Question about Kenmore Washing Machines
Problem with Kenmore Washing Machine.
How can I tell if the gearcase is out? I know the coupling is broke.
  • 351 Answers
IF your coupling is broke then put a new one on and see, but without a coupling then you dont have a washer period. Whirlpool is very good make if a new coupling does not work and you can hold the tub while it is spinning then you have a bad basket drive. but put a coupling on and then put it in spin, bypass the switch with a ink pen or something and try holding the tub if you can then its the basket drive if not your good to go.
Posted on Apr 19, 2009
The pump will drain but motor not getting signal to spin
If this is a top loading machine it is probably the drive coupling that is causing the problem. pump is driven from one end of the motor and gearcase driven from other. so when coupling is broke it will pump but won't agitate or spin
Jun 27, 2010 | Kenmore 40042
Kenmore Washing Machine 110.20722990 Will not agitate or spin. Took it apart and found a broken coupling between motor and gearcase. Does this mean gearcase is out?
no u just need to replace that motor coupling u just take pump and motor off take broke coupling off put new back on be as good as gold
Apr 19, 2009 | Washing Machines
Kenmore elite topload washer wont agitate or drain
the motor coupling broke ,,its between the gearcase and the motor
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Gearcase
The following link gives step-by-step instructions on how to repalce the gearcase on a Kenmore top loading washing machine with a direct-drive transmission:
http://www.fixya.com/support/r699497-replacing_gearcase
To answer your question, "yes", you DO need to remove the agitator. That is explained in step 11 of the instructions. I hope you find this information helpful. If you require additional assistance, please let me know.
PS Any particular reason why you are wanting to remove the gearcase?
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washer on the fritz
ck motor coupling probably broke or cracked not engaging gearcase
Sep 09, 2008 | Kenmore Washing Machines
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kennmore 22442
last belt drive kenmore came out in 1986..so doubt you find a belt on it unless you have a calypso model..if you have pump out but no spin motor to gearcase coupling is probably broke
May 05, 2008 | Kenmore 22442 Top Load Washer
Newer Kenmore washing machine doesn't spin in spin cycle
motor coupling broke ..this id dohicky between motor and gearcase or worse case gearcase suspect coupler first
May 04, 2008 | Washing Machines
Washing machine broken, kenmore model 110.92274100
REPLACE THE DIRECT DRIVE COUPLING IT IS BETWEEN THE TRANSMISSION AND THE MOTOR PART NUMBER IS 285753A THE TRANSMISSION IS NOT BAD
Apr 22, 2008 | Washing Machines
Kenmore washer
If your washer is not spinning fast enough, or barely spinning at all, this is usually a symptom of any one or all of the following: 1. Bad gearcase (transmission). 2. Bad basket drive, with which the transmission couples to under the agitator. 3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive. Usually a tell tale sign of a gearcase beginning to fail is the sign of an amber colored oil coated under the washer or inside the casing. I said, "usually". It doesn't always happen, but if you notice any signs of oil, the gearcase is shot. The basket drive and clutch assemblies are harder to diagnose and require some disassembly of the washer and the removal of the gearcase to inspect. Let me know if this helps.
Aug 01, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
