Question about Kenmore 500 6952 Dryer
Top loose, new dryer not level? rattle when start
Top loose. strange sound when drying. like rattle or? not sure dryer levelled properly. thought it had self levelling feet. i guess not!? 29" dryer
  • 351 Answers
No dryers are not self leveled. You may not have put the legs on ? they come in the box or if you have then you need to prop them up with a 1x4 or something.
Posted on Apr 19, 2009
6000 Series Rattle & Vibration
Sounds like the drum wheel or wheels need replaced .The twist frame thing just doesnt line up sorry ..LOL
Aug 19, 2013 | Maytag Dryers
Tip
How to Diagnose Maytag Neptune Dryer Problems
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Level</span> </li></ul> <ol> <li> 1 Ensure that the dryer's door is latched shut and that the power cord is plugged into an electrical outlet. Also check the home's fuse box for a tripped circuit breaker.<br /> </li> <li> 2 Make sure that the "Air Fluff" button on the dryer's touchscreen has not been selected if the dryer fails to produce heat. Also clear the lint screen if the dryer fails to heat.<br /> </li> <li> 3 Check the exhaust system, which exits from the back of the dryer for clogs, which commonly occur if the lint screen has not been cleaned regularly. Also ensure that only 4-inch metal exhaust tubing is used for the exhaust system. If clogs are present due to an improper exhaust system, the dryer will fail to dry the clothing completely. Also avoid overloading the dryer, which can also cause a drying problem. The amount of clothing equal to a single wash load should not be exceeded.<br /> </li> <li> 4 Check for the presence of loose items if the dryer produces noise, such as coins and loose buttons. The dryer will also produce noise if it is not leveled properly. Place a level on top of the dryer and turn the foot located on the bottom of each corner of the dryer until the dryer is level.<br /></li></ol><span><a href="http://www.ehow.com/how_5557946_diagnose-maytag-neptune-dryer-problems.html#ixzz19V7gQpV4"></a></span>
on Dec 29, 2010 | Dryers
My Maytag Neptune Dryer works great with no close in it. As soon as you put clothes in it wont stay hot.
Instructions
Things You'll Need:
* Level
1. Ensure that the dryer's door is latched shut and that the power cord is plugged into an electrical outlet. Also check the home's fuse box for a tripped circuit breaker.
2. Make sure that the "Air Fluff" button on the dryer's touchscreen has not been selected if the dryer fails to produce heat. Also clear the lint screen if the dryer fails to heat.
3. Check the exhaust system, which exits from the back of the dryer for clogs, which commonly occur if the lint screen has not been cleaned regularly. Also ensure that only 4-inch metal exhaust tubing is used for the exhaust system. If clogs are present due to an improper exhaust system, the dryer will fail to dry the clothing completely. Also avoid overloading the dryer, which can also cause a drying problem. The amount of clothing equal to a single wash load should not be exceeded.
4. Check for the presence of loose items if the dryer produces noise, such as coins and loose buttons. The dryer will also produce noise if it is not leveled properly. Place a level on top of the dryer and turn the foot located on the bottom of each corner of the dryer until the dryer is level.
Feb 23, 2011 | Maytag Neptune MDG6800 Gas Dryer
Loooking for pull cord 5hp/ 22 inch snow blower ultra by murry. My cord broke yesterday mhagansr@comcast.net
Instructions Things You'll Need:
  • Level
Jan 28, 2011 | Dryers
Start/ pause button flashing 47 minutes left to cycle pushed every button will not do anything
  • Level
  5. please comment on these solution by saying how helpful
Dec 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The start button is flashing red and beeping and the drying cycle won't start. Help!
  • If the machine shakes or makes a lot of noise, make sure the dryer is level. Some shaking is normal, but it shouldn't bounce around like it's itching to go somewhere. Adjust the leveling legs. They just screw and unscrew. Check to make sure the load inside the dryer is properly distributed and is not all clumped together.
  • Match the control settings to the type of load, and make sure you're not overloading the dryer.
  • Check that the ducts aren't blocked if the clothes take too long to dry. Look for lint or missing socks. Check to make sure the ducting isn't kinked, and make sure the outside dryer vent flap moves freely and isn't blocked---by snow, for example.
  • Sort your clothes by weight if they aren't drying properly. Lightweight clothes should be dried separately from items like comforters.
  • Make sure the lint drawer is empty.
  • Press the "Stop" button or press the "Lock" button for three seconds if the controls don't work. Press the "Power" button to wake the dryer up if it won't start. Make sure the "Delay Start" button isn't flashing if the machine fails to start. Press "Start" again.
  • If you see only lights displayed on the screen and no numbers, it's normal. The dryer has detected a low level of moisture. Other normal behavior is when the time remaining jumps to a lower number---it's revising its estimated time remaining. When you can't make a selection and the dryer beeps twice, the dryness setting is incompatible with the chosen dry cycle hope this helps please tell me if it does
Dec 06, 2010 | Zanussi Dryers
When it rotates it gives metal banging sound what is the reason?
Make sure dryer is level on the floor, and that nothing is leaning against the dryer.
Make sure nothing is loose inside the drum. Check all exposed screws, and make sure they are tight.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 20, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Makes a humming nose when you press start
Gas Dryers may produce buzz when the solenoid opens. The valve clicks at the start of the heat cycle, start of ignition and when the burner turns off. The flame makes a low roaring sound.
Jun 18, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Strange rattle when microwaving
Chances are the blade assembly has come loose on the shaft of the internal cooling fan.
This can be solved with a couple of drops of super glue at the spot where the blade and shaft meet, then allow it to dry for several minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you'll see the cooling fan.
Please let us know what you find.
Dec 23, 2008 | Sharp R-1490 Microwave Oven
Kenmore Dryer makes Noise Model 86671100
Very few of the tubs are true to round. You stated it has made the sound since you've owned it. Observe and listen to see if you can determine the closet area to the noise. Usually moveable parts get louder over time. Your problem could be a number of things. I would start by adjusting the bottom leveling feet and be sure it is level front to back as well as left to right. Other items could be drum seal gasket bearing, rear felt seal, rear drum support roller, belt tension pulley, blower wheel, blower wheel housing, front drum glide bearing, shaft drum support roller, bracket for drum support roller, front ring bearing kit, pully on the motor, or even lose cabinet housing bolts.
Use the below link to refer to on how to get inside:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Nov 07, 2008 | Kenmore 22422 Top Load Washer
Kenmore 500 6952 Dryer Logo
140 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
