blank and put admin to the passowrd.
if this password doesnt work just press the reset button at the back of the router for ten seconds and restart the router.
After that try accesing the router again. It should now let you access your routers setup page.
Oct 05, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
I changed my password but I forgot it
Do you have a Linksys router and you have forgotten your password or you want to reset the password to the default. Firstly you must have physical access to the router. This article is basically for WRT54g and model BEFW11S4
If you have changed the password from the default password and have forgotten the default or your router did not come with any documentation.
To regain access to the router try the following. In the username field leaveit blank and in the password field type admin
Username / leave blank
password / admin
The Rest Button on a Linksys Router
To reset the router
While the back of your router might look different, the reset button is usually clearly marked. To reset the router to the default password, insert something thin--like a pencil point--and depress the red button. Hold that for a few seconds. The password for your Linksys router should have reverted to its default.
Try accessing it from a machine that is plugged directly into it. The default address is usually http://192.168.1.1. When you gain access to the router then you can change the password to any word of your choice.
May 28, 2010 | Linksys Wireless-G WRT54G Router
Forgot linksys password
Reset your Linksys router back to default:
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 31, 2009 | Dell Inspiron 6400 Notebook
Linksys WRLS BRIDGE |WMB54G MUSIC R Logo
211 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
