Question about Compaq Presario M2000 Notebook
Have three vertical lines on my laptop Acer Aspire 3000
My laptop is about three years old and does not have any technical issues until few weeks ago. I noticed that there was a vertical line about the centre on my screen. Then after a few weeks there were two more.
Is there anyways to fix this without changing the LCD panel??
  • 519 Answers
This problem is possibly due to blown diodes in the LCD panel.
Posted on Apr 19, 2009
Vertical lines screen
First, has it been damaged, dropped...etc.? Second, have you change/updated drivers? How old is it? Does the laptop get very hot? Without proper air flow the Graphics Card may have suffered damage. Have you tried a system restore to a date before this issue?
Nov 19, 2012 | Acer Aspire 1800 Notebook
I have troubles with ACER ASPIRE 9300, the screen or rather the monitor is blurry with irregular vertical lines. The pictures and text cannot be seen as before. Am not very technical, how do I fix this...
If you are not that technical then I am afraid that you can do any thing to solve this problem. Sounds Like there is a problem with your Screen, You can check connecting External Monitor through VGA cable to your laptop and see whtr you are still getting the same problem.
I will suggest you to take your laptop to repairing center before you may damage it more:) Don't mind.
Aug 14, 2012 | Acer Aspire 9300-3716 Notebook
Aspire one model za3 user guide
Hello, your laptop is known as the Acer Aspire One 110, here is a direct link to the laptop from Acer. at the bottom of the screen you see a drop down menu for Technical Documentation, though I think Acer only have them in German? :-s
Jan 04, 2010 | Acer Aspire One AOA110-1113 Netbook
My battery dies within 20 minutes of use. I've let my battery charge overnight but i still only get about 20 to 30 min of life out of it. is that standard for an Acer Aspire 3000?
If the battery is more than one year old, or has been often used with the power supply plugged in, it might have degraded.
Sometimes you can regenerate it to some lesser extent by completely draining it and recharging overnight (but that's apparently what you already did).
So I'm afraid you will have to replace it.
A new Acer battery (4400 mAh) should get you at least three hours life, and up to six hours by being real careful (lowest screen luminosity, no disk activity, no heavy usage: e.g., vanilla word processing)
Oct 22, 2009 | Acer Aspire 3000 Notebook
Just asked. hi my acer aspire3000 has a vertical line and lcd how can i solve and what i should i do so that i can fix this problem?
The problem you've got is all about on your video card. This is the common problem. You have to change it with new one! To do this, you're need an expert to open the case on the motherboard. If you, locate the video card, pull it off and replace with same model.
Hoping that this can fix your problem..
Best regards,
Geloaa
Oct 06, 2009 | Acer Aspire 3000 Notebook
My Acer Aspire 3000, Keybourd Stopped Working
i had the same problem. the battery does something during startup and the only way i found to fix it was to turn it on without a battery while its plugged into the adapter, or leave it in standby instead of shutting down... i dont know if theres a better way, but thats what i do.
Apr 11, 2009 | Acer Aspire 3000 Notebook
Battery ac adapter overheats
You need to ditch the battery on the laptop. It is causing the issue. This is a know problem with this laptop.
Mar 31, 2009 | Acer Aspire 3000 Notebook
Vertical lines in my laptop screen
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
ACER 3023 SCREEN PIXELATING
Try uninstalling and reinstalling the video drivers. If this doesn't work, it's likely that the LCD control board or cable is damaged.
Feb 13, 2008 | Acer Aspire 3000 Notebook
Acer apire 3000 keeps freezing!
The first, best thing to do is to back up your data and do a system restore. Acer's have the restore function usually built into their acer system management software.
Restoring the computer will solve most issues. If you keep having issues after the restore you probably have a hardware error like a bad hard drive or bad memory.
Be sure to back up any important data as the restore will erase everything from the hard drive and set it back to the way it came from the factory
Nov 15, 2007 | Acer Aspire 3000 Notebook
Compaq Presario M2000 Notebook Logo
159 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
