Question about BargainCell AT&T HTC 8925 Tilt Smartphone Accessory Bundle - 2-In-1 USB Hot Sync Charging Cradle with AC Charger
Battery will not charge in phone on charger
My HTC 8925 PDA phone does not charge the battery when the battery is in the phone and the phone is plugged into the charger. I can only charge the battery in a battery charging dock. I just purchased this phone. Is that the only way you are suppose to charge this phones' battery or is this phone malfunctioning when charging?
  • 40 Answers
Ive seen phones that were the same but most newer phones should be able to charge the battery through the phone not just the battery cradle. You have probably got a defective phone. I'd be very surprised if it was designed that way but sadly its possible. Call your provider to double check and be sure to keep your box and all materials as most companies wont let you return or exchange a phone without the original packaging and everything in it. Good Luck.
Posted on Apr 21, 2009
I need to charge my htc wildfire s phone battery it won't charge it's not the battery or charger it's the socket
Probably you will have to buy an external battery charger that will charge the type of battery the HTC Wildfire is using. But if you upgraded to another HTC phone, maybe the new one is using the same battery as the Wildfire and then you can charge the old battery in the new phone and then use it in the old phone to transfer your contacts to the new phone.
Jul 31, 2014 | HTC Cell Phones
My tilt 8925 wont charge the battery anymore, I've had it appox 1 year. the phone reacts to the charger being pluged in but won't convert over to charging mode
If it will turn on a little, tap the icon for the battery in the upper right hand corner of your main screen. This will bring up a "system status" screen. Tap the icon of the battery there also. It will then pull up a tabbed screen. Under the "battery" tab, make sure that the check box next to "when device is turned on, do not charge the battery when connecting to the PC" is UNCHECKED. Then try plugging it into a USB port and see if it will charge or sync. I hope this helps!
Jun 29, 2009 | HTC Tilt 8900 Smartphone
ABOUT A TYPE OF CHARGER
I am in the possession of a new MP3 player SKI#450227 - how do I "charge" the Damn thing? There are 6 cords and I can't get any of them to match up!!!!!
Jun 13, 2009 | BargainCell AT&T HTC 8925 Tilt Smartphone...
Mobile phone does not power up
output pin connection may be failed...service the mobile
Jun 06, 2009 | BargainCell AT&T HTC 8925 Tilt Smartphone...
Htc 8925, error message ''no sim card detected''
Ensure all SIM contacts are straight & in line with each other. To clear corrosion on the contacts try using a clean pencil eraser. You don't mention if you get any error messages so I am supposing you aren't.
Mar 23, 2009 | BargainCell AT&T HTC 8925 Tilt Smartphone...
ATT Tilt Battery Won't Charge
i had the same problem. unfortunately, after several trips to the AT&T store and my office IT department, there's nothing that can be done. the AT&T store suggested cleaning my ports with a small amount of WD40 on a q-tip to clear out any rust that may have formed, so you could try that. If not, get on ebay and buy a spare battery and a charging console (where you can put the battery by itself to charge) and continuously switch them out. its not fun, but that's what i had to do, and i've been doing it for a year now.
Feb 26, 2009 | BargainCell AT&T HTC 8925 Tilt Smartphone...
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
My htc tilt stopped workng.
I've seen this on the 8525 which is the same basic model (different processor and few different features) as the 8925 (Tilt).
Most likely it's a bad mini-USB port on the phone. You can check this by replacing the phone's battery with one that is known to be fully charged.
As for water damage, the only way to know is to check the water damage sticker.
Dec 12, 2008 | HTC Tilt 8900 Smartphone
BargainCell AT&T HTC 8925 Tilt Smartphone Accessory Bundle - 2-In-1 USB Hot Sync Charging Cradle with AC Charger Logo
313 people viewed this question
Top BargainCell Cell Phones Experts
matt
matt
Jim Goldsmith
Jim Goldsmith
Are you a BargainCell Cell Phone Expert? Answer questions, earn points and help others
