Motherboards
Problem for Motherboards
Generic problem for all Motherboards
My pci graphic card is not working pro...
By mral03 on Apr 19, 2009
My pci graphic card is not working properly, motherboard make beeping sounds but nort reconize mi video card.I alredy make sure it was completely in the slot and other troubleshooting.
Comments:
Apr 19, 2009
- it does not have connectors,. It just do not display in the monitor. thanks
Apr 20, 2009
- thanks a lot i think is the mother board that is bad , but I am nor completely sure.
i dont see any connectors, or the box did not came with any.
Apr 21, 2009
- D915GAVL motherboard trying to make it work with a EVGA 9400 GT video card just a black screen nothing else.
Apr 23, 2009
- Yes is a PCI E 2.0 card and I connected the 4 pin power cable to the motherboard.
Apr 27, 2009
- thanks, I tried that already and the BIOS does not come on neither. Maybe is the motherboard?
Solution #1
posted on Apr 19, 2009
Somewhat Helpful)
MPetro302
Rank: Wiz
Rating: 84%, 160 votes
Does it have a 6 or 8 pin connection on the top of the card. If those are not plugged in they will beep like crazy. Your powersupply might hvae these connections and if not the videocard should have come with an adapter.
Comments:
Apr 19, 2009
- those are power connectors for the gfx card. They must be plugged in or it will not work.
Apr 21, 2009
- Have you also connected the Square type 4 pin power and the 4 pin molex rectangular Power connectors on the motherboard?
Also this is a PCI Express card correct?
Apr 26, 2009
- if you have onboard video use that and go into the bios and then select PCi-E video save & reboot. then connect to the video card.
Was this helpful?
Yes
No
Solution #2
posted on Jul 01, 2009
Not Rated)
sparky1500
Rank: Wiz
Rating: 80%, 188 votes
you need to upgrade your power supply perhaps
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
I assembled a pentium 4 motherboard including PSB.Switch't "ON" ,Fan of the Processor... (More)
Answer
hi have a dv8225nr laptop. did bios upgarde to fix keybroad problem after download restarted laptop... (More)
Answer
Asrock 1333-D667 R2.0 and P1 20 Need infor to download current bios
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
