Question about GE DVLR223 Dryers
How do i put the belt back on
Ge dryer
  • 2 more comments
  • blklucyga Apr 19, 2009
    how does it look when it is on right
    the belt came off as i was replacing the heating element
    i was checking the heating element and laid the dryer down and the belt fell off
  • Mark Nichols May 11, 2010
    mmm shoot let me think i know the route pattern i think its under than over, get your model number and i can tell you.
  • GE Master
  • 4,654 Answers
Unplug dryer, then pry the front left and right corners of the top up and try not to scratch the paint. Tilt the top back to the wall behind dryer. unplug door switch and remove sheet metal screws from inside of front. Then as pulling the front away from drum reach inside door with one hand and lift the drum up slightly as to relieve the weight of the front of drum up off of the plastic slides that serve as a resting place and friction guide for drum. Then again lift drum slightly and slide belt back around the drum, put front and top back on after deciding if you can feed the belt around motor pulley and spring loaded idler pulley from above or a square door in bacl of dryer. There are a lot of ways the idler pulley has the belt fed through. But I think you will make it ok, Let me know, Sea Breeze
Posted on Apr 19, 2009
  • John Tripp
    John Tripp Apr 19, 2009
    I did not know you had gone that far. Here is a photo hope this helps.
I need to know to route my dryer belt on my GE dbrl33ee2ww dryer as the belt slipped off and I did not see the correct path
Hi Roy, W/D here. I wrote this earlier for another person, but it works just as well twice.
You already have the diagram! (Bear with me).
Make sure that your power is off.
If you look carefully at the drum, you can see where the old belt was running.
Place your new belt in that position.
Now, place the belt over the motor pulley (It is in the same plane as the belt position on the dryer).
Pull the tensioning pulley past the belt, and ease it into place.
Roll the drum several revolutions by hand, just to get the belt tracking completely right.
Put it all back together and you're done!
Best regards, --W/D--
Feb 01, 2011 | Dryers
Dryer squeaks when drying clothes
try letting the mouse out??? its likley to be the drive belt or rear bearing dry,,, could be the motor bearings dry,,
back bearing and motor bearings could be lubed with WD40 but dont put it any were near the drive belts as they will then slip like mad,
spray on the driv belt a bit of "stop squeak" its for car fan belts realy but it works on any rubber belt
Oct 24, 2009 | GE DRSR483ED Electric Dryer
How do I put the belt back on my GE profile harmony dryer just don't know how it goes back on I try to put it on and it feels lose or doesn't catch
it has to run through the tensioner on the bottom ... through the tensioner and around the pulley on the motor ...
I hope this helps
Oct 09, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Jan 04, 2009 | GE DBXR463EBWW Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Broken belt
Hi , in replacing belt try to trace where belt way to go outside remove some bolts be sure unplug power , in putting back belt is the same way go in to install belt.
Feb 21, 2008 | GE DCSR483EA Electric Dryer
GE DVLR223 Dryers Logo
131 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
